Question about Faber (272607) Kitchen Hood
Can you suggest a good degreeser to clean cassete filters tried several products but not very effective
I"m not sure what you mean by cassete filters, unless it's two filters. I take mine out and put them in the dishwasher!! Works great, The grease comes out and they shine again after I take them out. It does not hurt them, I have been doing this for years.
Posted on Apr 01, 2011
0NLY AUDIO,CAN'T SEE IMAGE
good day Angel i am Falco the problem you have might be due to dirty heads on the Drum unit, I would first try a head cleaning tape, there are 2 types of head cleaning tapes one looks like a typical video casset type tape and the other is like a wight frizzy type tape that you apply a cleaning liquid to for a deep cleaning the first one is used for preventative maintenance, try the 2nd type first, it may take several times to restore your video note allow time for the liquid to dry up before trying a tape at least several min`+ , if after this procedure the problem has not gotten better than you might have an electronic fault and might not be worth perusing further, If however this made some improvement than you are on the right track and might require a better cleaning procedures, if so contact me further and i will step you through the procedure.
best of luck and regards Falco
Oct 15, 2013 | Aiwa HV-MX1 VHS VCR
Where do i buy a filter for my eureka ez kleen vacuum?
Did you try amazon.com? Just search for Eureka 437 filters. There are several there with photos.
Apr 02, 2012 | Vacuums
What causes my toyota tacoma consume more gas to the mile than normal.
There are several issues that can cause poor gas mileage. I suggest you perform ( or have performed) a tune up. Filters, Fluids, Spark Plugs, Wires, Belts, etc.. & see if that improves your fuel economy...
Feb 25, 2011 | 1998 Toyota Tacoma
Hello, How can I clean the lower filter on our Dyson DCO8.
HI there,
By Lower filter i am going to assume you mean the one below the clear plastic dust bin. The machine you have described has a thick hepa filter (probably with a purple plastic rim) and unfortunately they cannot be effectively cleaned. If you are keen to try then I would suggest using an air compressor blowing from the top to the bottom.
What I would really suggest you do though is throw it out and replace the hepa filter with a new one. If you are in Australia I would try Vacuumspot or Nelson Vacuums.
Jan 01, 2011 | Dyson DC08 Hepa Allergy Bagless Canister...
The tape is jammed. it is half way out of the cammra, but it wont open or go back down.
try to pull out u r casset rebon slowlly if you fill too hard then cut the rebon, then resque your casset 1st. after that slowly clean the reamining rebon. batter you vist service center becouse there is a chance og damaged of ur CAM head. Be carefull. Good luck.
Jan 30, 2010 | Sony Handycam CCD-TRV12 Camcorder
I tried using a 800mm lens with a 2x teleconverter on my canon digital rebel every time i press the shutter button i get err code 01 what does this mean
Hey there derf69, the error code "err 01" indicates the need to clean the lens contacts, which in your case you have several. I suggest you completely clean the contacts using a contact cleaning solution which dissappears completely. you can also use a clean eraser to effectively remove any resilient buildups. I suggest you completely disassemble your lens configuration, and rebuild, once all contacts on the lens and camera body have been cleaned. There is also a possibility that you may have an incompatibility problem. If the cleaning does not help, please let me know and provide the exact model name and number of your camera, lens, and converter. Good Luck
Mar 13, 2008 | Cameras
New casset insertion not displaying any image on the screen
JUST BUY A CLEANING CASSETTE AND PLAY TWO OR THREE TIMES AND PLAY YOUR RECORDED CASSTTE.IT WILL BE VERY CLEAR.
REGARDS
SANKAR
Oct 24, 2007 | JVC GR-D370 Mini DV Digital Camcorder
DHR- 1000
Recently repaired one of these with what appeared to be a power supply problem; found several defective capacitors on the drive board. The symptoms were similar to what you are seeing.
Aug 20, 2007 | Sony DHR-1000 DVHS VCR
DCR-TRV130 - not playing back
The head may be dirty, clean it with a cleaning cassete, playing using the cleaning cassete will clean the dirty head.
May 18, 2007 | Sony Handycam DCR-TRV130 Digital Camcorder
Faber (272607) Kitchen Hood Logo
117 people viewed this question
Top Faber Kitchen Ranges Experts
Steve
Bill Boyd
dik stukkien
dik stukkien
Are you a Faber Kitchen Range Expert? Answer questions, earn points and help others
