Question about Inter-Tel ECX 1000 Telephone
Intertel phone system died
Our intertel phones went dead--unable to call out (no dial tone) and unable to receive calls. our other phone, also serviced by SWBell, works fine. any suggestions?
    Scholar:
  • 108 Answers
Look for power on the InterTel system, any kind of lights on the system is an indication you at least have power to the system. If you are plugged into a power strip and have no lights, remove the power cord from the strip and plug it directly into an AC outlet. Be sure to turn off the system before plugging it into a wall outlet, and then turn the system back on. Good Luck
Posted on Aug 05, 2008
Speed dial help
To set speed dial numbers,with the handset down press the SPDL key(the key should flash)
enter in the 1 digit memory location code (1-9)
enter in the telephone number (up to 32 digits)
then lift and replace the handset. You should hear a confirmation tone and the SPDL key will stop flashing
To use pick up the handset, access a line and press SPDL and the location code (1-9)
Dec 22, 2009 | Inter-Tel Intertel 6123300 GLX Executive...
Voice mail not working
When someone is calling my direct line, the phone never goes into my voicemail. How do I fix this?
Apr 17, 2009 | Inter-Tel Intertel Axxess 5204300 Basic...
Ip phone - cannot find IP address
the phone and the computer can not be the same IP Address will not work..
Jan 26, 2009 | Inter-Tel Intertel 6123300 GLX Executive...
Intertel GLX phone rings busy unless unplugged
You could have a bad phone try to swap it with a working one. If that does not work there could be a problem with the port in the system or cabling. Move to a new port or new cable
Jan 05, 2009 | Inter-Tel Intertel 6123300 GLX Executive...
Inter-tel 660.300 Intertel Premier 24 Button
Line could be dead from local provider (Verizon,etc.).Could be a bad port on the phone system. Maybe a bad connection into phone system. What Intertel system do you have?
Oct 16, 2008 | Inter-Tel 660.3000 Intertel Premier 24...
InterTel Axxess won't pick up the line when handset is raised
Try doing Special (sideways 8) 360 and make sure your display says Auto CO Access On. If it does not then do it again so that it will. Then try doing Special (sideways 8) 361 and make sure your display says Auto IC Access On. If it does not then do it again so that it will.
Oct 03, 2008 | Inter-Tel Axxess Corded Phone
CSU won't boot up
Problem is on its way to being solved. We called our vendor who contacted Intertel. Intertel is looking into problem. They have seen it before and are going to exchange the unit under warranty. Thanks for your response. Scott.
May 12, 2008 | Inter-Tel ECX 1000 Telephone
Interel voice mail rings
In System Timers change the System Forward Initiate timer. Be cautious that this is a system wide timer and will affect all users. If you want it done just on one phone it gets a little bit more complicated but it is still possible.
Oct 26, 2007 | Inter-Tel Axxess Corded Phone
Change Time and Names
On your Intertel Encore system you can program from a phone at extension 20. Intertel does not allow the sale of the manual to end-users (you) only Intertel dealers have access. I can help with the time change: From EXT 20 press the PROGRAM key, use the arrow keys to scroll until "System Programming" is displayed. It will ask for the password. The default is 1111, if it's been changed you may be in trouble... You would then select "System" then Select "Time and Date" - change the time (24 hour format) and date (MMDDYY) then hit the SPEAKER button to complete programming. I hope this helps. I have not done this myself, just passing on the instructions.
Jan 30, 2007 | Inter-Tel Encore 618.4001 Phone
Lands Phones Logo
305 people viewed this question
Top Inter-Tel Lands Phones Experts
David Burbee
David Burbee
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
