Question about Nikon S8100 Digital Camera
My Nikon s8100 suddenly stopped working. It will turn on, but the menu buttons won't respond. No error messages. No damage. No unusual sounds. The menu button will work until I hit the shutter button. Then, it doesn't record a picture, and everything freezes up. Any ideas??
    Champion:
  • 226 Answers
Hi , may be a trouble in control panel or damaged component in main PCB,contact Nikon service.
Regards
Posted on Mar 25, 2011
Nikon d40x suddenly stopped working- won't turn on- was working fine and when I connected it to laptop to download, it turned on , then suddenly went blank.
Do you get the 'push shutter button again' or 'turn off and on again ' message? If so the motor in the SQ unit that charges the shutter and moves the mirror up and down has failed. A very very common problem. The part is on constant back order at Nikon, and good luck getting it anyway as Nikon is going to stop selling parts to anyone in just a few weeks.
May 06, 2012 | Nikon D40x Digital Camera
Nikon coolpix s8100 lens error lens won't retract
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 07, 2011 | Nikon S8100 Digital Camera
My nikon s8100 won't turn on when I press the on button... but it will light up green when I plug it into the charger! help! :( I just got the camera!
It means it has a bad battery since it recognizes power using a different power source. Replace the battery and it should work fine.
May 10, 2011 | Nikon S8100 Digital Camera
Nikon s8100 lens error
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
May 09, 2011 | Nikon S8100 Digital Camera
S8100 won't turn on after being dropped.
Sounds pretty straight forward. The impact most likely damaged the camera. Take it in to a service center to be checked out.
Mar 18, 2011 | Nikon S8100 Digital Camera
Lens error. lens is currently retracted. will not open. nikon s8100 bought xmas 2010.
Had issue with lens stuck and not retracting on nikon s8100. first removed battery. then manually (gently) rotated lens counterclockwise until lens seated in fully retracted position. inserted battery, turned camera on and camera operational again. I suspect that root cause of lens jamming was turning off camera while simultaneously moving zoom lever
Mar 11, 2011 | Nikon S8100 Digital Camera
How can I stamp date on pictures using Nikon CoolPix S8100 camera
Press the MENU button. Select Setup (the wrench icon). Select "Date Imprint".
Dec 10, 2010 | Nikon S8100 Digital Camera
Error message
Your camera probably doesn't have a problem. Mount a lens on it and turn the aperture to the smallest opening = F/22 or F/32 then try it.
Nov 05, 2006 | Nikon F65 35mm SLR Camera
Nikon S8100 Digital Camera Logo
525 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
