Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
Hi i was woundering how much 2 stroke oil i put a letter of fuel to get 30.1
  • 784 Answers
100-130 ml oil for 5 L gas.
Posted on Mar 25, 2011
Does this engine require mix gas?
Peter
you are too short on details like make model , 2 stroke or 4 stroke
read your user manual or look on the petrol cap as most have the ratio on the bowser emblem
so for an answer, it is most likely a 2 stroke and so-- yes-- it will require a oil/fuel mix in the tank
if you do not know it , start with a ratio of 40:1 ( 40 fuel -1 oil) and only use 2 stroke oil not normal engine oil
run at rpms and there should be a trace of blue smoke
too much smoke cut the oil back to 50:1 and no smoke increase the oil to 30:1
go google and type in user manual for ( make and model ) --and the ratio will be in that print put
Aug 19, 2016 | Garden
How do i mix my 2 stroke for a makita chainsaw how many ml of oil to a litre of fuel
Mix the fuel and oil in a suitable container that is airtight with a secure stopper to ensure the fuel mixture has a long shelf life. Keep the funnel, spout, container, etc., dry and very clean. Storing it all in a large plastic bag serves very well for this purpose.
Any quality engine oil can be used but an oil of the recommended type and viscosity will produce much better results. Purists and traditionalists still like to use vegetable oil but this has a very short useful life and dubious results. Self mixing 2-stroke oils are best and synthetic-based oils are reckoned these days to be superior.
Put fuel in the container first and then add the correct quantity of oil for the number of litres of fuel, close the container and shake with vigour for a few seconds and then transfer the fuel to the tool.
The number of ml of oil to use per litre of fuel will vary depending on the engine type, manufacture and age. The fuel/oil ratio is often marked on the fuel tank or cap, 30:1, 40:1, 50:1, etc.. 50:1 would require 20ml of oil per litre.
Some 2-stroke oil bottles have a useful measuring scale on the side...
Aug 06, 2016 | Makita Garden
What kind of oil do I need to put in the crankcase?
No oil goes into the crank case as it is a 2 stroke. The oil is premixed in the fuel at a 30-1 ratio.
The gear box takes 10w-30 se oil.
May 25, 2015 | 2003 Yamaha YZ 125
What engine oil do I use in my sit on mower
Nah 2 strokes for mixed fuel use a 5w30 unless its like a toro grounds master then you use 90 weight but yea 5w30 is what you want. If you live in a colder climate use 10w30
Apr 16, 2015 | Garden
Should I use 2 stroke oil or synthetic 2 stroke oil
Synthetic oils claim to extend the shelf life of mixed fuel. If you are going to use the fuel within 30 days of mixing use regular 2 stroke oil.
May 22, 2014 | Weedeater Featherlite Blower 18 Cc 150 Mph...
What sroke is a masport 635. is it two or 4 stroke. it has an openping for the petrol and a seperate opening for the oil.
Judging from what discription you are giving me I would say it is a 4 stroke, so make sure you have either sae 30 or 10/w30 oil in crankcase where it says oil and petrol (gas) in the other tank. 2StrokeJim
Oct 27, 2011 | Garden
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 | Garden
WHERE DO DO YOU PUT THE 2 STROKE OIL MIX IN A SHERCO SM50
hi i dont know these bikes personally but,they will have a seperate tank for the two stroke oil,you will probably find it behind one of the side covers,do not put it directly into the fuel tank,that will cause all sorts of drama,as the oil(being heavier than the fuel)will sink straight to the bottom of the tank,fill the carb with oil,then you will never get it started,hope this helps...cheers
Apr 29, 2010 | 2007 Sherco 5.1i
Confused a little
A 4 stroke motor does NOT have Oil in the Fuel. There is NO fuel mixture. Just use regular gas. The only place you need oil is in the sump, and regular 20/30 motor oil will be fine.This only needs to be replaced when low on dipstick in crankcase.
Mar 08, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Cant find oil tank
most pedestrian mower engines do not have an oil tank,if it is a four stroke engine you will find a filler plu with level gauge either beside top of engine or near base,unscrew cap and fill to level on dipstick mark.
if it is a two stroke engine you will have to premix your fuel with a quality two stroke oil(most are either 25 parts fuel to 1 part oil or 50 parts fuel to 1 part oil(the fuel tank cap may have raised lettering telling you this),hope this is of help
Mar 24, 2009 | Garden
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
