Question about DT Swiss 240s Front Hub
My rear hub appears loose such that there is lateral play in the wheel - not much (maybe 3mm) but it reminded me of the problem I used to have with cup and cone hubs when they weren't adjusted and I was under the impression that this did not happen with sealed hubs. How do I fix it?
    Guru:
  • 347 Answers
Just the bearing is sealed, still needs to have the system held together and that system can loosen up. I would suggest taking the wheel into a shop that works on higher end components and have them adjust the hub for you, but if you want to do it yourself here is the manual. You may need some special tools depending on why the hub is loose. Could be anything from the cones just need to be reseated (tightened) which can be done with an allen wrench to a larger maintenance issue.
Posted on Mar 25, 2011
09 stang GT/CS conv. play in Rt.Rr wheel lugs r tight. I can move wheel and rotor in and out a lil bit. No grinding noise when wheel spins.
There may be a slight amount of end play in each rear wheel if rear wheel drive. This is normal axle end play with a solid axle. If the rear axles are CV joint type with a small differential, suspect a loose/worn wheel bearing/hub assembly
Jul 01, 2015 | Cars & Trucks
Rear wheel assembly of my bike is shaking side ways
Sounds like loose 'cones' in the rear wheel hub. The cones are cone-shaped nuts that the bearings run against, being held in place within the hub in the 'cup' of the hub. Tighten the cones until there is free rotation of the wheel with no lateral play. Hold the cone in place with the spanner whilst tightening the lock-nut and recheck the adjustment. If you lack the tools take it to your nearest independent local bike shop and they will surely be happy to help.
Aug 25, 2014 | Cycling
Kawasaki 2007 kx 250 rear wheel play
I was thinking wheel bearing but you state they were replaced, are they tight in the hub? if your spokes are tight, your hub would be tight and if wheel bearing are tight everything would be correct when the axle is tightened. Your swing arm is tight as well not loose in the bearing.
Jan 24, 2018 | Motorcycles
How do I remove rear left tyre from 2007 impala, it is sticking to the hub, and wondered ifthere was a trick to it
suggest kick tire on one side or the other,changed millions of those,apply wd40 on hub after removal @ maybe not so hard next time, but 1st are you sure all lug nuts off?
Aug 15, 2010 | 2009 Chevrolet Impala
How to replace rear wheel bearings
don't have topaz. maybe escort will help guide you.
Section 04-02: Suspension and Wheel Hubs, Rear 1996 Escort, Tracer Workshop Manual
REMOVAL AND INSTALLATION Wheel Bearing and Hub Assembly NOTE: Wheel bearings are not serviceable and should therefore be replaced as an assembly with the wheel hub (1104).
Removal
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
  1. Remove the hub grease cap (1131) from the wheel hub.
  1. If equipped with disc brakes, remove the rear disc brake caliper (2552) and rear disc brake rotor (2C026). Refer to Section 06-04 for the removal procedure.
  1. If equipped with drum brakes, remove the two brake drum screws and the brake drum (1126).
  1. Unstake the rear axle wheel hub retainer (4B477) securing the wheel hub to the rear wheel spindle (4A013). Remove and discard the rear axle wheel hub retainer.
  2. Remove the wheel hub from the rear wheel spindle.
Feb 06, 2010 | 1990 Mercury Topaz
My Piaggio Vespa 125cc rear wheel has slight play. What could this be?
no panic - this is typical for the old 2stroke Vespas as their gearbox is on the rear axle....(needs no belt like the newer ones)
-but then there is a certain amount of play needed...
Jan 14, 2010 | Peg Perego Vespa Scooter
How to change stud in rear wheel hub assembly. i need to know how to change the stud in the rear wheel hub assembly, and how do i go about taking it apart
Remove tire and wheel, remove caliper and brake rotor. DO NOT apply the brakes while the caliper is loose. Hit stud you want to replace hard with a LARGE HEAVY hammer to drive it out towards vehicle. DO NOT use a light hammer. It will distort the stud and possibly mushroom the end making it very difficult to remove. Once the stud is loose, you may or may not have enough room to get it out of the hole. You may need to pull the hub loose from the rear suspension to gain more room. Remove the stud. Place new stud in hole. Put a stack of washers over the stud, grease the threads, and using a new FLAT nut with the same threads as the lug nut, tighten until the stud is pulled all the way into the hub. Remove the flat nut, reattach the hub assembly (if you needed to take it loose) and reinstall the brakes.
Sep 28, 2009 | 1994 Ford Probe
Should there be play in rear dif of a 02 jeep i can pull rear wheels out about 3mm
No, there should be no play. check axle locks and spidergears for damage
Aug 23, 2009 | 2002 Jeep Liberty
98 Cavalier Makes loud vibrating noise
sounds like another bad hub brg, jack up front end and check for play in wheels from top to bottom wiggle for movement. A loose wheel brg will set a front speed sensor code.
Jul 30, 2009 | 1998 Chevrolet Cavalier
DT Swiss 240s Front Hub Logo
420 people viewed this question
Top DT Swiss Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a DT Swiss Cycling Expert? Answer questions, earn points and help others
