Question about Jensen VM9410 Car DVD Player
Pe-wee dvd codes
When i bypass the brake code it show numbers from 1to 9 did know what the number are for
I bought a dvd jensen Car Model VM9410. dvd does not read the original vine and written incorrect region code. How can I fix it? There a solution? Thanks antonello Italy. email: antonellopanzanelli@libero.it
Posted on Oct 08, 2008
I am looking for bypass code for a xdvdn8190 can you please help me.
Posted on Oct 04, 2008
How to change the v chip code to a mitsubishi medallion projection tv 62
Bypassing the V-Chip Lock on most Mitsubishi sets:
Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus.
If you don't have the passcode, it is easy to bypass. This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it.
To bypass the V-chip: You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your passcode is requested. This process temporarily unlocks the TV.
To reset the code: When you use the button combination 9 and QV while entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
Good luck, and let us know how you made out with this TV set.
Mar 20, 2010 | Televison & Video
Can't find Jensen UV10 e-brake bypass code.
Ok what you gotta do is connect the pink e-brake wire with the black wire that is already connected to the radio as the grounding.
UV10 Works 100%!!!!
Greetings from Montenegro
Jan 28, 2010 | Jensen Car Audio & Video
I want the code to play Zone 2 DVDs on my DVD which is set for 4
1) Turn on the player with no disc in the tray
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up (
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear. If the "no disc" does not disappear then try again by using the REPEAT button
6) Now type the code that applies for your region (R2 is 57538). A '2' will briefly show up at the top left corner
7) Now press 9, and 9 will show up in the top left corner
8) Power off the player, and turn it on again. You'll have a multi region player
I've found the following codes at the 1080P7 hack:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
This worked on my dvd1080p9 R2 DVD player
Oct 17, 2009 | Samsung DVD-1080P9 DVD Player
Code for bypassing park brake
I need the model number and I can get you that code .
Apr 25, 2009 | Jensen VM9510 Car DVD Player
Bypass brake code VM9311YTS
just connect the pink wire to the ground wire. some will tell you that a menu will pop up if so just input the numbers 5,4,3,2,1,0 make sure you hear a beep after every number. the menu will look like a hammer icon. im not sure if you have to input the code because i didnt need to
Apr 01, 2009 | Jensen VM9020TS Car DVD Player
Brake Bypass Code
I just spliced the brake wire into my cigarette lighter positive wire to provide the voltage necessary to bypass the parking brake requirement for video. Worked like a charm. It takes almost no voltage to bypass it. Even just licking your fingers and holding the bare wire allows video to show.
Sep 28, 2008 | Kenwood KVT-512 Car DVD Player
Regional code
1.- TURN ON THE DVD PLAYER
2.- PRESS OPEN/CLOSE
3.- PRESS THE FOLOWING NUMBERS 8888
4.- PRESS ENTER UNTIL SHOW "Region code: 9" (Region Free)
5.- PRESS OPEN/CLOSE
OR
1-Turn on your DVD player.
2-Open the tray.
3-Press 9 five times, you will see a number (for me it was 6, you'll see it on the screen, where the DVD displays all messages, like a blue bar up top) then I pressed 9 a few more time until the number being displayed there turned to a 9, when it does then press enter, now it's region free.
Mar 10, 2008 | GPX D2816 DVD Player
Bypass code
What you need is a video bypass module and you can get it at ebay.com
The module number is TR-7
Jan 26, 2008 | Car Audio & Video
Phase linear uv8=jensen brake bypass code
from remote setup, 5 4 3 2 1 0(hold "0" for 4 seconds) let go. look for the brake override option and turn it on.
Nov 16, 2007 | Televison & Video
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9410 Car DVD Player Logo
165 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Iron
Iron
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
