Question about Yahoo Messenger
Why i canot see the text in my dialog ym ??? - Yahoo Messenger
    President:
  • 2,185 Answers
Try uninstalling your existing yahoo messenger and install the latest version. If that does not work, try creating a new user on that computer and open yahoo messenger from there. If that works, then the user you have been using with that problem is corrupted and needs to be recreated.
Goodluck.
Posted on Mar 25, 2011
I have a scanned PDF document that I want to highlight and previously when the text wasn't recongnized it would ask to convert. At one point I checked the "do not ask again" box and now I am...
Basically Acrobat comes with a feature called as OCR (Optical Character Recognition) which helps acrobat in recognizing the text being used in a particular scanned document.
Just for the information, Acrobat 7 used to come with OCR accuracy of approximately 85% which has increased to 95% accuracy in the latest version of Acrobat (Acrobat X)
Now, in Acrobat 7, what you need to do is try running the OCR again on this document by following the steps mentioned below:
  • Open the document in Acrobat 7
  • Go to Document menu at the top
  • Click OCR text Recognition option under that menu
  • Then Recognize Text using OCR under that
  • This will open recognize text dialog box
  • Make sure All Pages option is selected in the new dialog box
  • Then click the edit button available in the same dialog box
  • This should open recognize text setting dialog box
  • Select Clearscan option in PDF Output Style drop down
  • Click Ok and then Ok again which should start the OCR on the open document
  • After OCR successfully completes try highlighting the text and see if you can do it
If you are still unable to do it, I would suggest you to download the trial version of Acrobat X from adobe.com which is a fully functional version which you can use for 30 days. After downloading this trial try opening the same document there and try running the OCR again and perform the highlighting of text again in Acrobat X itself.
If it still does not work please reply back with the results of the above mentioned steps and we can try performing some other workarounds to make the text recognizable.
Jun 01, 2011 | Computers & Internet
Tip
Rotating Text in Cells
In Excel, text of cells can be rotated to any direction or to a certain angle. It is called the orientation of the text. By default, orientation of text is horizontal.
To change the orientation of text, follow these steps.
  • Select cell or range of cells that contains data you want to rotate.
  • Select ”Cells” command from “Format” menu OR Press Ctrl+1, Format Cells dialog box appears.
  • Click Alignment tab of dialog box.
  • Specify angle in ”Degrees” spin box of orientation section.
  • Click “OK” button of dialog box.
on Jan 29, 2010 | Computers & Internet
Why my ym canot see the message in the dialog ?????? (ALL)????????
Could be text written in another language with a different set of characters and you don't have the appropriate language pack installed on your PC.
Mar 21, 2011 | Yahoo Messenger
Every time i log to yahoo messanger i canot read my emails.
first uninstall ym and then clean up ur system and its registry with reginout cleaner then reinstall it it will solve the issue
Oct 14, 2010 | Yahoo Messenger
Text box restriction
I hope this helps and thanks for rating my effort...any other questions...shoot em to me....The Fang.
Restricting character input You can use the SetInputTextType command to restrict the characters that the user can enter in the text input dialog box. For example, suppose an application contains an input text field for users to provide a numeric value, such as their age, and that the input text field has the variable name ageVar. To ensure that the user enters only numeric values in the text input dialog box, you could add the following code to your application:
fscommand2("SetInputTextType", "ageVar", "Numeric");
When users open the input text dialog box, they can enter only numeric values in the text fields.
For more information, see SetInputTextType in the fscommand2 function entry in the Flash Lite 2.x ActionScript Language Reference.
May 28, 2009 | Adobe Flash® CS3 Professional Full Version...
YM error 81003005/log-in ID, password invalid
I observed that this yahoo messenger comes with the network's (where you are connected at) firewall restrictions. There has got to be in between with your YM and the firewall. This problem is common when you belong to a proxy.
Secondly, if the firewall is the one not bugging you, it might be the DNS servers are causing the troubles. Sometimes, it seems the connection goes well only that DNS problems got in the way. This occurs rarely but if you can catch this problem, headache solve. The second solution discusses this.
Lastly, this has also got to do with the software part, that is the YM itself. As you can read in some of the comments below, other accounts work well and to some do not. If this is the case, then the connection (firewall) itself is not the problem but the software. Yahoo's advise is to update to its recent version of YM. Well, I did this but I was trapped with the same problem. My second solution works well for this kind of problem. Read on.
Solutions
[Solution #1]
Here's how I solve it:
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
My solution is good only if you have set your proxy server previously in your Internet Explorer. I've noticed this behaviour since in our school, I need to set the proxy server to access the internet. But at home, I don't need to. So when I am at home, this is the normal situation I encounter when I forget to unset back the proxy settings.
On the other hand, the other way around should work. What I mean here is, if you connect to a network that has a proxy server, you need to setup the proxy settings in order for you to use their internet services. Thus, access to yahoo could be established.
[Solution #2]
One area to look also if the proxy is not the one causing the problem, you can check if you have your DNS Server address(es) set, which - in case you have changed your network, can't be accessible to the new network. Thus, it can cause this error.
So, you may unset the DNS Servers (Go to Network Properties >> General Tab >> TCP/IP Properties >> General Tab > Obtain DNS Server address automatically) and try logging in your YM.
[Solution #3]
If the above solutions does not go well, this last one might be the savior. Instead of constantly banging your heads with those re-logins and reconfigurations, you can track back your YM version and replace it with an old version instead. I did this and it works for me well. I had before a version 9 Yahoo Messenger and when I replace it with a version 8, the problem was solved. This should be your last resort if the previous won't work. Remember also to be patient. If it bugs you, don't bug down... bug up!
Here's an old version of Yahoo Messenger (8.1.0.419.exe) - [Download]
Hope these helps.
Jan 29, 2009 | Yahoo YHT-630 System
Replying to text messages
Click the ok button and then left scroll to:
"Messaging" screen
Scroll down to "Sent"
"OK"
this will give you all the messages you sent
Jan 24, 2008 | Casio G''zOne Type S Cellular Phone
Yahoo Messenger Logo
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
