Question about LG Televison & Video
Where can I get replacement LCD, HD, Wide Screen, screen for a LG Philipps 23" TV? The number on the screen is LC230W01(A2) (KA) BAR CODE 230462KN43239. My screen has a larg crack in it. Thanks dad31255@yahoo.com
  • LG Master
  • 17,130 Answers
Ideally it is better that you get in touch with the LG service center close to your place to get the part and also the estimate. In most cases the cost of part which is from the service center will be inclusive of the service work and this makes it better to have the work done with warranty and better skill. I request you check this out.
Please check the link below for the LG support center., Please register and proceed
http://www.lg.com/us/support/product/support-product.jsp
Posted on Mar 25, 2011
  • 1,591 Answers
Http://www.lcdpanels.com/index.php?MenuLevel1=Item&SalesList=LCDPAN&ItemDisplay=NLC230W01&OEMFlag=0&gclid=CKuZtc6P6acCFRG4KgodMC9vaA
They have an 800 number and apparently the screen is in stock but there was no price on the page, so you'll have to call them or place the order online.
  • Norman Skinner
    Norman Skinner Mar 25, 2011
    You may wish to try the service center rout, but check the pricing.
    The place I recommended pretty much deals exclusively in flat panel products, and if I recall they have free FedEX delivery. Doing the work yourself may save you a lot of money.
My 55" lg tv that has 8" wide gray bar vertically that is smi see through? My ? Is what part do I need to buy to fix it.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 28, 2016 | LG 55lv4400 55 Inch 1080p 120hz Led Lcd Hd...
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
Acer all in one monitor has white bubbles
This type of behavior usually results from pushing on the screen too hard or "tapping" too hard.
The lcd screen in the device will need replaced to fix this issue.
Sep 06, 2014 | Acer AZ5610U9072 Allinone PC 23' Touch...
My LG HD tv screen has a wide, gray band on either side of the picture
Try changing 'perspective' or screen ratio.
This may work, but could also stretch the picture too wide,
On my non-LG TV this is called 'aspect ratio' under the 'picture' menu.
Nov 20, 2017 | LG 42LB1DRA 42 in. LCD Television
My monitor flickers erradically.
Flickering erratically is usually a sign that the fluorescent tubes that light up the LCD are failing, or the high voltage power controller that drives the tubes is failing. Although these can be replaced at some cost and a great deal of expense, it is usually not worth it with very nice, new & larger displays selling for less than $ 150 (23" HD wide screen moitors) from even the best brands such as Samsung, Planar, LG and Viewsonic.
Jan 11, 2011 | Mgc P700 17" Flat Panel LCD Monitor
LG HD 37 INCH TV GREEN LINE APPEARING ALONG THE BOTTOM
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
Feb 19, 2010 | LG 32LG30 32 in. LCD HDTV
LG RZ-23LZ40 no Picture
I would suggest to check the standby voltages as well. If the 5 volts are not present you will not get video or the TV will not operate properly.
May 23, 2008 | LG RZ-20LA70 20 in. LCD Television
Heads cut off and no score...
Try your setting on your cable box (Screen position)
also maybe wide mode try switching to wide zoom good luck
Dec 10, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
173 people viewed this question
