Question about Refrigerators
Just installed a new main control board on a Whirlpool GI5FVAXVL. and now it's displaying a PE0 000.
  • 132 Answers
It appears that the original fault was actually a sensor and not the board.
You will need to test the sensors to find which one is faulty.
If you use an ohm meter you will soon find the culprit
OL means open circuit
0.000 short circuit
300 to 700 ohms is ok
Posted on Mar 25, 2011
How do I fix my whirlpool duet washer that is showing a F20 code . We recently installed a new water softener, could there be residue or something from the old that is causing this?
F20 Control relay for motor controller faulty This fault code is only displayed on washing machines that have a CIM, BPM or Direct Drive motor fitted and an external motor control unit is used.
The main electronic control unit has failed to detect the relay that switches the motor control unit on and off has operated correctly. This relay is fitted on the main electronic controller and it is highly unlikely that there is an issue with the electronic board that controls the drive motor.
  • Check wiring and all connectors between the motor and main electronic control units
  • Replace main electronic control unit
Jul 20, 2016 | Whirlpool Washing Machines
My whirlpool refrigerator model # GI0FSAXVY011 is not working.
I found out the answer. I replaced the control board. I installed a new one. Now my refrigerator is working.
Jan 12, 2016 | Whirlpool Refrigerators
WHIRLPOOL SID BY SIDE FRIDGE MODEL GD5RHAXNT00 LIGHT HAS GONE OUT IN REFRIGERATOR AND TEMP GUAGE IS NOT SHOWING A READING
What youre experiencing is a common main control board failure.
The main control board for this model is no longer produced. But, don't scrap your refrigerator because new control boards are no longer available -- Save your appliance and high replacement costs and let us remanufacture the control board for you. This is a common control board failure that FixYourBoard.com can repair. We remanufacture the main control board in your model and back our work with an industry leading two year warranty. W10135090 Whirlpool ELECTRONIC CONTROL BOARD MAIN CIRCUIT BOARD
May 26, 2014 | Kenmore 57029 Side by Side Refrigerator
The temperature in refrigerator is coler than setting on the display why?
Before I begin is the model number=> GI5FVAXVL correct? If not I will need the correct model number to proceed. Thanks, John Tripp Appliance 911
Jan 29, 2014 | Whirlpool GI5FVAXVL (249 cu ft) Bottom...
WMG30GS Whirlpool microwave display
please follow this steps and fix it. God bless you
  1. Main control board If the display on your microwave has gone out completely this is usually a sign that it is a malfunctioned main control board. To correct the issue the main control board would need to be replaced.
  2. Display board A display board can either malfunction completely or partially, causing two separate results. If the display on the unit has completely gone out, this can be attributed to either a bad main control board or display board. On the other hand, if the display has only partially gone out, this is usually a sign that the display board is defective and will need to be replaced
Nov 27, 2013 | Microwave Ovens
My Whirlpool oven is displaying E2 -F1- and won't turn on. What do I do?
The fault code indicates that the control has failed. Erc/ clock main board.
Before replacing try unplugging for 1 minute then turn back on if code reappears you need to replace the main control board.
www.appliancehelponline.com
Apr 09, 2010 | Whirlpool Ovens
Whirlpool model: rf385pxdz My oven will not work, First It displays "door" then displays error code "EO F7"
Hi. This is a possible control board issue. First i would advise to check the wiring at the door switch mechanism, and control. Make sure the wires that link the control to the actual door latch assembly, are connected well, and are not lose. If the wires are Ok, and not corroded, simply replace the main control board.
Nov 03, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I have a 2004 whirlpool gold model #gd5rha. When
you need a new control board,this is very common,especially if the bulbs on thr refrige side blow out,this creates a surge and ruins the control board $85.00 w/shipping at appliance parts pros or 1-877-477-7278
Oct 06, 2009 | Whirlpool Refrigerators
No power, even though it is plugged in. The breaker box had no flipped fuses.
they can trip inside you can't see it so flip them on ...off fast and hard push off very hard to reset
Aug 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Refrigerators Logo
498 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
