Question about Canon 24-105mm f/4L IS USM EF Lens
Canon 5D Mk11 with 24-105 lens shows error on screen stating there is a communication issue between camera and lens. Cleaning the lens contacts did not resolve it. The same lens on a Canon 20D caused an ERROR 99 and camera shut down. Any ideas?
Error 99 is lens strip error...
you have to change strip inside the lens
Posted on Apr 06, 2011
  • 45 Answers
The lens is des connected or not properly attach to your camera if it wont work just go to the canon service center for appropriate check up
Posted on Mar 25, 2011
How to fix canon 5D mark 2 error #30?
On the 5D error code 30 appears to be shutter related and general advice is to get a professional repair or send it back to Canon.
Aug 04, 2014 | Canon EOS 5D Mark II Digital Camera with...
How to fix error 001 in canon lens
The Canon Err 01 is called Lens communication.
The lens has lost communication with the camera, or vice versa. This can be caused by dirt or grease on the gold coated contacts. On the lens or in the camera.
Try cleaning the contacts, with a dry cloth or cotton swabs. Don't use any sharp tools or force. To pinpoint where the error is, you could try to place another lens. If the error disappears most likely the first lens caused the problem. If the error stays, you should suspect the camera.
If you only have the problem with one lens, and the contacts are clean, contact a certified Canon repair centre.
Jul 10, 2014 | Cameras
Error code 80 + lock up functions
Still, when this error comes back, you should contact Canon.
On of the options hinting, you should use Canon lenses. So perhaps one of the contacts is a bit dirty?
Try cleaning all contacts in your camera, involved with lens and battery connection. Sometimes changing a lens can have a cleaning effect to. Most of the time not forever.
Success
Jan 20, 2014 | Canon EOS 5D Mark II Digital Camera
How to fix the communication error canon 1.8 50mm
Turn camera off, remove lens
Replace lens, turn camera on.
To help prevent it from happening again, you can try cleaning contacts on both camera and lens.
Aug 30, 2013 | Canon EF 50mm f/1.8 II Lens
Camera displaying error message
Have you tried cleaning the lens contacts, both on the back of the lens and in the mount on the camera body?
Jan 14, 2013 | Cameras
Error 01 in canon eos 5d
Err 01: Lens to body communication error
1.The camera to lens communication is somehow being interfered with could be a problem within the lens itself, possibly the camera body, or something as simple as a smudged fingerprint on the lens mount contacts,
2. Check the lens and the contacts
3. Also check below link if you need a canon eos 5d service manual
http://goo.gl/1rXwuc
thanks
Apr 26, 2012 | Canon EOS 40D Digital Camera
Hi error 01 on canon 5d mk 1. With brand new 70-200 2.8? Have read there is an issue on portrait shots but I am unable at this stage to be sure if it has only been an issue for landscape horizontal use or...
Error 01 is generally associated with camera unable to communicate with lens. Could be contacts need cleaned; since lens is new contacts on camera are more likely starting point for cleaning. But, common issue is failure of something in the lens, but that seems unlikely as it is new ... but it could happen. You might search for other Canon Error 01 comments/solutions. Failing a solution from that, time to contact SigmaUSA repair to have them inspect/repair under warranty.
Oct 03, 2010 | Sigma APO 70-200mm f/2.8 EX DG HSM Lens
Tamron 200-500mm lens on Canon 40D ... when I put the lens on the camera I received an error message stating that ''communication between the camera and lens is faulty, clean the contacts.'' All my other...
Try gently cleaning the electronic contacts on the lens's mount with an eraser. This will remove any mild oxidation on the contacts. If this doesn't resolve the problem, then contact Tamron and ask if there are any issues using this particular lens with a Canon 40D.
Apr 17, 2009 | Tamron Cameras
When I try to take a picture with my New Canon 450d/Sigma 70-300
check your card,change with new cf.That might fix problem i had the same issue and it was my card.
Mar 29, 2009 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Canon 24-105mm f/4L IS USM EF Lens Logo
510 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
