Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
When switching on our Rinnai 551F fan comes on for 20ceconds then goes off. Nothing happens. Where do you light these heaters. I think there is no pilot flame. Have tried nothing because the unit only has a heat control and a on/off knob that I can see. Thanks Teresa
  • kate Apr 28, 2013
    Hi, Did you find out the solution to this problem. Ours is doing the same thing. Thanks
  • Dani Power
    Dani Power Jan 23, 2017
    did u figure it out?? mines doing the same thing
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 113 Answers
Hi! Go here to see Rinnai 551F service manual http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/230.pdf. Also go here for additional information on your product http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/installations/230.pdf Thank you for using fixya! I hope I had helped you with your problem! May you have a good day!
Posted on Mar 25, 2011
Rinnai energysaver 551 ft starts but won't stay running
Those water heaters are very sensitive to flow rates. The service manual appears to be here: http://rdjxmmyvbu.blogcu.com/rinnai-551f-service-manual/13623970
But there is no guarantees
Jul 24, 2016 | Rinnai Heating & Cooling
Still looking for a surge absorber for a Rinnai energysaver 551F in Australia .Part Number DSA302M
If you have a part number you should be able to go to any plumber/gas fitter and ask them to order it through Reece/Tradelink etc.
Try ringing Rinnai direct, parts and sales is on 1300 555 545, ask for the nearest stockist.
Most Rinnai spare parts are a number begining with 9 for Australia. The code you have sounds like a Rinnai Japan part number. Might cause confusion if you try and order it.
Try this link to a 551 service manual. It has a parts list and expolded diagram. Don't worry that it's a pommy site. The heaters are the same.
http://www.rinnaiuk.com/5_Downloads/5_Warm_Air_Heater_Downloads_PDFs/05_Rinnai_551FTR_Service_Manual.pdf
Aug 18, 2010 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Looking for A circuit board to suit rinnai space heater rhfe-551f which is 20 years old
I would call Rinnai and have them tell you who's the contactor in your area......they'll hook you right up I'm sure. If not email me at scook143@yahoo.com I will sell you a board.
Jun 15, 2010 | Heating & Cooling
Can you vent the Rinnai 551F vertically through ceiling?
This unit can be vented through the roof but requires a specialized flue system-do not use an existing flue connection. Call a contractor - have them check and see if the unit can be modified to a vertical flue- it will require the existing piping to be replaced--Not a job for a do-it yourselfer
Nov 01, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Has been off all summer is there such a thing as a reset switch to fire it up as nothing is happenning
Check the plug and make sure the outlet is not turned off by a light switch. Check the outlet with another devise to make sure it has power to it. There is a fuse inside the Rinnai either on the control board or in the wiring. It is a 250 volt 3 amp glass fuse. Check that.
Oct 14, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Won't turn on or up
If there is a 'lock' button on the heater, push and hold till the green light goes out.
otherwise www.rinnai.co.nz - tradesmart, energysavers.
May 28, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai heater turns itself off
Dannizen,
You could have something as simple as an air hose off, or a piece of carbon on the flame sensor. Your problem could also be a gas valve , which is much more complicated. If you are handy with tools you could be able fix either quickly. If you’re not good with tools you will need to get some help. Either way you have to have some back ground info on your heater. Get in touch with Rinnai and get a service manual for your unit. They cost around $15. If you have to call a service guy, use the Rinnai web site to find an authorized service person. Don’t just let your fingers do the walking and get some guy who has no idea what a Rinnai is. You’re only asking for trouble there. Your unit is a little older so don’t be surprised if parts are hard to find.
Good luck,
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Mar 04, 2009 | Rinnai RHFE-556FAIII 21,500 BTU Ductless...
Users manual for a rinnai 551f heater
Here is the owner manual : Rinnai wp
And here also an extra, the service repair manual:
Untitled
With compliments.
Nov 30, 2008 | Rinnai Heating & Cooling
Squealing Noise coming from DeLonghi TRD0715T Oil Filled Heater
does the noise occur when its doing its purge cycle? I mean as soon as you turn it on and set your temperature?
Jan 24, 2008 | Rinnai Toyostove Direct Vent Heater:...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
426 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
