No graphic card - Computers & Internet
    Sergeant:
  • 296 Answers
Buy one.
Posted on Mar 25, 2011
Where is my graphics card
Laptops usually don't have a separate graphics card (unless they are very new or very high end). They have a graphics chip that is part of the motherboard.
..In other words: you can't replace them or fix them if something is broken.
Apr 06, 2012 | Acer Computers & Internet
What video card are compatable with SR1620NX ? The graphics card is not working right anymore and I need a compatable video card.
A PCI Express graphics card.
Doesn't matter if the PCI Express graphics card uses the PCI Express 2.0 technology, or the PCI Express 2.1 technology.
The PCI Express graphics card, will insert into the PCI Express x16 expansion slot on the motherboard.
Supporting data;
1) View of the motherboard in an illustration,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00378480&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=1127351
Scroll down the page to view the motherboard illustration.
A) Looking at the illustration, view the BATT. (CMOS Battery)
To the left of the CMOS Battery (BATT) are three white PCI slots.
Above them is a longer expansion slot. This is the PCI Express x16 slot.
Above it is marked > PCIX16X1 (PCI x16 times 1 slot)
NOTE* When installing the PCI Express graphics card, lift up gently on the Lock 'handle'.
It looks as though you should push down on it, but you need to lift up on it instead.
Also go above the motherboard illustration, and read to the right of the heading > Internal Connectors
In the list you will see > One PCI Express x16 graphics slot.
WHEN installing a graphics card, ALWAYS install the software from the CD disk provided, First!
Computer on, and Windows running, insert the graphics card's Installation disk, (CD) into the optical drive tray.
Install the software by following the directions.
THEN shut the computer down normally, and unplug the computer from power.
OBSERVE Anti-Static Precautions.
Install the graphics card.
Close the computer case, and plug the monitor into the graphics card.
Turn the computer on.
When you install a device (Such as a graphics card for example), Windows will try to find compatible drivers.
IF, THE driver is not installed First, Windows will match up one of it's thousands of generic drivers.
This = No.
You want THE driver installed first, so that Windows will find it, and Not try to match on of it's generic drivers.
NOTE 2*
It DOESN'T MATTER what graphics ram memory the graphics card has.
The graphics card's Processor and Ram Memory operates independent of the system resources.
Example:
The computer uses DDR Sdram ram memory.
The graphics card uses GDDR5 graphics ram memory.
It will work just fine.
NOTE 3*
It does NOT matter if your computer uses the PCI Express 1.1 technology, and the graphics card uses the PCI Express 2.0, or 2.1 technology.
PCI Express 2.0, and 2.1 technology is Backward Compatible with PCI Express 1.1 technology.
Will you get the full capability of the PCI Express 2.0, or 2.1 graphics card?
NO
Will you notice?
NO
What you need to look at it, is how much power will the graphics card use. Look at the system requirements for the graphics card, and be sure your Power Supply has enough power for that graphics card.
Also, IF, the graphics card requires additional power cables from the Power Supply, make sure your Power Supply has the required power cable, or power cables.
IF the Power Supply does not, use a power adapter cable.
NOTE 4*
Graphics card manufacturer's base the power needed for the graphics card, Not just on the graphics card itself, but on an entire computer system, AND the graphics card.
The graphics card manufacturers use a test computer system, that is a powerful computer system.
Gamer motherboard, Dual Core, or Quad Core processor, 4GB of ram memory, and at least two harddrives, and two optical drives, PLUS the graphics card in question.
This complete computer system uses a LOT more power than just the graphics card by itself.
There isn't a single graphics card out there, that uses more than 150 Watts by itself.
Recommendations for a graphics card that is compatible, with a Compaq Presario SR1620nx desktop computer?
Budget to medium:
Good enough to watch videos, older games, and some newer games.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4675217&CatId=3670
Medium:
Higher level games, and large screen monitors,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6642574&CatId=3669
For questions post in a Comment.
Regards,
joecoolvette
Dec 18, 2010 | HP Compaq Presario SR1620NX...
I have a dell dimension 4400 and the original graphics card thats came with it but yesterday i when too turn on my computer and the screen is not picking up and image from the CPU is there anything i can...
OK, I am curious how are you going to install a new graphics card without installing a new graphics card? "picking up and image from the CPU is there anything i can do to install a new PCI graphics card with out having too install the new graphics card"
You can install a different graphics card in the computer assuming you have an open expansion slot. If the Current Graphics card is actually installed in the AGP slot open the Main CPU unit and remove it then install the new card. If when you started the computer you saw anything on the screen, the DELL logo or Bios setup, the problem most likely is not the graphics card being bad but possibly that the settings in windows some how changed and it is set to something it can't support or the monitor has gone out. If it is the graphics card and it is built onto the motherboard you will have to install the new card and when the computer starts enter the Bios to change the BIOS settings to disable the on board card or it will give you problems with conflicting resources. Most graphics cards use the same resources so two cards in the same computer will conflict with each other and neither will work. I would test with a different monitor before replacing the graphics card.
Dec 13, 2010 | Dell GeForce2 MX, (32 MB) Graphic Card
Was wondering if it can be replaced with a better graphics card
This depends, mspolar1.
Depends on;
1) If it's a Desktop computer, or a Laptop computer.
Desktop computers may, or may not, come with Integrated Graphics.
For those desktop computers that do Not, a graphics adapter card is used.
(Graphics adapter card is also referred to as a Graphics Card, or Video Card)
Desktop computers that Do come with Integrated Graphics, will also have a graphics expansion slot to install a graphics card in.
2) Laptops generally just have Integrated Graphics, BUT there are some models that Do have a Graphics Card, and there is the possibility of upgrading to a better one.
The above relates directly to Toshiba desktop computers, and laptops, as well as a reference to all desktop, and laptop computers.
To explain Integrated Graphics:
Another name for Integrated Graphics is OnBoard Graphics.
ON the motherBOARD.
The graphics chip is soldered directly to the motherboard.
[ Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
A graphics chip has a GPU on it,
http://en.wikipedia.org/wiki/GPU ]
Integrated Graphics borrows some of the system's resources.
The Processor and Ram Memory.
The Processor and Ram Memory are trying to take care of the Operating System, and the program that is being ran.
Two Operating System examples are Windows XP, and Windows 7. An example of a program that may be borrowing system resources heavily, is a game.
If an intense game is being played, the system resources cannot keep up with the demand for graphics, when Integrated Graphics is installed.
(Slow frame rates, or freezing. Poor graphics. Even with low settings)
A dedicated graphics card borrows very little of the system resources, or none at all.
A graphics card has it's own Processor, and Ram Memory.
(GPU and graphics ram memory)
In direct reference to Toshiba laptop's, post the laptop Model Number to see if the graphics can be upgraded.
There are some Toshiba laptops where this is possible, and some that are not.
(Post in a Comment)
The one's that use Integrated Graphics, and no dedicated graphics card, are the ones that cannot be upgraded.
Oct 29, 2010 | Toshiba Computers & Internet
ATI Radeon 9550
To find the latest drivers for your ATI card, use this link I have provided
to find more info about driver updating and graphic card drivers.
make sure you download the right driver for your graphic card(graphic card name) and also download the right catalyst control center to take full advantage from your graphic card.
Good Luck.
May 25, 2009 | ATI RADEON 9550 Graphic Card
I have installed a game that needs graphic card software
NEW TO GOTO PROPERTIES OR CHANGE RESILLUTION OR GRAPHIC CARD SETTING
MY GRAPHICS CARD HAS SETINGS FOR CERTAIN GAME TO MAKE THE SYSTEM GRAPHIC BETTER AND LOADS SPECAIL DRIVES FOR THAT GAME ONLY ORDERED BY THE GAME MANUFACTURE SETTING TO GIVE YOU THE BEST PERFORMANCE FOR THAT VEDIO CARD IF NOT
GO OT WEB SITE LISTED BELOW
TYPE MANUFACTURE NAME IN ADDRESS BAR AND ENTERKEY
DRIVERS
Jan 28, 2009 | 3dfx Voodoo4 4500 (32 MB) Graphic Card
Search drivers for graphic card the mother is ms-6541
  • The Following link [below] is from www.Diamondmm.com (The Product Supplier for this Graphics Card)
Here is the Link to The Driver For BV200 BizView 128mb Graphics Card
This Driver Version Supports the Following Operating Systems:
  • Windows XP
  • Windows 2000
I Hope This Helps.
Oct 28, 2008 | Graphics BV200 BizView 128MB (128 MB) PCI...
Dedicated graphics card
nopes..with intel media accelerator u cant upgrade to a 128 mb graphics card or whatever higher memory cards for that matter..there is a studio 15 laptop with 256 mb ati graphics..probably u should hav got that..
Oct 17, 2008 | Acer AOpen MX 400-A (32 MB) Graphic Card
Graphics card on laptop
dear friend in laptops it is not possible to change or put a graphics card u could had thought a bit before buying
Sep 08, 2008 | XFX GeForce 6200TC Graphic Card
Trident graphics card
your graphics card need drivers as you computer is only running on basic video what is the card name and number please
Aug 01, 2008 | Trident BLADE T64, (32 MB) PCI Graphic...
Computers & Internet Logo
David Payne
David Payne
