My 32" RCA model #
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 25, 2011
I have a RCA model F32672sb chas.number CTC187cl3 that the picture has a hour glass display meaning the two sides are shrunk in.Everything else seems ok.
From your description you probably have a horizontal sweep circuit problem. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 13, 2009 | RCA F32672SB 32" TV
My tv keeps turning on and off
You might have a timer set.
Jul 05, 2009 | RCA F32672SB 32" TV
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
How do i get to the input/video screen on the RCA F32672sb 32
If you have an old vcr hook the dvd player to the inputs on back of the vcr (RCA jacks) Run a coax cable from the "out" on the vcr to the back of tv. Turn the tv on channel 4 or 3 then put a tape in the vcr and push record then pause it. Or if the vcr has a tv/video button you can push or activate it and it should allow the dvd to play through to the tv.
Feb 10, 2009 | RCA F32672SB 32" TV
Rca 32'' tv
If you are a technician you can solve the problem if not you need send the device to a repair center,the problem are a coil between the pins of the horizontal output transistor maybe get solder joints cracked you need to resoldered .
Aug 17, 2008 | RCA F32672SB 32" TV
RCA 32" wont turn on
It sounds like you may have a bad Horizontal Output Transistor (HOT) and/or a bad Flyback Transformer. The set is trying to start as indicated by the flashing light, but an internal fault is shutting it down right away. It could also be the Power Supply circuit. A 32in. set is not cheap to replace so it may be worth finding a repair technitian and at least getting a quote. The Flyback is the most expensive part, the others are minimal. If it is one of the above problems it could easily be repaired by a qualified technitian.
Mar 11, 2008 | RCA F32650 32" TV
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
Rca tv model # F32672SB
The fuse is a 5 amp,can get at any electronics store
Jan 09, 2008 | RCA F32672SB 32" TV
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
Crashing sound on Protron 32 TV
no sound, everything was working fine the night before. woke up the next morning, and turned the tv on, and there was no sound at all. nothing from the TV, DVD, and nothing from the Computer. Please help. curtisw_1999@yahoo.com.
Dec 26, 2007 | Protron PLTV-32 Television
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
