Question about Ricoh Aficio 2035 Copier
The copier produce black strip output - Ricoh Aficio 2035 Copier
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
Look my friend this proplem happend some times put whit paper on paper yo want to copy and print yo woud'nt see any black strip
Posted on Mar 25, 2011
Ep 1030/1031F gets black strip down side of paper about an inch wide
Odds are you need a new drum cleaning blade. The only problem is trying to find parts for the copier. Good Luck
Mar 31, 2013 | Minolta EP1030/1030F CS/PRO Copier
Machine status P-9 what is this message?
Black Imaging Unit failure
• All density readings taken from the density pattern produced
on the Transfer Belt are 0.5 g/m2 (IDC Sensor
photoreceiver output) or less during max. density
adjustment (Vg/Vdc adjustment).
on the Transfer Belt are 4.5 g/m2 (IDC Sensor
Photoreceiver output) or more during max. density
adjustment (Vg/Vdc adjustment.)
Remove and reset the Black Image Unit. If this doesn't help the Image Unit may need to be replaced.
May 25, 2010 | Konica Minolta bizhub C250 All-In-One...
Copier NP6216 produces thick dark strips
Hello sir; I suggest you either replace drum blade or replace whole drum cartridge.
Aug 20, 2009 | Canon Office Equipment & Supplies
Ink cartridge running low will it default small cartridge
It won't default to the small one...I emailed Canon support; this is the response I got.
The reason for the two different black ink tanks is for the different types of printing your unit is capable of. They are not intended as backups to each other. The larger black tank is pigment based, and is primarily used for standard black text printing or output. The smaller black ink tank is dye based like the color inks, and is used for photo and graphics output. They are designed to complement each other, allowing the printer to produce the best possible black text output or photo quality as appropriate.
Feb 25, 2009 | Canon PIXMA MP610 InkJet Printer
All copies and scanner outputs result in a totally black image
hi,
its could be hardware issue, if you tell me which printer, then we can try some reset on that machine..........
Regards,  raj_p5983
Jan 23, 2009 | HP PhotoSmart C4180 All-in-One Color...
Not photocopying
Open side, look at black assembly on the door, there is either a black spongy roller there or two wires in a black assembly,
1- wires may be broken resulting in blank copies
2- roller out of place
3- HVT (high voltage transformer) not working
Jun 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Print is obliterated with 4 broad hoziontal strips on paper
The green roller is the OPC drum, and as with many panasonic laser printers the cleaning mechanism doesn't work properly. The only way to solve this is to replace the unit.
Jun 19, 2008 | Panasonic KX-P6500 Laser Printer
HP CM1015 copy/scan problem
DO THIS CHECK WHERE THE CATRIDGES IS IN ORDER.OR IF IT IS LEAKING
Jan 17, 2008 | HP LaserJet CM1015 All-In-One Printer
Ricoh Aficio 2035 Copier Logo
53 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
