Hi there, i have a fujitsu laptop n series. The battery will not charge, so I purchased a new one... same problem. With the ac adapter plug it will (most of the time) turn on, however as soon as I put the battery in the battery indicator lights are turn red. If I unplug the ac adapter the computer will stay on for a few minutes then loses charge. Thanks for your help
  • Jennifer Mogan
    Jennifer Mogan Mar 25, 2011
    When I plug in the power adapter, the battery light flashes orange. I plugged in the power adapter & turned it on... There is a green power (I think) indicator light & two flashing battery lights flashing back and forth between each other, orange & red. There is another light (upright cylinder looking) green and sporadicly flashing.
    When I jiggle the cord the cylinder green light reacts by flashing more rapidly or diapering or stays solid.
    So, how difficult is it to dismantle my putter and figure out what's wrong?
    Thanks for helping me out,
  • Jennifer Mogan
    Hi Geekman,
  • 32,281 Answers
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's power socketcould be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Posted on Mar 25, 2011
Fujitsu lifebook blinking battery led, bad ac adapter?
i would try purchasing a universal laptop charger on ebay and see if it works. they are under 25 bux. worse case scenario you will have a backup ac adapter. be careful plugging in other ac adapters because the polarity could be wrong or it could have to much amps
Jul 11, 2010 | Fujitsu LifeBook A6025 Notebook
New AC Adapter Will Not Charge Battery/Operate Computer
Most probably static electricity killed some circuitry inside your laptop.
Nov 12, 2009 | Acer Aspire 3610 Notebook
Fujitsu esprimo mobile only charges when it is on
No that not normal.
Turn the laptop off and remove the AC power and then the battery. Plug in AC power only and start the laptop, let it boot into the operating system and then turn it back off.
Remove AC power and reinsert the battery, then plug in AC power again and look for the charge indicator LED light on the front of the laptop.
If the light comes on then it's charging.
If it doesn't then there is a problem with the laptop.
I would recommend giving Fujitsu a call as their customer service is excellent.
Good luck.
Sep 16, 2009 | Fujitsu Siemens Computers & Internet
Battery not getting charged-power supply on ac power
hi thanks for using fixya!!
Is your laptop is brand new? Try to remove the battery. Then, try using your laptop and AC adapter without the battery, you will get the power supply directily from AC adapter. If it works properly, then its okay. Now, try to install back your battery then try to charge it. If not charging, perhaps you need to buy a new battery. However, I suggest you bring your laptop to a service technician to further check the error, before you purchase a new battery.
If you need further assistance, let me know!
May 25, 2009 | Computers & Internet
Battery is not charging
when you first purchased your laptop did you plug in your adapter to give your battery a full charge? If not then try a new battery when buying something like that always charge at least 12 hours before play.
Jan 08, 2009 | KDS Datamation Systems DS-8BY-BC-820...
Toshiba Satellite A55-S306
Sounds like you have snapped the centre connector in the laptop. If you look at the AC connector on the laptop there should b a "pin" in the centre. These frequently snap off, symtoms are :
Battery will not charge
Will not turn on from AC supply.
There are some firm which will replace the ac jack for you but it will cost.
Interent search .. replace DC jack on toshiba
Sep 05, 2008 | Toshiba Satellite A55-S306 Notebook
Charging Fujitsu Siemens D7830
Have you ever replaced your AC Adapter, if yes than replace AC Adapter with an OEM....
Jul 22, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Laptop / AC Adapter Problem
It maybe the problem of your laptop ac adapter,find a new universal laptop ac adapter to have a try.
Sep 14, 2005 | Fujitsu Siemens Loox 710 Pocket PC
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
