Question about Air Tools & Compressors
My motor is:Part.Num.6-348524-04,FR:F215T 7.5HP 230volts 1P;What means Type CP and Code H ?
    President:
  • 1,388 Answers
In the US, the motor industry has worked on a standardized basis for labeling the potential performance/ characteristics of a motor. I have noticed at our repair business that Imported motors, depending on country of origin, have many different designations. For example, the stock number that you list includes a (fr:) reference. In the US, this would be listed as (FR frame, or frame type) which refers to various external components of the motor relating to mounting etc.. Code could/usually refers to insulation class of windings relating to highest temperature the motor can endure. Codes for temp are (B,F,H) and others. (Types) of motors usually indicate/ relate to torque-speed curves, rpm, capacitor start, capacitor start and capacitor run etc. Unfortunately I could not find reference to your motor, however, you can probably guess at the capacity of your motor by the application. ex. motor to turn a large fan vs a motor with high start torque requirements for air compressor (inforation needed if you were going to replace a burned motor). More information can be found by reading about "NEMA and IEC standards for motors" Good luck.
Standard for Motors
torque-speed curves for motors with NEMA Design A, B, C, and D characteristics.
Posted on Mar 25, 2011
What do you mean by fr error code in window type aircon
freeze error make sure freeze sensor in coil
Jun 10, 2018 | Heating & Cooling
How to work key pad
Key pad? Do you mean the keyboard or what?
Mar 21, 2016 | Dell Inspiron 1525 Notebook
Trouble 3 hp motor
What kind of problems are you having with this motor?
Rod
US Parts Center
May 03, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
Split AC system not cooling.
P-7 Error Code means: DC Voltage Problem in the outdoor unit.
Bad PFC & IPM Circuit Boards.
The Pridiom Group
201-266-8234
Jul 26, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
Electric dryer won't heat. Continuity is good on
Make sure that you have 230volts at your receptacle. Most dryers will run the motor and controls off of one leg of your 230volt outlet or 120 volts but require 230volts to operate the heating element. As a previous service man I can't tell you how many times people called on a dryer problem when the problem was in a breaker.
Jul 03, 2010 | Dryers
How many parts in transformer & briefly explained
Firstly - DANGER.Power can kill so be very careful.
These can be made of a couple of parts but are sold as one peice.Check your manufacter for more info.
How Magnetic Iron Core Transformers work........
the transformer has a pair laminated wires normally copper or iron core wrapped around in a tight coil called windings.they are independant circuits not electrically connected together(x2 wires = 2 Circuits)
this creates a magnetic effect when power is applied to one end and mutual inductance creates a power output at the other end.Like a magnet really.
There are some transformers that have a multi voltage outputs called TAPS which will have different voltages to the input voltages.
ie
Input in New Zealand can be 230volts
Output can be 12 volts or 5 volts or 230volts
depending on the applications required,
for example
Street Transfomers can be 11,000 volts INPUT stepping down to 230volts.OUTPUT for your household power
or
Garden lighting transformers output can be 12volts but still be 230volts input
or
computers power packs can be multi voltage outputs of 12 volts,9 volts,5volts but still 230volts input.
There are also Electronic Transformers available too.
Commonly used for dichrioc Halogen downlights in homes or the office,
Apr 26, 2010 | Sunbeam Transformer (ICTRBA) ATX Full...
Hello I have a hotpoint tcp 1p tumble dryer
this sounds like the thermostats
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Dec 20, 2009 | Hotpoint Dryers
Dayton blower wiring instructions
Look at the name plate on the motor. If it's 'duel voltage' it will show a 'high' and 'low' voltage hook up. If it only shows one hook up config, then use the rated voltage on the name plate. If 240 volts, use L1 and L2 for incoming power @ 240volts.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 30, 2009 | Dayton Psc Blower 960CFM. 1030RPM...
N73 unlocking
u try to switch off the mob and take the battery and sim.after some time u put all and see it may work. r other wise try the following web sites.......
http://www.simplemobilephones.com/
http://www.wirelessunlocks.co.uk/?gclid=CLGf8v6v7pICFRyrbwodI0l95w
http://www.gsmok.com/index.php?mod=shop&tree=038&gclid=CP-mg5Ww7pICFRspbwodViG_4w
http://www.mobile2mobile.net/unlock/RemoteunlockingMotorola.htm?gclid=CO60i7Kw7pICFQvWbgodCyUK3w
did my solution is helpful for u... yes means post ur ratings to me....
Jun 06, 2008 | Nokia N73 Cellular Phone
Air Tools & Compressors Logo
95 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
