Question about Olevia LT37HV 37 in. HD-Ready LCD Television
The blue power light is on. When i use my remote either the one that came with the tv or mt satilite remote to power on the tv. The blue light stays on, and nothing happens. It appeares to be stuck in stand by mode. My model is a 237 -t12 hd ready
  • 1 more comment
  • mdorrym Mar 27, 2011
    Thanks;
    The remote works with a differant Tv. So I don't think that is it. It is out of warrenty. I have seen other comments about Olevia's bad power supply board?
    I have a olevia 237 T-12 TV. The blue stand by lite is always on. The TV won't work, with the controler or by manual use of front panel. The satilitte remote does not effect the TV. I have tried unplugging it for 3 hrs and have turned it back on as asked by the help people at Olevia.
    Thank you. It seems that a lot of experts have been saying the same thing.Can I just buy the replacements boards or moduals?
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, please read to the end, and watch the videos !
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with similar issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
the girl in video 3 had never even soldered before and was able to do this repair!
Posted on Mar 27, 2011
  • Norman Skinner
    Norman Skinner Mar 28, 2011
    Being a non-big-brand, getting complete boards for this would probably have to come direct from the manufacturer and that could take quite some time - I'd really try fixing this one yourself first.
    Genius:
  • 1,622 Answers
Hi, to be sure that the TV is on stand by mode you will need to operate the TV direct from the TV itself. To know if the remotes are still working or not..
After testing that if it doesn't function at all, that means the TV is experiencing Power problem...
You will need to contact your local repair man to checkit out for you..
Or if the TV is still on guanrantee, you couldd simplytake it back to where you purchase it from and they will fix it for free or replace it with another TV
Take care..
Posted on Mar 25, 2011
My samsung tv say on mute and can't go to unmetered?
It could be a stuck button on the remote.
Try this:
Turn off TV.
Turn on at the TV, not the remote (push screen just above the Blue Light thing at the bottom if no Power button is displayed). If you have sound it was the remote.
Clean the remote of any sticky stuff with compressed air or very lightly with alcohol. Do not use WD-40, it will stick again.
Good luck. Please rate this answer 4 stars if helpful.
Sep 10, 2017 | Samsung Computers & Internet
Why won't my 32" Goodmans TV power up?
There could be an open fuse internally or the power supply may have failed.
Apr 25, 2015 | Goodmans Televison & Video
Light on bottom just stay red
I have a new power supply and my light stay solid red on my LG tv. Has anyone experienced this. I ordered the power supply from Sears. Someone please help a brother.
Nov 20, 2014 | LG 32LD550 32 in. LCD HDTV
WHY DOES THE BLUE LIGHT IN THE FRONT OF TV STAY ON AFTER TV IS OFF
It is normal. This is the STANDBY light. It shows that the power cord is plugged in and there is power being supplied to the tv. This is necessary to operate the remote control circuit so that you can turn it back on with the remote.
Post back if this was helpful.
Jan 25, 2011 | Samsung HL-T5076S 50 in. TV
FORGOT HOW TO SET MT REMOTE FOR MY ORION TV
Turn on TV,press and hold the CODE SEARCH button until the light on the remote lights up,press the TV button, the light will blink,enter the code,0236,or 0463,the light will go off,press POWER button, the TV should go off, if not, repeat the steps using a different code until you get the one that works. ..hope this helps..
Mar 29, 2010 | One For All URC4220 Remote Control
My tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Apr 07, 2009 | JVC LT-42X579 42 in. LCD TV
Connecting mt digital converter box
Antena will go into converter box input then out of the converter box output into the satilite boxes antena input then out to tv!
Please rate this response and help keep this area FREE!
Thank You!
Jan 22, 2009 | Televison & Video
Re; won't turn on
press the tv/video button until you see something. I hope that helps, another thing is check if its on Satilite or regular TV.
Aug 26, 2007 | Jensen TS2750J TV
Olevia LT37HV 37 in. HD-Ready LCD Television Logo
232 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
