Question about Vizio L32 32 in. LCD HDTV
Black screen - Vizio L32 32 in. LCD HDTV
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both - in your case it's most likely the inverter board.
First check for fusible links on the inverter. They may be tiny white rectangular boxes, flat and green or they may be flat black 0 ohm resistors (will have a 0 printed on the surface)
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 25, 2011
Screen blank on x836 turns on screen blacksout help thanks
Black Screen, Working Phone [Solved] - Phones - Cell Phone General ...
www.tomsguide.com/forum/id.../black-screen-working-phone.html
Dec 14, 2015 - 12 posts - ‎10 authors
I turn my phone off and then turn it back on, same result, black screen. I then tookout the battery and put it back in, same result. I took the battery ...
Why is my screen black but everything else works ... - iFixit
https://www.ifixit.com/.../Why+is+my+screen+black+but+everythin...
iFixitThe Samsung Galaxy S3 is a multi-touch, slate-format smartphone with ... I have a problem with my phone i dropped it and it works but all i see is a black screen ! ... was fine but then a couple of mins. later the screen started turning pink and when I .... i dropped my gs3, the screen cracked & the screen stays black, everythimg ...
Phone stuck on a black screen during or after a call? Here's ...
www.smartmobilephonesolutions.com/.../cell-phone-shows-a-black-scree...
Is your phone showing a black screen after finishing a conversation and not allowing ... causes and better yet some solutions to fix this issue on your cell phone. ... phone up to your ear, so that the phone will lock (turns on the black screen), ...
Jan 04, 2016 | Cell Phones
Why does screen go black or white by itself?
There are 3 step to repair black screen error
If you got black screen error then there is a 94% chance that your computer has registry problems. To repair black screen error you need to follow the steps below:
* Step 1 - Download a black screen error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair black screen error.
Here are the url of black screen error repair tool:http://www.FixError2010.com/ttfix-black_... Source(s): http://www.FixError2010.com/ttfix-black_...
Sep 22, 2015 | Computers & Internet
Its the problem with microsoft grenuine license file a black screen appears on thge desktop screen
video adapter problems are the most common cause of black screen in you desktop.And also registry problem in windows can give the black screen error.You can fix black screen error manually.
Jul 21, 2012 | Microsoft Windows XP Professional for PC
Why screen is black out.
On my Windows 7 laptop, I got problem of Black Screen of Death, Windows Boot Genius fix the problem without data loss! I vote it!
Jan 26, 2011 | Computers & Internet
A black rectangular black screen shows up but..... sony trinitron
Check the set up. You may have closed captioning turned on which will show up as a black box if there is no closed captioning information for the selected channel. If that fails to resolve the problem, update this.
Thanks,
Dan
Aug 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Vizio L32 32 in. LCD HDTV Logo
123 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
