Hye i bought a pc hp dx5150 sff when i plug in my hard disk 80 gb seagate baracuda it shows missing operating system i install xp bootable cd in my cdrom first setup was successfully completed and pc get restart but when it restart it shows error loading operating system please sir help me to install windows
    Scholar:
  • 84 Answers
Sounds like you may have to change the boot up drive in your bios.
To enter you bios, you have hit Del or an F key as your computer begins to boot up (watch the screen, it should tell you).
Once you've entered your bios, you have to find where in the bios it allows you to set the order of boot devices. This is commonly under "Power Up" options or on the more recent BIOSes, it'll be under "Boot Devices." Once you're there, refer to the on screen instructions on how to change the order. The most common ways are using the page up/down keys, the +/- keys or the left and right arrows. Set your Seagate Barracuda to be the first place it boots from and you should be able to boot from it.
Posted on Mar 25, 2011
The volume is busy...
Hello sparkling202,
• Goto http://www.bootdisk.com/
• Select Windows XP Fresh Install Bootdisk And Bootable CD
(You should be able to format the hd from the bootable cd)
*As a reminder, The format command will ERASE ALL YOUR DATA on the hard drive !
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 07, 2010 | HP dx2250 Monitor Personal computer AMD...
We are unable to load window xp on hard disc, before we only find the 32 GB in 80 GB hard disk ... we successfully installed the window xp, but when jumper setting done in accurate place, it shows 80 GB,...
I think this model is still an IDE type. You set the 32GB limit then jump the settings to read the full capacity of the drive. If you are trying to load XP OS from a blank drive.
First prime the hard drive, you can do low level formatting and use third party software to partition and format the drive. on FAT32 partition you can only use 8GByte to make the drive bootable. Make it primary if I remembered it correctly and active. Or use the NTFS format.
You can use also if it have the manufacturers' hard drive utilities to check the hard drive integrity. I know they have it. It also equip with zero fill to renew chain and links of the drive. Then partition, format, primary and active. Then load your OS.
Check also your CD disc integrity, scratches do make a lot of troubles. And also your cdrom/dvdrom drive.
Oct 27, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Problem in hard disk
hi Kumar, you may not have noticed it in the past, but most drives aren't 100% the capacity that is shown on the box.
There are two reasons for this:
System Overhead use and the way Microsoft counts a MegaByte (1,024,000 bytes) versus how the manufacturers count a MegaByte (1,000,000 bytes).
Hope this helps.
Mar 20, 2009 | Samsung (SP0822N) 80 GB Hard Drive
My 80 gb hard disk was not accesible
please edit through a dos bootable cd of windows 98. and it should have edit function on the cd. you can edit the boot.ini drive and modify the settings to boot from win xp32 bit by default, it must be second on the list.
if you cant succeed back up your important data from the drive and format the drive back up can be done by imaging softwares.
Feb 20, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
What to do with unreadable but recognised hard disk segate 400GB
Your Windows Xp bootable CD should have an option called "Format his file system using FAT32" while installing the OS. Use the option to format it. The only prob is that it creates only a single partiotion. After installing windows you can re-partition using a third party software such as Partition Magic(please note that it will not affect your windows installation as you can first re-size the windows drive to a lower capacity and then partition the un-allocated space.
Nov 29, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Seagate SATA Baracuda 160 GB harddrive crashed
I've found this to just be the nature of hard drives. You never really can trust them, thats why you always need a backup. Maybe look into a fault tollerant RAID solution if it's really important (kinda expensive)
Nov 23, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Maximum size of hard disk supported
Hi Bijay.
Neither is at fault. Please click on this Seagate link:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=How_To_Install_and_Troubleshoot_ATA_Hard_Drives&vgnextoid=559e5b1142aec010VgnVCM100000dd04090aRCRD
Scroll down to: Partitioning the drive in Windows XP / Windows 2000 (for systems where this is the 2nd drive in the system).
Follow the instruction on the web site.
This Seagate web site will help you setup the Seagate 160 drive.
If you feel the drive is still at fault you can run Seagate’s SeaTools. Click on the next link:
http://www.seagate.com/www/en-us/support/downloads/seatools
This software will check the 160GB drive.
(Follow the online instructions for), SeaTools for DOS.
In a Windows XP system & using a FAT 32 & a cluster size of 16kb instead of NTFS. Windows will see the total size of the drive but can only access 149GB of drive space. 11GB of drive space will be used by the FAT. File Allocation Table. The FAT is windows guide to every cluster on the drive.
XP uses NTFS & sets each cluster to 4kb. This 4kb size lowers the total usable GB size & uses more GB's for the FAT. You're 127GB size may be correct for a Win XP system using a NTFS file system. The FAT is using 33GB of drive space as a locator for every cluster on the 160GB drive.
Help with understanding the NTFS file system: http://www.microsoft.com/windowsxp/using/setup/expert/russel_october01.mspx
Bijay if you are still having trouble understanding please post any questions here.
Mike
Aug 12, 2008 | Intel D845GLLY Motherboard
Hard disk partition table error
Insert windows xp bootable disk and boot your system in CD/DVD and then reformat your HDD and install new windows operating system.
Jan 08, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Hard disk I/O error cannot formate harddisk shows no fixed disks how to solve
Please try to check with your cmos system if it was detected, if not means your harddrive was absolutely damage.
Please rate me solved!
Best regards,
Philip
Nov 16, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
