Spring for a wall furness door - Heating & Cooling
    Brigadier General:
  • 4,736 Answers
Maxe, knowing who the manufacturer of your wall heater is and the model number will really help us to hep you.
Posted on Mar 25, 2011
Can I get my Craftsman 1/2 hp automatic opener I'm guessing it's 20 years old to open the door all the way, after the spring broke?
as the spring is required to take the load off the motor in the operation what you are in effect doing is over loading the motor
you make the adjustments after the spring has been fitted
Feb 18, 2018 | Cars & Trucks
Garage door only opens 4 inches
PROBABLY A BROKEN SPRING
LOOK ABOVE THE DOOR ON THE WALL IF THE SPRING HAS A GAP IN IT CALL A DOOR COMPANY TO CHANGE THE SPRING (NOT A DIY PROJECT THAT I WOULD RECOMEND).
HOPE THIS HELPS
Nov 17, 2010 | liftmaster Chamberlain Garage Door Opener...
Apparently a spring on my oven door is broken (DCS-RG-4844GG). On the large oven door, the left hinge has no tension in it. I can latch the hinge to remove the oven door for cleaning. However, when I...
spring is broken on the side that is 'slacked' without return tension. may be necessary to get underneath the stove chassis. move away from wall, carefully disconnect the gas fitting after turning off the gas spigot. Pull away far enough from wall to 'tilt' the whole chassis rearward to access the underside. Technicians use a 'jack' to raise stove....
Dec 02, 2017 | DCS RGS-484GG Gas Kitchen Range
My garage door opener only opens the door 2 feet high and stops, what could be the problem?
You could have a broken door spring or the drive gear is going bad. You need to remove the cover to check the gear. It is white nylon and is just in front of the motor. You can also increase the 'up force' which is a control on the rear of the motor unit.
Oct 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Oven door spring is either broken or off its hook?
Open the oven door and look in the sides of the oven trim. Probably 4 screws.
Mar 10, 2009 | GE Profile JT912 Electric Single Oven
1.3HP CRAFTSMAN CHAMPION GARAGE DOOR OPENER-NEW IN 2004
Well sounds like its a pressure setting. you said you open the door by hand? Was it easy to do? Ask your self this can a 15 year old kid open it and close it? If so then it sounds like its a presure setting There should be two blue slots on your opener with numbers 1-9 says up and down force. Turn the up force towards the bigger number. Just a little bit. But before you do that as the other guy stated make sure that your cables and springs are working. Spring depending on your doors can be in three places but we going to assume you has the most common set up so look over the top of your door (with it closed) you should eb able to see a tube running across there. and somewhere in the in middle a set of spring look at the spring to make sure that you dont see any of the tube showing in the springs. Becare not to touch the spring as they are under a lot of stress.
Feb 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door only opens about 3 inches
You have a broken spring on the door. Stop tyring to open door with opener immediately or you will have a broken opener and a broken spring
Oct 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Kitchen aid superba side by side refrigerator
CHECK CONDENSOR FAN IN REAR OF UNIT NEAR COMPRESSOR. IF COMPRESSOR IS RUNNING AND UNIT IS COOLING SOME, CONDENSOR FAN IS LIKLY THE PROBLEM. IF THE CONDENSOR FAN DOES NOT RUN THE COILS UNDERNEATH AND THE LOOP THAT RUNS NEAR THE FRONT EDGE OF BOTH DOORS WILL BE HOT.
Jul 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Spring came off freezer door on chefmate RS-06DR. Don't know to attache spring to freezer and door
I had that same issue - a little tricky to describe the fix, but here goes (very non-technical terms used here):
1) take the freezer door off if it hasn't already fallen off
2) unscrew the single screw that holds the plate (that the freezer door attaches to), onto the interior side wall of the fridge.
3) gentle ease the plate away from the fridge wall. It has some plugs that expand to keep in snug to the wall. Now that the plate is off you can work more easily with the spring and door.
4) The spring has 3 parts, the hockey stick end, the spring tube in the middle, and the u-shaped end. The door has a longer top guide (male) and a lower, shorter guide (male), and a tiny hole about 1/2 inch from the top guide. The plate has a bottom bracket (female), a top hole (female), and the top ledge that contains the top hole.
5) insert the hockey stick end of the spring into the tiny hole of the door while fitting the spring tube over the doors top male guide.
6) (this is the tricky part) - force the u-shaped end of the spring so it straddles the top ledge of the plate so that one part of the wire is above the plate and one part of the wire in below the plate.
7) while doing #6, the top male guide of the door should be inserted into the top female hole of the plate
8) snap the lower male guide of the door onto the female guide of the plate
9) you now have the door assembly intact. gently push the plugs of the plate back into the side of the fridge and screw the screw in.
It took me awhile to figure out, and the above instructions are from memory so if I got it a little wrong, you'll hopefully be able to figure it out. The keys were understanding where the spring fit and taking the plate off the fridge. Good luck.
Apr 28, 2008 | Refrigerators
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
