Question about Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
    Master:
  • 324 Answers
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Posted on Mar 25, 2011
  • RJ H2O
    RJ H2O Mar 27, 2011
    For a vaporizer you should be using distilled water. if using softened water, spring water, etc the vaporizer will leave a white dust in vaporizer and around room as minerals settle out.
    RJ
  • Victor Albright Mar 28, 2011
    My understanding is that when you heat water to the point that it boils or gives off steam, the minerals are left behind, because the excitation is on a molecular level. That is the whole point of distillation. Ultrasonic vaporizers, on the other hand, work by mechanical rather than molecular excitation, and whatever is in the water will be deposited in the room.
I have hard water, plugged it in, no steam. Added salt, no steam. What to do?
I have hard water as well and I wasn't getting steam. I put in a good tablespoon of salt and the steam started immediately. Try more than a pinch (if that's all you put in originally)
Oct 16, 2012 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I need to know how to use the warm steam vaporizer i lost the instruccions..
you add vicks petroleum paste/jelly at the top where the air vent is. Add 1-2 tablespoons of salt with tap water in the tank, plug in the unit and warm steam will produce.
Feb 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My humidifier is not working. I have cleaned the heating element. When plugged in the green turns on but that is it. The elements are not heating up to begin the vapor process.
Add salt. No more then 1/2 to 3/4tps max depending on the mineral content in your area.
The unit has two electrodes dipped into the water. Since water its self is none conductive without heavy minerals such as iron and such. You will have to add a small amount of salt until current starts flowing between the electrodes. I suggest a small pinch of salt each try until it produces the steam effect you desire.
Dec 22, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I bought our Vicks vaporizer and it worked great the first night we used it. We had added a pinch of salt and it steamed all night. Now my husband is sick and we cannot get it to work correctly. We added...
When you say you added apinch of salt I asked my wife and she says that is the measure that she uses. I doubt that you have to much salt but you can flush out your vaporizer with warm water while the unit is running. I would run two or three times for 1-2 hours each then remove element and rinse withe warm water.Also rinse out container and refill with warm water to fill line,make sure you don't overfill as this can cause the spitting. I would add about 1/4 cup of pure vinegar and let unit run. If you have hard water or high mineral content this should help to clean it.
I hope this helps you but if it doesn't I would return it as defective. Thank you
Dec 16, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is barely putting out any steam...is there a way to clean this unit so that it will produce more steam? This is a Vicks 1.5 gal unit.
Is the water in your area soft? If so, add a few pinches of salt. Vaporizers boil the water by running electricity through it. If your water is too soft, no electricity and therefore no steam.
If you have hard water, and the unit must be cleaned, try soaking it in vinegar.
Dec 24, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
No mist coming out at all
on the box there is a number for questions or comments : 1-800-VAPOR-1-2 ( 1-800-827-6712 ).
Mar 13, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Nov 19, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vaporizer That Works?
Have you tried adding salt to the water in the vaporizer? Sometimes the water needs to minerals for the humidifier to work...I add sea salt to mine every time I fill it.
Oct 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks Warm Steam Vaporizer 1.5 Gallon Humidifier Logo
535 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
