Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
We have the following problem with our Sony Model No. KDL 40V 4000 CD Digital Colour TV. All channels are perfect except for SBS channels, Coffs Harbour Channel 10 & 1HD Coffs Harbour. We frequently experience pixilating reception (particularly evening). Could you please advise solution/reason. Regards DEBBIE WILLIAMS
  • whu8 Mar 25, 2011
    Thanks for your advice.
    We have spoken to a bloke from Oz Antennas recently who says that there is an upgrade chip or card available that can be installed into the TV to increase the signal strength?
    Is this so? We aren't really technical wizards so are relying on experts to help fix this very annoying problem.
    The ironical thing is that the timing of the pixilation couldn't be worse - Just when his favourite programs are on!! So we'd like to get to the bottom of it if possible.
    I wait for your reply.
    Regards
    DEBBIE
  • Sony Master
  • 12,061 Answers
Hi, well it is the "(particularly evening)" (sic) that gives me the answer to your issue, I feel, there are two possibilities. One that the signal is being degraded by something, some sort of interference is degrading your signal.
Now as strange as this may sound, it can and does happen,if you have ever experienced loss of signal due to a very heavy rainfall or storm, then you have experienced and extreme of what I am describing. Now as well as things like this we also have sunspot activity, very active ATM, also all sorts of "Other" interfering sources. Some may only come on at a certain time and remain for a certain time and stop, repeating daily, there are many factors that can cause and alter these things.
Now the reason that they usually don't interfere is that most often the signal strength is stronger than the interference, but in some areas that strength and interference levels may be very close and sometimes we get a sort of "Break through" which is what I think you then experience on your set, this would be especially so if the Channel being interfered with wasn't a BIG station, or far away, then the signal will no doubt be less than normal, making interference likely.
Two, The other reason is that there is a component(s) in the set that are being affected by a thermal fault, and they slowly degrade over time on,and eventually the component(s) start to fault, and effect the signal/picture , and this in turn is what is causing the problem.
OK what can you do about it? Well one at a time...
Well, relocation of the antenna may help, a higher one, if it's suspected that it's a weak signal, and turning it away from, suspected interference, and more towards the desired signal, here millimeters, can make a huge difference. Calling in an "Antenna Man" would be well worth the cost if this is what is suspected.
Check all connections on existing system, even a small amount of corrosion a bad connection etc, could degrade that already weak signal, so it all must be 100%.
The other possible cause, the thermally affected components, unfortunately, would have to be looked at by a professional. as it would take a skilled engineer to track down such a nebulous fault. In this case it may be preferable to "put up with it" until the set fails completely, or becomes unwatchable.
Well those are my thoughts...
Posted on Mar 25, 2011
I have done an autotune on my sony bravia tv but am not getting channel 9 sbs. the television in the bedroom is a smaller digital tv and that picks up all the channels. the two tv's are connected
Is the splitter an amplified splitter or not? Have you tried the channel search when you connect the antenna directly to the TV? (Disconnect the cables from the splitter and use a coupler to join them together.) Tuners do vary in their sensitivity. For digital signals, your TV should report the signal strength. This is often under the Settings sub-menu. Some TVs will give this information in the Channel Edit option.
If the straight through connection gives a better signal, check your antenna direction and try a different splitter. Amplification will often help; however, when my amplified splitter was damaged the less sensitive tuner lost a number of channels that the other TV received. (Looking at the signal strength, one TV was getting adequate signal with one bar out of 8. The other needed at least 4 bars to process the signal.)
I hope this helps.
Feb 01, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
SONY LCD DIGITAL COLOUR TV MODEL KDL 46S2000 - KDL26S2030 - ALL TUNED OK THEN LOST SEVERAL CHANNELS HAVE TRIED RE-TUNING AND CHECKED TECHNICAL SET-UP BUT STILL CANNOT GET BBC 1,2, AND SEVERAL FREEVIEW...
if you have cable and that happens then the tv has a problem in the IF or tunner section.that means the tunner has to be replaced or the IF IC needs to be replaced.if you do not have cable that means you are blocked out.have a tech look at your tv.good luck.
Sep 22, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Bravia KDL-46S4100, No Picture No sound
I have a sony bravia kdl 40v 5100 for less than two years and i did not purchased an extended warranty and now my tv is down.
I have no picture, no sound just a black screen when i turn the power on, the power (green) light is lite up and the tv turns off by itself for like less than 30 seconds. I have tried to press as many buttons on the remote control and on the side of the TV to get any message but nothing seem to happen. Any suggestions and solutions? Thanks
Aug 23, 2011 | Sony KDL-46S4100 46 in. LCD TV
Hello, Well I have a Jensen antenna( Perfect for HDTV). How do I tune the antenna into a Soniq LCD TV Model E16Z10A. I can only get SBS channels and a few 9 channels. I have done everything! I need your...
I have the same problem with my soniq hd tv i got a digital antenna that plugs into the power and i have also tried the roof antenna and neither worked.. Could it be the tv?
Jan 01, 2011 | Televison & Video
Lost all digital channels - Sony KDL-52W3100
Use ur original remote of the tv u want setup to the DTV box go menu switch cable back to air
reseption.Set tv channel 3 hook up the DTV box and rescan the channels u have it.
Aug 15, 2009 | Televison & Video
No digital picture for Sony KDL-40v2500
These tv's receive digital on the atsc 8vsb. Do you know what there broadcasting in New Zealand ? It could be that a Sony tech there can fix your problem. The TV can be set-up for a different digital broadcast and Sony is all over the world even in New Zealand .
May 04, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Loss of freeview channels
The retuning process is as follows:
  1. Press the [i+] button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If toy wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
Feb 08, 2008 | Sony KDL-26U2000 26 in. LCD Television
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
