Question about Dell OptiPlex GX110 PC Desktop
Display(VGA) output my pc does not give any display out put(unable to on the monitor).the RAM,Processor,monitor are tested on different PCs and found ok.please help me.
  • 70 Answers
Does your system have on board grafix? or do you have a grafix card? if its on board grafix try borowing a grafix card off somebody to try in your system or try your grafix card in another system
Posted on Aug 03, 2008
How to trouble shoot no display problem in PC
Mostly the prolem comes with PCs is no display. When such situation comes we can try following DIY and 90% the faulty part could be diagnosed:
1.Unplug the VGA cable of the monutor and if monitor shows some message (check signal cable) monitor is ok
2.First check for the power whether LEDs are blinking?If yes power unit is fine.
3.Check for the responses of the kwyboard LEDs, if after switching on LEDs are blinking processor is ok otherwise there is some issue with Processor.(Note it might not blink if the mainboard is burned)
4.Try to press num lock key if the LED is responding most probably this is the issue with RAM otherwise with Mainboard.
on Dec 08, 2009 | Computers & Internet
Display off after some time
As you have checked all of the removable components. That only leaves one bit left. The motherboard. Check the capacitors around the CPU socket and the Power connector. There is a common problem with Socket 775 CPU it is that the contacts on the CPU socket can be badly connected even when the CPU is fitted and locked in.
Jul 26, 2013 | Intel Essential DG41WV Desktop Motherboard...
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
Hello Guys, i my monitor will not display anything even if the system unit is running? and processor is abnormally heating, i just bought a new vga card and it started this, i have intel core 2 duo @...
hurm,try change the processor fan.. or your monitor did not support the vga card.... monitor have the resolution.. or you can change the power supply to 500w..
Oct 08, 2010 | CTX S762A 17" LCD Monitor
Screen keeps going black
check your numlock key presss it then check numlock led if it on /off then your computer gives dispaly to monitor perfact then when you power up ther computer press F8 key then enter in enable vga mode if you see safe mode and other mennu.
But if you can't able to see those menu then you have to check your monitor to cpu vga cable connection.
Also check your monitor is properly working? or not.
Aug 13, 2009 | Acer X193W LCD Monitor
I have the same problem
Dear! If monitor showes power but not showes display its means that monitor requires heat and it very better if you can give sun-rays. I assure your monitor will work if you do that for 4 hours. Check your monitor sepreatly with another system or computer if it works that means your VGA card not supported so you should change your VGA card but first check your monitor.
Thank You
Jul 30, 2009 | ASUS P5RD1-VM Motherboard
No display on computer
First thing is do you have a beep when the system boots? Sounds like you may have a BIOS issue I would start there........your RAM and processor are more than likely NOT the problem
Apr 15, 2009 | HP Pavillion a818n Desktop PC (Refurb)...
Samsung GH19LS LCD Monitor wont display computer signals
You should have received two cables with the monitor. One is for VGA and plugs into you video card or computer board . The second one is for DVI digidal video and if you have that cable it plugs into the square connector. Then if you look into your monitor manual or quick setup sheet it will tell you how to connect and set the monitor to either VGA or Digital. I'm sure that is what has to be set. Don't hook up both cables to the monitor and computer. Only use the one. Digital gives you a better picture if your computer has that function. Hope this is helpful. Bud
Jan 04, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Please help
check mosfet ic 7338 it's burn in near by pin no1 replace it
check serial bank registance all near by ram slot value is 10ohms
Mar 29, 2008 | Intel D845GVSR Motherboard
Dell OptiPlex GX110 PC Desktop Logo
56 people viewed this question
Alun Cox
