Question about Garden
Engine cranks as it should but will not cut without lugging down to the point that blade stops. the only time it runs at high rpm is the few seconds before it runs out of gas. fuel line and filter both appear fine. fuel is fresh. whats my problem?
  • 2,239 Answers
From the symptoms you are describing it is running too rich, start by cleaning the air filter, if this does not help check the spark arrestor in the muffler outlet ( if fitted ) if all else fails screw the the H jet in the carb in by 1/4 turn, this will lean the mixture.
Posted on Mar 26, 2011
I have a 2002 Ford Taurus wagon OHV. Need to know how to tell if the crankshaft sensor is bad
Engine cranking, if you have spark at the plugs, the crank sensor should be ok.
Nov 16, 2017 | Ford Cars & Trucks
Engine fires but cuts out in a few seconds
Bad points and/or loose transistorized points.
Aug 15, 2015 | Garden
Hi I have a stihl ts420 it works well and it cuts but the blade won't stop when it's on and it keeps spinning when I'm not holding the gas how can I fix that problem??
I don't know what all these people are talking about. If your saw is used frequently and not new anymore, it's very likely your clutch springs are worn to the point where they no longer hold back the clutch shoes from coming in contact with the clutch drum anymore and at ANY rpm, they contact the drum and cause it to spin. This also happens often when the saw is given throttle when the blade is binding, it wears the shoes and causes heat which weakens the springs. I'm not positive it's this, if you have ever tinkered with the carburetor it's possible it's idling too high yes, but I'm fairly certain that the clutch springs are worn or stretched out or perhaps one may be broken. This is why string trimmers sometimes keep spinning when the motor is at idle. Start the saw and let it get to operating temp, then without giving it any gas, lower the blade to a hard surface and see if it keeps running or if that stops the motor. If it stops immediately, it's a fair bet the clutch needs replacing.
Sep 19, 2014 | Saws
Chainsaw runs fine but the blade slows down to stop when i cut
too much load (too large a cut), dull chain, no lubrication oil on chain, slipping clutch.. lots of reasons.. need more information and you need to check all the points I mentioned. The clutch is RPM dependant- once the RPM drops- the clutch will start to slip. Look for oil or grease on clutch shoes also
Aug 01, 2014 | Garden
Head brightin n dim heater goes up n done
running or not , the engine, that be big time , important....??????
if running is engine hot cold (engine coolant, not air temp)
this is called bad power (12vdc) distribution.
or is the alternator failing
or is the engine RPM going to low, 800 is normal for most cars.
if not running, its a bad battery (or just discharged) or is corroded battery lugs (service them)
if engine RPM drops too low the Alternator will just cut out
and the 15v power is now 12. a visable dim can be seen.
causes running. are
1: alternator belt slipping, sure service it.
2: alternator regulator bad.
3: battery bad. or bad lugs.
if you have a voltmeter all this is easy.
got one?
Jan 31, 2014 | Honda Civic Cars & Trucks
I have a 2008 mercury Milan with nearly 60k miles on it. When I come to a stop the rpm drops by 1000 then recovers quickly. What should I do to fix the problem? Any suggestions will be greatly appreciated.
Check out related help links to troubleshoot these problem:----Click the link below:---Idles Fine but RPM jumps in drive mode? http://technoanswers.blogspot.in/2012/07/idles-fine-but-rpm-jumps-in-drive-mode.html
---------Mitsubishi Lancer rpm needle bounces? http://technoanswers.blogspot.in/2012/02/mitsubishi-lancer-rpm-needle-bounces.html
--------How to adjust rpm on 2009 dodge charger SRT8?
http://schematicsdiagram.blogspot.com/2011/12/how-to-adjust-rpm-on-2009-dodge-charger.html
Engine cuts out at 3000 RPM? http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
Cold start problem and vehicle shudder around 2500 to 3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
High rpm in neutral? Inconsistant high RPM in neutral? http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Jetski Sputters and Low RPM? http://whatisbyme.blogspot.in/2012/07/jetski-sputters-and-low-rpm.html
Fuel Injection Problem And RPM suddenly increases http://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2005 Toyota Highlander: Engine runs hard RPM below 3000? http://whatisbyme.blogspot.in/2012/05/2005-toyota-highlander-engine-runs-hard.html
1987 Toyota Camry: RPM Drops going Up hills? http://whatisbyme.blogspot.in/2012/05/1987-toyota-camry-rpm-drops-going-up.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
1990 Toyota 4Runner: Engine cuts off when reaches 2000 RPM?
http://whatisbyme.blogspot.in/2012/05/1990-toyota-4runner-engine-cuts-off.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
1995 Toyota LS: Misfire at idle or low RPM http://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Lexus RX: Tapping noise under Valve Cover At Low RPM? http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
These will help.
Thanks.
Nov 22, 2012 | Cars & Trucks
Driving on the road the RPM goes higher wituout speedind
Check out related help links to troubleshoot these problem:----Click the link below:---Idles Fine but RPM jumps in drive mode?http://technoanswers.blogspot.in/2012/07/idles-fine-but-rpm-jumps-in-drive-mode.html
---------Mitsubishi Lancer rpm needle bounces?http://technoanswers.blogspot.in/2012/02/mitsubishi-lancer-rpm-needle-bounces.html
Engine cuts out at 3000 RPM?http://schematicsdiagram.blogspot.com/2011/12/engine-cuts-out-at-3000-rpm.html
High rpm in neutral? Inconsistant high RPM in neutral?http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
Fuel Injection Problem And RPM suddenly increaseshttp://whatisbyme.blogspot.in/2012/07/fuel-injection-problem-and-rpm-suddenly.html
2005 Toyota Highlander: Engine runs hard RPM below 3000?http://whatisbyme.blogspot.in/2012/05/2005-toyota-highlander-engine-runs-hard.html
1987 Toyota Camry: RPM Drops going Up hills?http://whatisbyme.blogspot.in/2012/05/1987-toyota-camry-rpm-drops-going-up.html
1995 Toyota LS: Misfire at idle or low RPMhttp://whatisbyme.blogspot.in/2012/04/1995-toyota-ls-misfire-at-idle-or-low.html
Lexus RX: Tapping noise under Valve Cover At Low RPM?http://technoanswers.blogspot.in/2012/04/lexus-rx-tapping-noise-under-valve.html
These will help.
Thanks.
Nov 22, 2012 | 2008 Toyota Avalon
Rpm not working and run for a few seconds and cuts off
possible crank sensor problem. the 3800 engines were noted for this failure. although could be a bad module, cam sensor or associated wiring
Aug 31, 2012 | 1997 Buick Riviera
Hi, My Stihl TS400 with 14"
Racing on a 2 cycle engine is usually a sign of a lean condition. It could be caused by a few different things including a bad crank seal or a torn intake manifold as some are made out of rubber. I would remove the cutter arm then pull the muffler to inspect the cylinder and piston. If they are scored it will be a costly repair.
Jul 14, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Stops running after 2 minuets
Honda engines have an oil sensor that sometimes fails. It will cause this. If the sensor fails it is like not having enough oil and will kill the engine for protection. Just something to look into. Hope this helps
May 01, 2009 | Swisher T14560 T - 60" Trailmower with 14...
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
