Need to know exact name & maybe part number of door rim which has the latch. It holds window in place from behind Thankyou Brian.
  • 1,998 Answers
Hello brain,
needing the make and model of your machine? is how we will start this first. with these i might be able to track down your schematic Thanks Rick
Posted on Mar 25, 2011
Door Sensor Won't Shut off!
if there is no visible switch which the door pushes against then the problem probably is the door latch switch remove panel with window down look for screws holding it on then pull it off just be careful and watch what your doing may have to swivel to get past inner door latch if manual window C clip behind crank need a small hook. window up look at door latch should be a plug unplug it see what happens.
Jan 13, 2015 | 1997 Dodge Stratus
I need help on removing door panel on 2000 Dodge Caravan - window fell in dorr and I can not seem to get the panel off. Any suggestions?
Answer
FRONT DOOR TRIM PANEL
REMOVAL
Using a trim stick (available from parts stores), pry courtesy lamp from door trim.
Disconnect wire connector from courtesy lamp.
If equipped, remove screws attaching door assist handle to inner door panel.
If equipped, remove screw attaching door pull cup to inner door panel.
If equipped, remove screws attaching trim panel to door from below map pocket.
If equipped, remove window crank.
Using a trim stick, remove screw cover from switch panel.
Remove screws attaching switch panel to door trim.
Remove power accessary switch from door trim Front Door Switch Panel
Disconnect power switch from wire connector.
If equipped, using a small, flat bladed pry tool, remove memory seat/mirror switch and disconnect wire connector Memory Seat/Mirror Switch
If equipped, remove screw holding door trim to door panel from behind inside latch release handle.
Disengage clips attaching door trim to door frame around perimeter of panel Front Door Trim Panel
Lift trim panel upward to disengage flange from inner belt molding at top of door.
Tilt top of trim panel away from door to gain access to latch linkage.
Disengage clip attaching linkage rod to inside latch release handle Inside Door Handle Linkage
Separate linkage rod from latch handle.
Remove front door trim panel from vehicle.
INSTALLATION
Hold top of trim panel away from door to gain access to latch linkage.
Place linkage rod in position on latch handle.
Engage clip to hold linkage rod to inside latch release handle.
Place front door trim panel in position on door.
Install trim panel into inner belt molding at top of door.
Install clips to attach door trim to door frame around perimeter of panel.
If equipped, install screw to attach door trim to door panel behind inside latch release handle.
If equipped, connect power switch into wire connector.
Place power accessary switch in position on door trim.
Connect wire connector into memory seat/mirror switch and install switch into trim panel.
Install screws to attach accessary switch panel to door trim.
Install screw cover into switch panel.
If equipped, install window crank.
If equipped, install screws to attach trim panel to door inside map pocket.
If equipped, install screw to attach door pull cup to inner door panel.
If equipped, install screws to attach door assist handle to inner door panel.
Connect wire connector into courtesy lamp.
Install lamp in door trim.
Feb 02, 2012 | 2000 Dodge Caravan
The dishwasher door snaps open, stopping cycle. The friction catch often requires multiple presses to hold closed sufficient to allow the cycle to begin. I would like to know what adjustments are required...
Welcome to FixYa.
I suspect based on your description...it is the door strike that is likely fatigued as is common with these machines, thus allowing the door to "pop" open. The latch doesn't hold it closed, it just activates the switches, the strike is designed to hold it closed.
It is part # 8574157 and will look like the image here...
You do not need to remove the control panel to access the strike for the door latch assembly. It is done simply by pulling up (may need a flat screwdriver or the like) on the latch and forward. The new one also simply clips in place.
**make sure to turn off the breaker/power before servicing the unit...safety first**
Let me know if you need any further assistance and I will try to help in any manner I can. Good luck,
Regards,
Macmarkus :)
Jun 08, 2011 | KitchenAid Dishwashers
How to fix the interior lights? They stay on after the doors are closed. They also stay on after the car is started. After awhile they will go off but the problem comes back as soon as I get back into the...
  • It can very possibly be the door ajar switch. But it may not need to be replaced. Them switches get dirt and crud in them as well as rust. You can spray some WD-40 on the switch and open and close the door a few times. and see if this loosens it up some.
  • If you need to replace it then this is an easy task. The switch is just a few inches below the door latch on the inside of the door frame.
  1. Remove the neg battery terminal.
  2. Remove the screw from inside the armrest.
  3. Remove the screw under the door handle.
  4. Take a torx wrench and remove the three bolts (on the side of the door) holding that hold the door latch in place.
  5. Pull the latch out and you will see the door ajar switch.
  6. Unscrew the door ajar switch and screw a new on in it's place.
  7. Now reverse to finish the job.
Regards, Tony
Jun 01, 2011 | 2000 Ford Taurus
Code F 11
F11 is a serial communications error that is associated with either the door latch, central control unit (main computer) or associated wiring. Since you can hear a "click", and the washer works intermittently I would suspect you have a bad door latch assembly. Just to be sure you will need to check all your wiring connections going to the central control unit and door latch. To access follow these steps:
1. Unplug the washer.
2. Remove the three 7mm screws holding the top panel on. They are located along the top edge in the back of the washer. Once the screws are removed the top panel will slide back then lift up.
3. The Central Control Unit (CCU) is located in the central rear of the washer. You can't miss it. Make sure all the connections are plugged in snugly. The door latch connections are located behind the front panel on the right hand side. Check ONE connection at a time.
After checking wiring harness, run systems diagnostics test by performing the following:
Select DRAIN/SPIN, NO/SPIN, followed by pushing any button under OPTIONS 4 times. If entered correctly the display will read "C00" and you should hear the door latch "click". The diagnostics will run through a series of tests to include FILL, AGITATE, DRAIN and SPIN functions. Since the door latch is the first step of the diagnostic sequence, the tests will not progress if the door latch fails. You can push PAUSE/CANCEL any time to end diagnostics. Run this test several times. If anything fails you will get an "F" code in the display window. If the tests all pass, the unit will shut off, followed by an audible "beep" and the CLEAN light indicator will be lit. If you get successful results, then you know you probably had a loose wire somewhere. If the test fails, I would attempt to replace the door latch before the CCU. The latch costs considerably less. The CCU can cost as much as $220 depending on where you get it.
If you decide to replace the door latch follow these steps:
1. Make sure washer is unplugged.
2. Locate the wire hoop retaining ring that holds the rubber door boot on. It will be located behind the front edge of the rubber where it meets the door frame.
3. Locate the tension spring at the 6 o'clock position and stretch the spring apart to release the hoop. Pull the hoop from the bottom first and remove from the door boot.
4. Pull door boot from door opening and fold back inside wash tub so you can access behind the front panel of the washer.
5. Remove the three torx screws that hold the door latch on.
6. The door latch is seated in a plastic retainer bracket. Reach in behind front panel and carefully remove the door latch from this bracket so you can access the wire connectors.
7. Remove wire connectors.
8. Re-install wire connectors and latch in reverse order of how it was removed.
9. Re-install door boot, ensuring it seated properly all the way around the door frame opening.
10. Re-insert wire retaining hoop in the groove behind the front lip of the rubber door boot starting at the 12 o'clock position and working your way around to the 4 and 8 o'clock positions. (You may need a second set of hands for this part). While holding downward tension on the hoop to keep it seated, stretch the spring apart enough to snap the remaining part of the hoop back into place at the bottom of the door opening.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do I remove the panel on the driver's door to service the window motor?
carefully pry off trim around door latch handle w/a flat screwdriver.remove phillips head screws holding armrest/door pull push out C clip under window crank if equipped,or pry cover off window switch panel.with a putty knife or small nail pulling tool between panel & door,pry out the 'push pins'holding the bottom & sides of panel.lift up on panel to loosen window weatherstrip.disconnect any wires behind panel.
Sep 22, 2009 | 2004 Dodge Caravan
The washer goes for about 2 min. and the reg f 11 and dl i know the dl is for the door lock but how do you fix the door lock and why is this f 11 thing going on
Fdl is a door latch error code. F11 is a serial communications error that is associated with either the door latch, central control unit (main computer) or associated wiring. Since you can hear a "click", and the washer works intermittently I would suspect you have a bad door latch assembly. Just to be sure you will need to check all your wiring connections going to the central control unit and door latch. To access follow these steps:
Run system diagnostics again to see if the latch functions properly and all tests pass. Good luck to you and I hope this helps you.
May 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drivers door wont latch
open yor inner door panel most of the time it is a lock rod, or plastic socket that holds it in place might of broken, or simply jarred loose if slammed hard. on older cars.
shack
Apr 14, 2009 | 1998 Toyota Tacoma
Pearl 8100 Sim Card Assembly
This is a solder-on part. If you cannot solder, I would recommend sending it to the Blackberry experts. Try http://www.pdasmart.com for your blackberry repair needs!
Nov 04, 2008 | RIM BlackBerry Pearl 8100
Washer will not start
"Fdl" is definitely a door latch error. This will cause the washer not to start. You will need to replace the latch to keep from getting errors and intermittent problems. It will only get worse until it fails altogether. To replace, just follow these steps: 1. Unplug the washer. 2. Feel around the rubber door boot along the front edge. At the bottom, behind the rubber you will find a tension spring. Pull the tension spring out and remove the wire retaining hoop. 3. Remove the door boot from around the door opening and push inside the washer so you can access the door latch behind the front panel. 4. Remove the three screws on the front of the washer that hold the latch in place. 5. Carefully remove the wire connecting plugs to the door latch and remove latch assembly from plastic retainer holding it in place. 6. Replace the door latch in the reverse order of the steps given. 7. Reinstall rubber door boot around the door opening making sure you seat the rubber all the way around the groove. 8. Now comes the hard part - putting the retaining spring back in place. Position the tension spring at the six o'clock position and start inserting the hoop from the top first, working your way around to the 4 and 8 o'clock positions. The assistance of another person would be great right about now. Hold the hoop in place at the 4 and 8 o'clock positions, making sure you keep enough tension on the hoop to keep it seated in the groove. 9. Stretch the tension spring in order to snap the remainder of the hoop back into place. I know this may seem like a lot, but it is a fairly simple repair. I hope this helps you.
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
