Question about HP DeskJet 840c InkJet Printer
I have an 12 year old hp printer still going strong hp deskjet 840c. Sometimes it shows a connection error that is the computer doesnot detect the printer I use a usb cable for connection. The printing command just be in the pending list. normally when we switich off any thing that is connected through the usb the computer gives a sound showing the system is disconnected from the computer but now a day when the printer has this connection error this sound is missing. sometime when i switch off and switch on it works but nowadays it doesnt but nowadays it works sometime when i shake the printer. i changed the usb cab but it was of no use
  • 51 Answers
Hi I think your printer has a parallel connector ( big D shaped socket with wire clips each end) on it if your pc also has a parallel plug get a parallel lead and install the drivers to use LPT1 this should remove the faulty USB plug from the problem
good luck Ian
Posted on Mar 25, 2011
My hp deskjet 840c is not printing, can you tell me please how can I know The cartridges ink actual quantity and how can i clean them into the printer? thanks.
this link will show you how you can properly clean your printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud02948&tmp_task=useCategory&lc=en&dlc=en&cc=us&lang=en&product=59868
assuming that you are using windows 7 this link will show you how to check the ink levels
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=23455&tmp_task=useCategory&lc=en&dlc=en&cc=us&lang=en&product=59868
Mar 06, 2011 | HP DeskJet 840c InkJet Printer
My new computer does not have a parallel printer port. My old 840C printer has both parallel and USB ports, though I only ever used it with a parallel cable, so I tried connecting with a USB cable. The...
Hello and welcome draepeacock !
The only solution is a workaround :
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.Back up your data first.
Both are easy and safe , no specific knowledge required .
Regards .
Feb 14, 2011 | HP DeskJet 840c InkJet Printer
What ink cartridges are compatible with hp deskjet 840c
HP C6615DN (HP #15 black) and HP C6625A (HP #17 color) inks are the compatible inks for this particular printer.
Thanks, Lolita
Nov 04, 2010 | HP DeskJet 840c InkJet Printer
HP DESK TOP 840C PRINTER CONNECTION
They do make adater cables for such problems. Here is just one such example: Parallel to USB Cable
Make sure you get the correct 25 pin cable. They have this type also:
Parallel to USB Cable 2
You can search the web for more companies. Google parallel to usb printer cable.
After saying all that and checking your printer info, I see that the 840c has both a parallel and a USB cable port. See page 21 of the manual: HP 840c Manual
If you go that route, you will need a standard USB cable. The shorter the better, but no longer than a 6' cable. Make sure you follow the iinstallation instructions for the USB setup in the manual.
Thanks for using Fixya.
Apr 14, 2010 | HP DeskJet 840c InkJet Printer
My printer started to only print random numbers and letters MODEL HP DESKJET 840C
Turn the printer off at the wall outlet, reboot your computer and then plug the printer back in.
Nov 17, 2009 | HP DeskJet 840c InkJet Printer
The printer is not printing even wen d cartridge is full and driv
well writen- if all is as you say that just leaves the drivers for your printer...
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=59868&
go to this page and select your operating system (win XP- Vistia) then save the drivers to desktop.
Now- disconnect your printer from your computer and don't reconnect until you are instructed to do so. OK-run your printer drivers and follow directions-connect when told to-
And that should do it.
Please leave for me a rating...
May 15, 2009 | HP DeskJet 840c InkJet Printer
Blinking lights on my hp deskjet 840c printer
There should be some error .So you know how to remove the catridges just remove it n re insert it properly.If there are any paper jams try removing it also.and by the way if you haven't installed the drivers for HP deskjet this problem may arise.So make sure you ahve don this.Also this can be happened if the printer have some hardware problems.So none of this solutions are working its better to consult it with an expert.
Dec 18, 2008 | HP DeskJet 840c InkJet Printer
HP DeskJet 840c
pls. change your data cable of printer connected to computer
if it is work pls. remarks
Jan 30, 2008 | HP DeskJet 840c InkJet Printer
HP DeskJet 840c InkJet Printer Logo
71 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
