Question about Panasonic DVD-S25
My 3 year-old got a hold of the remote for our Panasonic DVD-S25 player and somehow applied a parental rating control with password (which we do not know nor does our child). Now the dvd player will only play G rated movies. Is there anyway to fix this or do we need to buy a new dvd player all together?
  • 112 Answers
Posted on Mar 25, 2011
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
Jul 07, 2013 | Televison & Video
How do I reset the parental control password on a govideo dvd player?
Parental Control
Blocks playback of rated DVDs based on
their content. Not all discs are rated.
1. In DVD Stop mode, press SETUP.
2. Select Others > Parental.
3. Select the desired Parental Control
rating from "1 Kids" to "8 Adult", then
press ENTER.
4. Enter your password using the 0-9
keys, then press ENTER.
• The factory default password is
3308. If you forget your password,
this will always work.
Password
Changes the Parental Control password.
2. Select Others > Password.
3. Enter your old password using the 0-9
keys.
4. Enter your new password.
5. Re-enter your new password and
press ENTER.
Mar 05, 2011 | GoVideo DV2150 DVD Player/VCR
Unlock instructions for Toshiba dr570 DVD
Hello
Turn on your DVD player and television. Select the appropriate input source for your DVD player on your television.
Press the "Setup" button on your DVD player's remote control to display the main menu.
Navigate to the "Rating" menu option using the "Down" button on your remote control. Choose the "Parental Control" item by pressing the "Right" arrow button, followed by "Enter."
Enter the parental control access password using the numerical pad on your remote control, followed by the "Enter" button. If you did not previously setup a unique password, enter "8888" when prompted for the password.
Press the "Enter" button to display the parental control rating menu. Select the "8: Adult" menu selection by pressing the "Up" or "Down" directional buttons on your remote control, followed by "Enter." Press the "Open/Close" button on the front of the DVD player to complete the process.
Nov 21, 2010 | Toshiba DR570 DVD Recorder
JVC XV-M555 DVD player has the parental control set somehow. Need to know how to disable the parental control on this DVD player
Found the manual for the player buried in a box from moving. Procedure is
1) With no DVD in player
2) Press enter while holding down shift to display parental lock menu
3) If you dont remember the password enter 8888 to access the options
4) Use cursor to move arrow to country code option
5) Use right cursor to select country code, then down cursor to move country code to US
6) Use left cursor and down cursor and right cursor to move to set level
7) Use down cursor to toggle through level options. (None removes all blocks)
8) If setting a level toggle down to password and set new 4 digit password.
Jan 01, 2010 | JVC XV-M555 Multi-disc DVD Player
Parental controls set, no password known
Check to see if there is a reset to factory settings in the menu or a small hole on the case which you can use a pin to push a small button in side which is used to reset your device to factory settings
Aug 29, 2009 | Panasonic Televison & Video
Can't get the Initial Settings screen
Hi,try this...with the dvd tray open,hold the rec button and play button on the dvd for 5seconds.hope this helps?
Mar 25, 2009 | Panasonic DVD-A110 DVD Player
High school musical dvd player parental control password
ok I have got the manual and for parental options it says
The parental option anebles parents to prevent their children from watching inappropriate material on a dvd. It reads the ratings for programming, then denies access to programmnig if the program's rating meets the limitations you selected. In this case, the user will have to enter a 4 digits security password, then press enter button.
The password in my book is forward button,backward button, forward button, backward button.
tahts the ones with the 2 arrows on.
I hope this helps i need the help line no because my little girls remote does not work with her player.
Dec 30, 2008 | Disney High School Musical DVD Player
Parental password control inadvertently activated.
Called Zenith. They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!
Nov 11, 2008 | RCA Televison & Video
DVD player parent lock
My unlock code is 0123, I didn't set it but it works to unlock parental controls
Mar 28, 2008 | Disney Televison & Video
Dvd troubles
Same problems with my unit.  But, try this... I think it worked.  First, you can not get to the setup screen for the unit with a DVD in the player.  So, remove the DVD first:  Unplug the unit, wait a few seconds, plug it back in.  Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play.  At the Sony Blue DVD screen, select Setup on the remote control.  Select DVD setup and get to Parental control.  Set a password.  This will then take you to a "rating" screen.  By setting the rating very high (I set mine for #8) any movie should play without needing the password.  With no password set, you can not change the "rating" and hence mine was set at #1 (kids).  It seems to have worked for now anyway.  Good luck.
Oct 14, 2007 | Sony SLV-D300P DVD Player/VCR
Panasonic DVD-S25 Logo
193 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
