Question about Eiki LC-SE10 Projector Multimedia Projector
My tv wont respond to the digtal optical audio cable
  • 442 Answers
Is it the TV or the projector that wont respond
Posted on Mar 26, 2011
Sound from my plasma TV does not work on AVR 235 via optical cable
So much can go wrong. WARNING!! NEVER LOOK STRAIGHT INTO THE LIGHT FROM AN OPTICAL AUDIO OR VIDEO SYSTEM. The optical output could be not working (try switching it on and look if you see a red light) The optical cable can be broken inside) see if the brightness of the red light is almost the same as what is coming out of the TV. Point it to a white paper to view.
The optical input from your receiver can be defect or dirty. The optical protocol can be wrong or the systems are not compatible.
If it ever worked, the most chance is the cable is defect.
Otherwise follow the chain and read what the manuals have to say about how and what.
Nov 30, 2014 | Harman Kardon AVR 235 Receiver
I cant get my energy sound bar to work on this sharp lc46sb54u tv,do i need to use digtal output cable? i have tryed rca cables,no luck.
You have to setup the sound to go to the aux out on the TV. Either digital, Optical or RCA in order for the TV to route the sound to the correct output port.
Apr 27, 2014 | Sharp LC46SB54U 46 in. LCD TV
I have an rca surround sound system and how do I install of to my vizio
Your best option would be to connect all your components requiring video to be hooked directly to tv through HDMI in or component in. With a component hook up, you will have to provide audio with either digtal optical or composite cables. You then would want to provide sound to your surround sound by a digital optical out or composite out to the input of your surround sound.
Apr 04, 2011 | Vizio 42 in. LCD TV
E320VP LED HDTV just purchased. How to I hook up to a home theater system if it has no optical input jack? Thanks.
You should be looking for an optical output on the TV and an input on the home theater. if you mean the home theater has no optical input then you will have to resort to using RCA cables, they wont provide surround sound but most TV channels wont use surround anyway. They are the red and white sockets on the TV. If you need further help please respond with the brand and model of home theater system
Jan 11, 2011 | Vizio Televison & Video
I just bought a Panasonic plasma tv model TCP50S2 and I can't seem to get my Kenwood receiver to work with it. Do I need to set the remote to the Panasonic tc? If so does anyon know the code number? I...
I assume you want the TV sound through the receiver?
You need to connect the TV digital out to the receivers digtal in.
This is probably an optical connection.
Then you need to switch the receiver to the correct input. You may also need to tell the receiver what kind of connection is made: Optical or coaxial, if it doesn't detect this automaticly.
Sep 22, 2010 | Kenwood VR-705 Receiver
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
I own a Yamaha RX-v365 and i cant figure out how to connect my PS3 to the surround sound. For some reason the HDMI cables wont work. Any help would be greatly appreciated. Thanks
As above :
Connect PS3 via HDMI to DTV/IN, Connect HDMI from out to TV's HDMI/IN. Connect TV's Optical out to amps DTV/Optical in.
2X HDMI cables and one Optical are required.
I have the V363 but yours looks the same.
Enjoy great sound :)
OH: choose the DTV input then stereo and then dolby etc .. cheers
Oct 31, 2009 | Yamaha RX-V363 Receiver
8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Apr 11, 2009 | Yamaha HTR-6130 Receiver
Digtal
All sets are Digtal Ready they are telling you that if the only way you receive a signal is by antenna then tv will not work without a converter box, as long as you receive cable or satellite then your good to go!
Nov 27, 2007 | RCA F25441 25" TV
No digtal audio with fiber optic jack
hook up a digital audio coaxial cable to it (not the old ones with the pin in the middle that always bends, the new one that looks like an rca cable except its orange instead of red/white/yellow). If it still doesnt play sound then your receiver is probably in analog mode. If it does play sound then its the fiber optic input.
Oct 08, 2007 | Kenwood VR-3090
Eiki LC-SE10 Projector Multimedia Projector Logo
22 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
