Question about Nintendo Wii Console
I cant connect to wireless network - Nintendo Wii Console
    Scholar:
  • 84 Answers
In order to connect to your wireless network, ensure that you enter the right encryption key or password when setting your wireless options on your Wii. Also, make sure that your wireless router is not employing the use of any MAC filtering options. Lastly, make sure that your router isn't near any electrical devices that may cause interferences and that it's close enough to your Wii to provide a strong signal.
Posted on Mar 25, 2011
2 Suggested Answers
  • 495 Answers
SOURCE: cant connect to wireless network on my ps3
First off you have a wireless router hooked up to your ISP correct.
anually set a static IP for your wireless connection (When going through the network setup in Network Settings --> Internet Connection Settings (wireless), choose Custom instead of Easy when the page asking for either appears).
Set the IP address to something outside your DHCP range. e.g. 192.168.0.5 (for dlink router) or 192.168.1.5 (Linksys router)Default gateway should be the IP of your router. For dlink, this should be 192.168.0.1 and Linksys should be 192.168.1.1DNS Server can be the same as your default gateway, mentioned above.
Subnet Mask should be 255.255.255.0.If you're using some sort of encryption (WEP, WAP, etc), set it in there as well when it asks to do so.
And that should get you going. I actually haven't done this on the ps3, but its my info from experience with regular pc to pc networking.
Also If you haven't tried this already, change the wireless channel from 6, to 1 or 11 in your router and wireless consoles.
If all else fails, try this http://www.clanbluntforce.com/forum/index.php?topic=864.0
Posted on Nov 21, 2009
Have mpc l373n1 and it says iam connected to wireless network but cant get online please help
Do you own the wireless network? It is possible to connect to a wireless network without being online IF the wireless network is not connected to the internet. So first you must make sure that the wireless network you are connected to, is connected to the internet.
Hope this helped!
May 18, 2011 | MPC Computers ClientPro 414 All-In-One PC...
Cant connect to a wireless network
You need to turn on your wifi which maybe on the outside or on your keyboard, then go to bottom right of screen & left click on wireless connection then click on "connect to a network"
Apr 24, 2010 | Toshiba Satellite A100-S8111TD Notebook
Connected to wireless network, but cant browse internet.
I think there might be lost in the packet sending.
You said the PC is still connected to the network but not able to go online.
Is there any other wireless computer which is able to go online wirelessly and working fine.
If yes then try to uninstall and reinstall the adapter.
If not then check the router wireless settings.
Click Here for more info about networking.
Oct 08, 2009 | Computers & Internet
Cant get wireless router to work on laptop
First, try to connect your laptop hardwired to the router, if it works fine, its just the wireless configuration. Make sure you are using the correct wireless network key to connect to your wireless network. Go to the Control Panel > Network Connections > Right-click Wireless Network Connection > Properties > Wireless Networks Tab and delete all the names listed under Preferred Networks box. Click Ok. Right-click on Wireless Network Connection again > View Available Wireless Network > Choose your own network and click Connect. If it asks you to type the network key, type in your WEP or Wireless Network Key and press connect. That should do it.
Oct 06, 2009 | Computers & Internet
Wireless card works. says cant find wireless
There's a little switch on the right hand side below the keyboard...
Regards.
Aug 06, 2009 | Acer Aspire One PC Notebook
My computer was wireless until I changed modems becausethe old one stoppd working
If you are using Windows XP, you go to start --> control panel --> network connections --> right click on wireless network connections & go to properties --> go to wireless network tab --> delete / remove all the networks under preferred network box then click on view available wireless or configure then connect to your network by clicking on the name of your modem --> type in the wireless password.
May 01, 2009 | 2wire (1000-000057-000) Modem
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
Setting up wireless connection
First check to see if your windows can see the wireless router. Does it see the router? Click view wirelss networks to see a list of available networks. If you cant see any make sure your wireless network is switched on.
Also which manage s your wireless network, the windows or the wireless cards own software?
Aug 14, 2008 | Computers & Internet
Nintendo Wii Console Logo
16 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
