Question about Keurig B60 Coffee Maker
My Keurig B60 start spontaneously brewing. I had to unplug it to make it stop. Now it flashes not ready. Any suggestions?
SOURCE: New Keurig B60 stopped working!
I had the same issue. I now believe that there was some "vapor lock" type issue. Mine would say the same thing, and i could hear the pump running, but the water level was not changing in the reservoir. I unplugged it, removed the reservoir, let it cool, then tipped it on its back for a few minutes, then on each side. Truthfully I was trying to see if there was some kink in the tubing. Couldn't find a problem, so set it back up and it runs great again.
Posted on Jan 02, 2010
  • 28 Answers
SOURCE: My Keurig B60 just stays flashing
Try removing the water reservoir tank, the replacing it. Make sure the reservoir tank is seated properly. There seems to be a problem with this model with the water reservoirs not seating properly and causing the unit to stop working or shut off. Hope that helps! Best of luck...
Posted on Feb 07, 2010
  • 28 Answers
SOURCE: keurig b60 wont brew
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
SOURCE: My Keurig B60 will not
Contact Keurig cust. svce. (if still under warranty) and they may replace unit. 'We had ours for three weeks and a new one is being shipped.
Posted on Dec 24, 2010
heatman101
  • 43501 Answers
SOURCE: My Keurig B60 will not brew. The "ready to brew"
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Mar 04, 2011
I can't get the not ready light to go off. Brewer does not work.
1. Try to unplug unit for 1 hour. Reconnect power after 1 hour. Wait ~10 minutes.
2. Ensure you have a full reservoir of water.
3. Lift and replace lid for k cup. You should be able to select cup size and start brewing.
4. If still not working, suggest returning. Keurig retailers are very good at doing exchanges now, especially Bed Bath and Beyond (with no receipt).
Good Luck.
Dec 30, 2013 | Keurig B60 Coffee Maker
Keurig B60 screen flashes "Not Ready," "Auto Set Off" and "Brew Temp." The machine also will not shut off. Unplugging it does nothing, nor does the reset sequence of button pushing. Is there anything else...
Lots of problems with the B60/65/70 units. There are some really good videos on you tube, but trust me, the process to fix is going to be a pain and cost ~$50. You should consider taking yours back for an exchange. There is a known problem with these models and it appears the retailers are being very generous on exchanges (check this out: http://babelniche.wordpress.com/2012/03/10/keurig-dumps-inventor-builds-millions-of-junk-coffee-makers/) .... Good luck
Nov 22, 2013 | Keurig Platinum B70 Coffee Maker
Keurig B60 coffee maker won't draw or heat and "not ready" stays on
Handel not in positive position to start brew process.
Jan 26, 2013 | Keurig B60 Coffee Maker
Directory shows "Ready to Brew". How do I start
Sorry to read about your problem, I hope this helps you out.
Just hit the big button, its flashing have k cup in and handle down
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
i
Dec 21, 2010 | Keurig B60 Coffee Maker
Keurig b60 wont brew
Jan 25, 2010 | Keurig B60 Coffee Maker
B60 just flashes not ready yet ,have unpluged and tried that small cup med. cup and menu thing nothing changed
There has to be water in it first off. See my solution on the B50 with a similar problem. Before the lights blink ready the top (K-Cup Holder)has to opened and closed. Then the lights should blink and it should say ready to brew. I wish I had included that in the previous solution on the B50.
Feb 22, 2009 | Keurig B60 Coffee Maker
Keurig B60 coffeemaker stopped pumping water because I didn't notice there was almost no water left in the chamber and started it--I added water right away but it won't pump any more water out of the...
This morning my Keurig sounds like it begins to pull water then stops. I tried to cut it off then back on. Still didn't work.Removed water from reservoir and K-cup and added pure vinegar. Ran machine several times without filter or Kcup by pressing cup selector several times. You must open K-cup holder and close each time. I had to do this about a dozen times before the water began to draw again. Flushed system by filling water reservoir with fresh water, and brewed just plain water until vinegar was gone.Works like brand new.
Nov 11, 2008 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
99 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
