Question about HP DesignJet 4520PS InkJet Plotter Printer
We have a HP Designjet 4520ps plotter that is having the error message 79.04 According to HP this is a firmware error so we decided to try to update the firmware. We downloaded everything we could find including the latest firmware file (7.1.1.2). When we got to the plotter we tried to FTP the new file to the plotter, but we could not get the FTP to work with a .FWM file. Next we used the HP website and they advised us to use a USB memory stick and plug it straight into the plotter, but there isn't any USB slots on the plotter. Lastly we tried using the inbuilt web function. HP says you should open up the settings page and click on the "Update Firmware" button, however there isn't any update firmware button on the http pages.\r\n Does anyone have any ideas how we can either FTP the .FMW file or if there is a different way of going about this whole procedure?
  • d26pclan3 Mar 29, 2011
    Thanks Seeker5211. I cannot use the solution that you suggested as there is no "firmware update" button on the settings tab for me to click on.
    I posted on the HP web forum too as you suggested. Hopefully between this forum and that one I might be bale to find a solution.
Dear sir/madam,
in this hp designjet 4520, this error comes up :error code 24:10. when i enter it, in the service manual it shows: Broken bag detected in Ink Cartridge. but it doesn
Posted on Jul 18, 2011
  • HP Master
  • 1,591 Answers
When the printer comes up with an error code on the front panel, we may have to perform the service test(s) related to the error code. Sometimes when we enter into service/diagnostic mode and try to perform a test, the printer may come up with system error 79:04 (non-continuable generic error). When this occurs in diagnostic mode, it is not likely possible to analyze it by pressing front panel keys (e.g., up arrow and cancel); the printer will likely be hung/stuck with the error. Solution To overcome this issue, power down the printer and then ensure that no data cable is connected to the printer (Network/USB/Fire Wire) before powering it back on. For proper use of the diagnostic menu, the printer should be in a stand-alone state (only connected to power). Once it is confirmed that the printer is in stand-alone mode, then enter back into service/diagnostic mode and perform the test(s) required.
Posted on Mar 25, 2011
    Genius:
  • 1,089 Answers
This is what I got from hp.com:-
How to update your printer's firmware using the Embedded Web Server:
- Download the firmware file to a location on your computer's hard disk. Make a note of the location.
- Browse to the downloaded file and doubleclick the file.
- In the "Winzip Self-Extractor" window choose a location to extract the files to or note the default location, then select "Unzip".
- Connect to the printer using the Embedded Web Server.
- Click on the settings tab.
- Click on "firmware update" and follow the instructions.
- Once the firmware has been updated, the printer will reboot automatically.
If that isn't working for you, try this link - www.hp.com and look at the left side of the page for FORUMS. I've had very good luck going there to get answers.
Need instructions to install a new roll of paper
The Hp 4500/20 user manual is available for down;load from the HP website and offers tips and tricks on plotter usage- very handy to have,
like I say Its FREE and easy to DOWNLOAD.
Sep 13, 2013 | HP DesignJet 4520PS InkJet Plotter Printer
I have problem with plotter hp designjet 500 ps, error 79 : 04, error with blue ink...
A 79 error most often indicates that you have a problem with the firmware for the printer. Go here and download the firmware update that corresponds to the operating system that you have installed on the computer. Follow the directions that download with the file and you should be printing again.
Aug 23, 2011 | HP DesignJet 500ps (42 in.) InkJet Printer
No tiene comunicacion la pc con el plotter portrair TW-1800P
Hello...
Pls tell me you are using it by usb or utp cable,if you are using usb cable then first check the cable if it is ok then problem in your formater card ,if you are using utp cable then first check the utp cable & if it is ok then problem in your zet direct card.
try for both solutions one by one your problem will be resolved 100%.
Regards
jm
Aug 20, 2011 | HP DesignJet 4520PS InkJet Plotter Printer
Hi, I am using an HP Designjet 4520ps plotter and am getting error 84.16:01 - Possible paper jam. There is no jam, it occurs somewhere in the middle of a print job and renders the job a waste. Any...
84.16:01 is a BT arm failure.
In the diagnostics submenu, go to 2.2 BT Arm test. Press ENTER.
If you have a failure, The front panel will display System Error Code 01.0:10.
At this point call HP if you still have a warranty. Otherwise, call a trained DesignJet tech
Jun 13, 2011 | HP DesignJet 4520PS InkJet Plotter Printer
HP Designjet 1050C Pluss - Error Code Question
Hi there only can try.
This is a firmware error, meaning your f/w simm is probably bad. You can try reseating the simm. It is behind the small panel in the back of the plotter, that is held on by 4 torq screws. Reseat all the simms that are present and see if that helps. If not, you probably need to purchase a new firmware simm.
Also try looking at
pulling the JetDirect card and then re booting it
Feb 10, 2010 | HP DesignJet 1050c InkJet Printer
The HP DesignJet T1100ps printer has a 79:04 error code. What kind of error is this and how can I solve this problem? please, help ! !
hp will never tell you but this error is a kind of a catch all error basically the service manual says to reload the firmware. check the file you are sending. i have seen a bad file cause this error. hope this helps.
Jun 09, 2009 | HP Designjet T1100ps Printer
BONJOUR MONSIEUR :JAI DES PROBLEMES AVEC MON IMPRIMANTE HP500PS
MY DESIGNJET 500 HAVE THE 79:04 ERROR IT WAS JUST CUTTING THE PAPER WHEN THIS OCURR
Mar 03, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
HP DesignJet 4520PS InkJet Plotter Printer Logo
754 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
