Question about Samsung ML2251N Laser Printer
I using samsung ml-2251n model.my problem is when i test print and never stop print.
    Problem Solver:
  • 13 Answers
I Cant understand tell me when u press the button for 3 or 5 sec than what will the printer response
Posted on Nov 14, 2013
SOURCE: network printer support how do I connect 2251N
http://uis.georgetown.edu/software/documentation/winxp/winxp.network.printer.html
http://www.stanford.edu/services/ess/pc/docs/xp_printer/index.html#anchorone
http://www.online-tech-tips.com/windows-xp/how-to-install-a-network-printer-on-your-home-or-office-network/
Setting Up a Network Printer
Preparation
In order to install a network printer, you must know your printer's Manufacturer, Model Name, and IP Address.
The Manufacturer and Model Name can be found on the printer case, an example is HP LaserJet 4000N. The IP Address can be found on a label attached to the printer. An example of the IP Address is 141.161.888.999. If your printer does not have a label indicating the IP Address, or you can't identify what model it is, please call your printer manufacturer.
1. Click on the Start button, then click Control Panel, then click Printers and Faxes, then click Add Printer.
2. A new Add Printer Wizard window opens. Click Next to start.
3. Select Local printer attached to this computer. Make sure Automatically detect and install my Plug and Play printer is NOT checked.
4. Then click Next to continue.
5. We will create a new port for your network printer. Select Create a new port.
6. Beside Type of Port, click on the down arrow, then click on Standard TCP/IP Port.
7. Click Next to continue.
8. A new Add Printer Port Wizard will open. Click Next to continue.
9. You must now type your printer's IP Address in the Printer Name or IP Address field.
10. The Port Name will automatically be filled when you enter the IP Address. Do not change the Port Name.
11. Click Next to continue.
12. IF YOU HAVE PROBLEMS, then you will see the screen on the right. This means that the IP Address for the printer is NOT available on the network. Select the Back button and make sure you entered the correct IP Address. Check to see that your network printer is powered on and displays a 'ready' status.
13. IF YOU DID NOT HAVE PROBLEMS, Windows XP will scan the network to find your printer's IP Address. This may take a few seconds. Select Finish to continue.
14. You must now select the printer's manufacturer and model. Windows XP will automatically select the detected manufacturer and printer driver. Normally, you will not have to change this selection.
15. OPTIONAL: If your printer is listed but you have more than one printer model to choose from, please select the model with PS, if available.
16. IF your network printer is NOT automatically detected, select the Windows Update button to find the proper software drivers.
Note: If your printer is not automatically recognized using Windows Update, please call your Help Desk.
17. You will be prompted to confirm the selected printer driver. Make sure Keep existing driver is selected, then click Next to continue.
18. You will be prompted to assign the printer a Name. You can use the default name, or add more info to indicate the printer location, such as My Office, Hallway, Foyer, Room 222, etc.
19. Select Yes if you want to use the printer as the default printer. Click Next to continue.
20. You will be prompted to share the network printer. Do NOT share the network printer.
21. Click Next to continue.
22. You will be prompted to print a test page. Select Yes, then click Next.
23. Check your network printer to make sure your page printed. Select Yes when prompted to confirm a successful test page.
24. Click on the Finish button to complete the Add Printer Wizard.
Congratulations! If your test page printed, you have successfully installed the network printer.
Note: If you had problems and did not get a test page, please call your printer manufacturer.
Posted on Mar 30, 2009
  • 3278 Answers
SOURCE: I have a samsung ml-1710 laser printer. Was wrking
Power off the printer, disconnect/reconnect the printer cable, power on the printer, reboot your workstation.
If that doesn't work, in Control Panel - Printers, delete the icon for your printer. Disconnect the printer cable. Reboot your workstation and log in. Reconnect the printer cable and see if the printer is recognized. Install the printer driver.
Posted on Jun 12, 2009
  • 406 Answers
SOURCE: Samsung ML-2010 prints test page but doesn't
tHIS MAY be a problem of the software. or if the printer does not recognise on any PC then the problem in the main board of printers.
Posted on Nov 15, 2009
SOURCE: samsung ml-2510 printer red light on, doesn't print
yes
Posted on Feb 17, 2010
SOURCE: Samsung ML-2510 Printer will not work with Macbook Pro - OS X
try to use the Generic drivers and not the Samsung ML driver for your model. In the drivers list type in GEN and it'll show up.
Posted on Apr 27, 2010
My samsung ML-1640 wont work.but still can print test print. how to reset ML-1640?
Hi there!
You can try to reset your printer using reset software. Just go to www.nakshatraworld.com
Hope this helps.
Mar 30, 2011 | Samsung ML-1640 Monochrome Laser Printer
TENGO DAÑO DEL RODILLO
you can use an other pick up roller which is located in bypass cassette. and change it to cassette 2 and use for couple of years.
Nov 29, 2010 | Samsung ML2251N Laser Printer
Dec 12, 2009 | Samsung ML-2510 Laser Printer
I am using samsung ml 2245 monocrom printer.. after printing 2*** print with the demo toner... it stop working and giv the error of toner exhuated..i refil the toner only single time.. plz tell me how to...
We have software to reset your printer
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Jun 11, 2009 | Samsung ML-1640 Monochrome Laser Printer
Samsung ml-1250 Printing stopped
Try purging the 3 pending print jobs then try to print again. Go to Printer and Faxes on XP, then right click on your printer icon then select purge print jobs. Or double-click on the printer icon on your system tray (lower right hand of the screen) then click on the pending print jobs then purge it. Then try to print again.
Oct 21, 2008 | Samsung ML 1250 Laser Printer
Samsung ML-2510 will not print from MAC OS on Macbook
I had the same problem and spent some time trolling the Net. But....I found it.
Run installer from CD.
Tthen go to system preferences > print and fax
Delete the ml-2510 by clicking the minus square
Click the add square..
Select the ml-2510 again, and make sure that at the bottom of this window, under the "Print Using:" field, you again select the ml-2510.
Click add.
That's it! You're good to go!
Aug 05, 2008 | Samsung ML-2510 Laser Printer
Samsung ML2251N Laser Printer Logo
75 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
