Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
I have a single line that is aprox. 1.5 inches in on the edge of the screen. The line mainly is black but also appears red. It is a vetical line and to top it off it goes away once in awhile just to make my day complete. This Tv has been flawless till this point and on HD or Blueray blows away higher priced units. The tv is a kdl46w4100 lcd 120 hz . I'm On Bell sat and all my hdmi are top end monster cables. There is a well used Wi connected to it any help would be great ..........Thanks Shane
  • 1,591 Answers
You probably have a bad solder joint on one of the matrix controllers.
Below is an example on a smaller LCD, but it will give you an idea what you are looking for.
As you can see, there are several controllers and each controls a "strip" of pixels
If a solder joint lets loose then that strip will go black or become distorted in color.
To make your day more complete, the vibrations from the speakers will occasionally cause the connection to reconnect, making it a bit harder to locate the EXACT pin that came unsoldered.
In these cases, it's best to put liquid solder flux across all the contacts on that controller and resolder all of the pads on that controller.
These connections are extremely close together though, so make sure you have adequate magnification to check for solder bridges after resoldering the controller to the board.
If your soldering skills aren't great, you may want to have this done at a shop - just don't let them tell you that you need a whole new screen right off the bat. It's almost always just loose solder and not a defective controller, especially if the unit self repairs once in a while.
Posted on Mar 25, 2011
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
Lines on screen
i have, a lg pdp50x30010 it has a white screen with vetical colour bands which move across screen can have replaced main board and av board and driver panel can you help pls.
Jan 09, 2014 | Curtis Klu 7-inch Touch Screen Mobile...
I have dell vostro 1014 laptop. there was a vetical line appeared on its screen of green colour 3 days ago and graduaaly more vertical lines are appearing of red colour.what should i do please help me....
press the back of it & you'll notice they will go away let go & they come back.
the screens bent either way you look at it you need a new screen.
i've tried to fix this problem twice before & twice i've cracked the glass trying to straighten them.
now i just put a new screen in them.i'll do it cheap click link:
T-ComTech Computers
Sep 30, 2010 | Computers & Internet
The convergence is off. When I try to use touch
Ok, we go to solution of your problem===The pico fuses are green and on the main power board--have you removed the back and looked inside--most of these sets have the two STK-392-110 on the main board to the right-they are usually on the left edge of this board on two very large metal heat sinks--chips are about 2 1/2 inch wide X 1 1/2 inch tall--is this how your set looks inside? they will have the number printed on the black face of each chip in white--The fluke meter will allow you to check all the grey protect resistors--most are 1.8 ohm and the pico fuses will be near the edge of the board to the left----All I expect from you for help is a vote here--if you remove the back do you see the chips?
Sep 19, 2009 | Toshiba 42H82 42" Rear Projection...
Black vetical lines on the screen. how do u fix
You need to flash or update your computer's bios. if you have an inspiron 1501 go here:
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R174470&SystemID=INS_PNT_1501&servicetag=&os=WLH&osl=en&deviceid=13120&devlib=0&typecnt=0&vercnt=9&catid=-1&impid=-1&formatcnt=1&libid=1&fileid=236967
read the installation instructions or print it. then download the file and follow the instructions. after restart. see if you still get the vertical lines.
Mar 02, 2009 | Dell Inspiron E1505 Notebook
Dave
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Jan 25, 2009 | Akai PDP-4247 Television
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Black vetical line
It's either x-main or logic board... Take it to a qualified shop and I think you'll be impressed... Most of these are repaired at module level now and it makes the repair relatively inexpensive.
Bill
Nov 19, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
