Question about Samsung SCX 4521F All-In-One Laser Printer
It doesn't load paper,when paper was load in a tray,the paper was loaded in jam and also gone in bango.
    Scholar:
  • 103 Answers
Welcome to FixYa.
If the printer don't load paper, please follow the following steps.
1. Check the printer make sure no scraps of paper are stuck inside the printer.
2. To check remove the door at the back of the printer.
3. If you paper try to pulled the paper jam.
4. Double check again if there is scraps of paper.
5. Then put back the door of printer.
6. Then, Disconnect the USB cable from the printer.
7. Disconnect the USB cable from the computer.
8. Leave the cable unplugged for 5-6 seconds.
9. Reconnect the cable to the printer and computer. Ensure the printer is connected directly to the computer through a USB cable or power USB hub.
10. Restart your computer.
Hope this information will help.
Thank you for using FixYa.
Posted on Mar 25, 2011
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
I have a hpj6480 printer. It says paper jam. I've done everything, turned off removed every piece to clean out, pushed every imaginable button...still paper jam it reads....
Below are the causes of paper jam
  • Paper loaded incorrectly in the paper tray.
  • Damaged or dirty paper rollers.
  • Torn, wrinkled, or damp paper loaded in the paper tray.
  • The rear access door or two-sided printing accessory (duplexer) might not be closed or is not locked into place.
  • Paper was added to a stack already in the tray while the HP product was printing.
  • The tray contains more than one type of paper.
  • The paper is jammed inside the HP product where you cannot see it.
  • An obstruction is blocking the paper path.
  • Torn pieces of paper from a previous jam are stuck in the product.
  • The tray is too full.
  • If printing on an envelope, the edges of the envelope are bent.
Try steps provided in below link and check if paper jam is resolved.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c01312792
GuruAid.com
Oct 30, 2014 | Office Equipment & Supplies
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
Paper keeps jamming. we get a partially printed page,then jams about 2/3 of the way and we have to pull it out.
You can avoid most paper jams by correctly loadingpaper and other media in the printer. Tips on how to help prevent paper jams · Do not loadwrinkled, creased, or damp paper. · Make sure thepaper is not buckled in the tray. · Never mixpaper/media types within a single tray. · Flex, fan, andstraighten paper before you load it. · Do not exceed themaximum stack height. · Push all papertrays firmly into the printer after loading them. · Make sure theguides in the trays are positioned snugly against the paper. · Do not remove anypaper trays while a job is printing. Wait for a Load Paper light sequencebefore you remove the tray. See the 'Load Media' section on page 61 of theUser's Guide for more information. · Use onlyrecommended paper. Consult the CardStock & Label Guide on the Lexmark web site for more information aboutwhich paper provides optimum results for your printing environment. For additional assistance, please contact LexmarkTechnical Support.
May 31, 2011 | Lexmark E232 Laser Printer
I keep getting a printer jam when trying to print, I clear the jam and then it sticks again, wither in the tray, the inner door or the fuser, any ideas appreciated..
Please check the error code when paper jams. The code will indicate where the jam is. Also let me provide some tips to prevent paper jam.
Flex, fan, and straighten paper before loading it. Make sure the paper lies flat in the paper tray. Do not load too much paper. Make sure the stack height does not exceed the indicated maximum height. Make sure the guides in the paper tray or the manual feeder are properly positioned and are not pressing too tightly against the paper or envelopes and push the paper tray in firmly after loading paper. Use only recommended paper or specialty media.
Do not load wrinkled, creased, damp, bent, or curled paper. Do not mix paper sizes, weights, or types in the same stack and make sure all sizes and types are set correctly in the printer control panel menus.
For Further Assistance, please contact Lexmark Technical Support.
Mar 14, 2011 | Lexmark C534dn Color Laser Printer
Copier jamming/copy printing sideways
If it jams every copy then it sounds like the paper tray size is not programmed properly. This is also why the print is the wrong direction on the page. So the copier thinks it has 8.5X11 loaded like this > -- and instead it is loaded like this > |
I hope that makes sense. So this not only causes the print to be the wrong direction but since the paper dimension are different that what the machine expects then it throws the sensor timing off and results in a paper jam. So just open your paper trays and check the paper size dials in the trays to make sure they match the paper size AND direction of the paper loaded into that tray.
Good Luck and Thank You for using Fixya.
May 13, 2010 | Canon imageRUNNER 2200
LaserJet 2420 Printer: hp 2420n 13.20.00 jam inside rear door...
i have 2420 dn printer..printer reddy mode the power on...but not initlizing...13.20 paper jaming error coming but paper is not jam..hw to resolve
May 06, 2010 | HP LaserJet 2420 Printer
Brother printer jams all the time
Be sure the paper tray is not over full and maybe even fan the paper before loading. Check all the corners that hold the paper as they are usually adjustable for different paper sizes and sometimes move or become unattached. The paper must lay flat and snugly in all places in the tray to load properly.
Mar 28, 2007 | Brother MFC 420CN All-In-One InkJet...
Samsung SCX 4521F All-In-One Laser Printer Logo
48 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
