Question about LG L1922P 19" LCD Monitor
Where do I connect the speakers to the monitor. I have a Flatron L1922P monitor. I ordered 2.0 USB Multimedia speakers that come with a 3.5mm stereo plug and USB plug. I must not being doing something right because when I plug in the usb plug I still get no sound. Help! Vicki
    Scholar:
  • 84 Answers
Your speakers do not plug into your monitor. Your speakers should be connected to a USB slot on your PC tower and the 3.5mm stereo plug should be put into the green stereo jack on your PC tower. If your audio jacks on your PC are not colour coded, then you should look for the jack which has a picture of a set of earphones over them.
Depending on your speakers, you may or may not be required to keep the stereo plug connected in order to get sound. Some models transmit model over the USB connection and others just use the USB connection as a way to supply power to the speakers and need the stereo plug to be connected in order to have sound. I suggest trying both.
Posted on Mar 25, 2011
How do i change speakers
There are couple of questions to ask , are u trying to connect the speakers to the monitor for a tv connection or using it to connect to a computer system , if connecting to the computer system , the audio settings have to be changed to the current speakers you connect to the monitor , or there might be a up link cable u might have got when u bought the monitor using which the sound will come out .
Dec 14, 2014 | LG FLATRON M237WD 23 inch LCD Monitor
I connected a flatron w1952tq to my computer and I have video but no audio. How do I fix it
do you have speakers on your monitor? If yes, check the wire connecing hte sound to the speakers
Jun 11, 2014 | LG Flatron L1951S-SN 19" LCD Flat Panel...
I just got a multimedia surround system with subwoofer.Spa7650/05, 180w.The subwoofer has three audio connections,front,centre and rear,My tv only has an audio coaxial.I can't connect it.What adapter...
Firs of all lets get agree on something..The subwoofer has three audio connections for "output " to :front,centre and rear speakers...these are not for "input"..Your powered SUB provides necessary signal for other spekers..
You can connect TV audio coaxial to SUB input with a RCA cable.....if your SUB does not have "RCA input " probably it should have "3,5mm Haedphone female Jack"..
if this is the case you need to buy a cable ; one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 22, 2011 | Philips Audio Players & Recorders
Bose speak cable was accidentally pulled out of computer and I cannot understand how/where to plug it back in. Dell xps 420
The 3,5mm jack from your speakers must be connected at the GREEN 3,5mm female jack (at the back panel of your dell, NEAR the blue, orange and black jacks, just above the USB connectors). Maybe this photo will help you:
In case you have another audio card and you're not using the onboard with the computer, the connections is a little different. In that case post a reply to clarify for you.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 20, 2010 | Bose Companion 2 Series II Multimedia...
No sound, other monitors have a input jack for sound but not this one.
Some monitors have built-in speakers and others do not have them.
In this case you need to purchase separate external speakers to connect into your computer. If your computer has audio output for surround sound, then you can buy 5.1 surround sound speakers. These will have 2 front speakers, 2 back speakers, a center speaker and a sub-woofer speaker..
Jun 04, 2010 | LG Flatron L2320A 23" LCD Monitor
I need to know how to hokk up speakers with it
Hooking up a speakers to the monitor depends on the connections that you have.
1. What type of speakers do you have? Is it a regular computer speakers (2-channeled or multimedia)?
2. Does it have a 3.5mm jack or an RCA jack?
3. Does the monitor has a speaker ports?
If the monitor doesn't have a speaker ports were you can connect you speakers, then it's not possible. Meaning that you could only connect the speakers to the computer.
Aug 04, 2009 | NEC Computers & Internet
No sound on viewsonic VG730m
you have to connect it via audio cable.
you need a cable with two 3,5mm stereo jacks. this you have to connect with the stereo output of your computer (mostly the green one) with the audio jack on your monitor. it's somewhere on the back i think. sound / volume control you do in windows - its the same as if you connect normal stereo speakers to your computer.
(perhaps you have to unmute or to raise the volume in the monitors os menu)
Jul 23, 2009 | ViewSonic VG730M LCD Monitor
Connecting to the onboard speakers on the flatron 776fm monitor
You simply need a miniature stereo audio cable.  Radio Shack carries them.
srich
May 27, 2008 | LG Flatron 776FM 17" CRT Monitor
LG L1922P 19" LCD Monitor Logo
167 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
