Question about Watches
How do i open the Roxy Jam Watch with a stainless steel butterfly clasp
ItsRixTime
SOURCE: how do change a battery of a watch?
If you do not have the proper tools,(proper tools are recommended) and depending on the type of backing, this may help you :
  1. Locate a very small tab (or recessed area) on the edge of the back cover. This is the access point for removal.
  2. Get a kitchen knife with a rigid blade. It doesn't have to be razor sharp, it only needs to be inflexible. You can also use a small fine screwdriver.
  3. Very carefully slide the blade under the tiny metal protrusion on the back cover (or across the length of the recessed area, depending on which type of cover your watch has). Do not attempt to insert the point of the knife. Use the length of the blade.
  4. Get under the tab or recessed area and gently but firmly turn the blade upward, popping the cover off.
  5. Locate your battery(Small round disc type) remove and check the numbers on it. Go to most any local dept. stores (Wal Mart, Target, Radio Shack, etc.) and purchase same.
  6. Install battery with numbers up.
  7. Place cover over watch, and snap back into place.
Hope this helps. If not, please let me know and I will get back to you.
Posted on Feb 07, 2008
SOURCE: how to set up ladies roxy digital watch
I found users instructions on roxy website at:
http://www.roxy.com/search/index.jsp?f=Taxonomy%2FROXY%2F2818169&categoryId=2818071&f=Taxonomy%2FROXY%2F2818071&fbc=1&fbn=Taxonomy|Watches&fbx=0
We were able to program our watch completely!!!
If you look on the back of the watch that you bought on the metal plate, it tells you the style. Ours was the Roxy 70's digital watch, and I found specific instructions at (even if this is not your style, the instructions may work):
http://www.roxy.com/graphics/uc/roxy/manuals/Roxy_manual_watch_70s.pdf
Posted on Dec 23, 2008
SOURCE: Watch clasp on Tag Heuer
http://www.worldofwatches.com/cust/sizingwatch.asp?d=0
Posted on Dec 26, 2008
escapement
  • 2334 Answers
SOURCE: stainless steel band adjustment
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 19, 2009
  • 19 Answers
SOURCE: How do I remove watch band links from m Stainless
I've got a great article that helped me out with this same problem! I thought this article explained things pretty well. http://hubpages.com/hub/How-to-Size-a-Watch
Posted on May 24, 2010
How do I open the band?
How to adjust your watch band - YouTube
? 7:52
https://www.youtube.com/watch?v=Y37okQAN7uA
Jun 16, 2010 - Uploaded by WatchDudeMark
In this video I will show u how to size your watch band with around the ... didn't need to watch it as you're obviously too fxcking useless to do ...
How do I open the band? - Fixya
www.fixya.com/support/t26047908-open_band
33 mins ago - Generic Ladies TFX Stainless Steel Watch W/ Rectangle Face ...watch? The clasp won't open and I didn't want to pay $65 just for a new clasp.
Your Guide to Adding and Removing Links in a Bulova Watch
www.ebay.com > ... > Jewelry & Watches > Watches > Wristwatches
Jan 10, 2016 | Generic Ladies TFX Stainless Steel Watch...
How do I remove a link in the steel wrist band on my watch
no details or photos so the best advice is to take it to a watch shop or jeweler and have it done
Dec 15, 2015 | Watches
Skagen watch - 233 SGS - the clasp on the stainless steel bracelet is not secure - the clasp comes undone in normal use - nothing energetic - and the watch falls off - been lucky so far as have either...
Hi ,
i would contact Fossil group as they are the manuafcturer of Skagen watches . looking at the model it uses a slider type clasp.
the metal on the locaking part can be easily bent causing to come undone.
Aug 25, 2017 | Skagen Watches
HOW OPEN INVICTA WATCH CLASP
Look at this video
https://www.youtube.com/watch?v=dkAoxVYtjXQ
you'll see the clasp as it look s when open. You need to hold the strap and clasp near one side of the 'join' while pulling the upper part of the strap away from the clasp on the other side.
Jan 11, 2012 | Invicta Square Angel Diamond Stainless...
I have a roxy candy watch and I can't figure out how to reset the time. Please help!
Current Roxy watches can be found here:
http://www.roxy.com/family/index.jsp?categoryId=2818071&searchSort=TRUE&pg=1&f=Taxonomy%2FROXY%2F2818071&s=D-ProductAge&fbn=Taxonomy%7CWatches&fbc=1
I don't see a "candy" model but there are some called "Jam".
If one of these is similar to your model, click on the picture of the watch, a new page will open. Under the color choices on the right side you will see a link to the Manual. The manual will have setting instructions.
Apr 03, 2011 | Watches
I need an extra link and the receiving end clasp for my fossil steel fs 2700 watch. Anyone know where to get?
Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care" and then look under "Product Info" on the left and you will see "0rdering links and bands"
Feb 14, 2010 | Fossil Stainless Steel and Leather...
Butterfly clasp on vostok watch
sadly there is no warranty that lasts 9 years . try any good local jewelry shop many do repairs .at least here in the US they do
Nov 13, 2017 | Vostok Europe "Pobeda" Watch
Pin that holds metal band clasp is missing
If it is only the pin that holds the metal band, this is an extremely inexpensive part that is available at most stores that sell watches.
May 24, 2009 | Casio G-Shock MTG900DA-8V Wrist Watch
How to open Baume & Mercier Hampton Milleis ladies stainless band
Looking at your watch it looks like the clasp on the SS model is just a double deployant preasure fit. If it is brand new sometimes these style of deployants are vary tight.
It is Stainless Steel it is vary difficult to break it looking at the construction of the bracelet.
Basically you just Pull, there is no button it is just pressure fit.
mike -- consumerwatchguide.com
Jan 01, 2009 | Baume Et Mercier Hampton Milleis MOAO8242...
Watches Logo
1,300 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
