Question about Sony CDXGT740UI InDash MP3WMAAAC Player
When there's no Ipod plugged into the front USB port on my Sony CDXGT740UI it displays the usual NO DEV. When I plug my Ipod into it seems to fail to recognize the Ipod and I get NO SUPRT on the display. I've tried two different Ipods with the same result. How do I fix this?
  • 902 Answers
Common issue with the sony models your usb port is bad. easy fix is auxilary cable input in the front from ipod or back in the unit but cheapest is a 10 dollar adapter for fm / blu tooth streaming. theres your solution thumb me up sorry bad news bout the usb
Posted on Mar 25, 2011
Crosely won't play usb
If it's a turntable with a usb connector, those connections are usually outputs only. USB on a turntable is used to output the audio to a computer to rip albums to digital audio.
Jun 17, 2013 | Crosley Audio Players & Recorders
My ipod wont show up on the bar when i plug it in the itunes
Sometimes your iPod fails to display in iTunes, which will keep you from being able to transfer songs from your computer to your iPod. If this happens, there are a number of steps you can take to resolve the issue.
Is it the iPod? Your iPod could fail to show in iTunes for a variety of reasons and this issue can be resolved by something as simple as rebooting your iPod. To reboot your iPod, first lay it on a flat surface. Using your thumb and index finger, press the play and menu button at the same time. If done correctly, your iPod screen will go blank and then you'll see the Apple logo. Is it the USB cable? Your iPod could fail to show in iTunes if you are using a defective USB cable. Try connecting your iPod to another computer that has iTunes installed using the same USB cable. If iPod again fails to show in iTunes, replace the USB cable. Is it my computer? One of the most common reasons your iPod doesn't show in iTunes is because your computer doesn't recognize your iPod is connected. Troubleshooting your computer/iPod connection Disconnect your iPod from the computer and reconnect. If your iPod still doesn't appear in iTunes, disconnect your iPod and reboot your machine. Once your computer has restarted, reconnect the iPod. Is it iTunes? Your iPod could be fail to display in iTunes if there is a issue with your iTunes program. If there is a problem with iTunes you can try updating the software to the most recent version. If that doesn't resolve your problem, re-install iTunes. b> http://www.itunes.com/ b> http://www.apple.com/support b> iPod Won't Connect to iTunes b> Apple's iTunes software contains mechanisms specially designed to sync with your iPod, allowing you to transfer music, videos and other media from your computer. If you find that iTunes does not recognize or allow you to access your iPod, then you cannot perform some of the device's most fundamental functions. Fortunately you can often resolve this problem without expensive maintenance, simply by doing a bit of troubleshooting and determining the cause of your connectivity problem.
Try resetting your iPod. Apple recommends this as a first step in troubleshooting an iPod not appearing in iTunes, since a quick reset will often restore functionality. If you use a click wheel iPod, hold down the "Menu" and center buttons until the Apple logo appears on your screen. For the iPod Touch, hold your "Home" button and "Sleep" button simultaneously until the Apple logo appears. Charge your iPod battery. If your battery has absolutely no power left, your iPod will often remain unresponsive even when plugged into iTunes. Try charging for three to four hours and then try connecting again. Plug your iPod into your computer using a different USB port. Sometimes a failed connection can mean you have a faulty USB port, so try plugging your USB cable into a different port and see if the iPod appears in iTunes. Verify that you have the latest version of iTunes. Visit the iTunes page Apple.com and check to see the latest version available. If you do not know which version currently runs on your computer, click "About iTunes." For Mac users, this option will appear under 'iTunes" on your menu bar. For Windows users, the option will appear under "Help" on your menu bar. Download the latest version of iTunes if necessary. Reconfigure your iPod service. If running iTunes on a Windows computer, click "Start > My Computer > Manage," and select "Services and Applications." Under "Services," select "iPod Service" and click "Stop." Leave the window open and connect your iPod to your computer. When your iPod shows up on your computer, click "Start." Reinstall iTunes. If simply updating iTunes does not work, you may have defective software. Try removing the program from your computer and completely and reinstalling it.
Jan 29, 2013 | Apple iPod touch
My sony nex f3 camera is on usb mode and it says its connecting but I havent plugged in the usb cable. I tried every button but I can't seem to fix this. It also says ' check the connected dev
I just had the same problem. It was the wrong cable. The correct cable should have like a fat rectangular object next to the port on the end connected to the camera. So make sure its the original cable or it will continue to say that.
Jul 05, 2012 | Cameras
Computer says this drive is not accessible. It has worked fine for two years. It will work on my laptop. I am using Windows Vista
A couple of things here. First, make sure your usb ports are working on your computer. Try plugging the unit into a different usb port. For example, if you usually plug it into the back, try plugging it into the front. If this doesn't work, get a "Powered" usb hub. Your usb ports work on 5volts. Even when they start to fail, they will recognize "non powered" devices like thumb drives or camera cards. Another issue is that the power supply may be failing. Make sure you're using the power supply that came with the drive. If you say it works on your laptop, I'm thinking that your pc's usb port might be failing. A powered hub should resolve this issue. Hope this helps.
Jan 04, 2011 | SimpleTech FS-U25/500E 500 GB USB 2.0 Hard...
Suddenly my pc re-boots when I plug my ipod into the front usb.
uninstall service pack 3 and ignore it when it asks you to re install it. go to add remove programs and uninstall it. obviously it worked befor. that is the solution. you dont need sp3 anyway.
Jul 18, 2009 | Gateway Computers & Internet
IPOD SAYS "PLEASE CONNECT POWER DEVICE" BUT IT IS PLUGGED IN
try updateing your itunes or letting ur ipod charge
Feb 25, 2009 | Apple iPod nano
IPod connection problem with Ford Focus
I think you have to connect both the line-in to the earphone-connector and the USB to the USB-connector on the iPod.
Don't ask me why, but that seems to work (according to another Dutch forum http://www.focusclub.nl/forum/viewtopic.php?t=4201&sid=be5c9f538bd310a274324907aff98513). I haven't tested it yet (don't have a line-in to line-in cable).
Jan 09, 2009 | 2008 Ford Focus
IPod Nano not recognized when plugged to USB
Make sure your not pluged into a USB hub. It will work if its plugged directly into a USB port on your computer.
Jul 14, 2008 | Apple iPod nano
IPod is not recognized
i have the seem probleme since i have installed a new firmware somone know where to find the original firmware ?
Dec 28, 2007 | Apple iPod MA446LL/A MP3 Player
Sony CDXGT740UI InDash MP3WMAAAC Player Logo
109 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
