Is it possible to connect two jacks simulteanously to a speaker like S115 or SW118 coming from 2 different channels of a power amplifier like P5000S' please advise thanks
  • 1,591 Answers
The s115 and p5000s are power matched for a single channel.
IE - the s115 is rated at 500W and the p5000s is 500W PER CHANNEL.
If you're trying to drive a left/right signal into a single speaker, you need to mix the left right signals together at the input side, and put the mix into a single channel of the amp, and then into the speaker from that one channel.
The other option is to have 2 s115's - one on each channel.
Posted on Mar 25, 2011
2 speakers and 1 powered sub
The red and black connectors are the right (red) and left channels for the speakers, so they should connect. However the sub needs a single RCA type phono socket, which should be marked "sub" etc. If it hasn't got one of them you will have problems connecting the powered sub.
Jun 07, 2013 | Crown CE1000 2-Channel Amplifier
Service manual Yamaha p5000s
www.retrevo.com/support/Yamaha-P5000S-Amps-manual/id/962bh143/t/2Free download of Yamaha P5000S User Manual. Troubleshooting help from experts and users. ...
Apr 18, 2012 | Yamaha STEREO POWER AMPLIFIER 750X2 @4...
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    Sound is only coming out of one side.
    check speaker wires connected to amplifier try to swap it between right and left speaker do the same to audio input jack (usually RCA jack). If it still works one channel only, probably the problem is in the power amplifier
    Apr 03, 2011 | Audio Technica ATH-M30 Professional...
    CAN I CONNECT BOTH MONITORS AND SPEAKERS (S215 AND SM'S) TO A YAMAHA P5000S AMP?
    You could use this amp as effectively 2 separate mono amplifiers - using one channel to power the monitors and one to power the main speakers.
    Alternatively you can run the amp in stereo connecting one set of speakers to the neutrik outputs and one to the jack outputs. In this case the amp output will be shared equally between the two sets of speakers, which are in parallel, and the combined impedance must be not less than 4 ohms.
    Feb 26, 2011 | Yamaha P-5000 Amplifier
    How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
    :) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
    Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
    Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
    for example a basic music system is
    1 cd player
    1 pre amp
    1 amplifier (4 inputs, 4 channel out)
    you bridge 1+2 and connect this to 1 12" double coil sub woofer
    the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
    Thats a kicking tricked out basic car audio system,,,
    Hope that helps you understand how it works..
    Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
    Amp Power light will not go on. Protection light is lit- Thump sound in speakers
    It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
    Amplifier in Protect Mode - Troubleshooting
    Let me know if you have any other questions.
    Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
    Multipal amps
    make sure your speakers are connected correctly if subs and are inside the box then check connections also at times the rca at the back of the head unit can disconnect. if power light is on then error is either speakers not connected correctly, rca faulty or not connected or speaker output on amp is blown
    Jan 03, 2008 | Kenwood KAC-7202 Car Audio Amplifier
    Gem Sound XP-350 both channels failed
    Speaker fuses are generally fast-blow styles 250 volt glass
    If an amp shuts down, with speakers connected, it sounds like one of the power supply lines does NOT like what it's "seeing" . Probably output transistors bad ( or module)
    Take it to a tech.
    Scott out.
    Dec 02, 2007 | NAD C350 2-Channel Amplifier
    41 people viewed this question
     Grubhead
    Grubhead
