Question about Cameras
The mirror is halfway up, and will not move when you actuate the shutter, for my Pentax MZ-30. Any button I push or switch I move, makes the camera make a whinning sound and nothing happens.
  • Anonymous Apr 23, 2009
    nikon d70 mirror stays halfway up and won't move, also no flash
    Problem Solver:
  • 6 Answers
Try to remove the battery with the camera in "OFF" then reinstall the battery (make sure the camera is off) and set your top right dial to the "P" (Pict position). Make sure the switch to the lower right front of the lens mount is set in AF. The n power the camera body back on. This should resolve the problem.
If not there may be a foreign material jamming the mirror.
Posted on Apr 23, 2009
MIRROR WILL NOT RETURN TO POSITION LENSE BLANK
The mirror motor on most KX, MZ, and other late model Pentax film cameras has a small plastic gear on the shaft that cracks, so that it will not drive the mirror up or down. Pentax originally replaced it with a larger gear made with better plastic, but they had problems with those also, so the eventually went with a brass gear
I don't believe the part is available any longer, or so I was told last time I tried to order one. Which is fine with me, as they are a real pain to work on and I do not recommend you try and fix it yourself.
Sorry
Jul 06, 2012 | Pentax MZ-7 Film Camera
Canon 40d will not take pictures
1) CF card in camera? Won't shoot without one
2) Does mirror go up?
3) Canon had a run of bad motors for this model - if mirror does not go up, then it is the mirror motor. If mirror goes up, shutter will not fire, press release again then the mirror goes down, the shutter motor is bad (same model motor). If mirror goes up, shutter fires, both blades travel together/no exposure, probably the shutter is bad.
May 07, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
Pentax ME Super: Mirror sticks in DOWN Position
The shutter & mirror is in need of a CLA. Clean, Lube & Ajustment. Its well needed for any camera when they are 20 years old and older
Feb 19, 2009 | Pentax ME Super 35mm SLR Camera
Pentax ME Super Shutter and Rapid Wind Button...
anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
Dec 24, 2008 | Pentax ME Super 35mm SLR Camera
Shutter
kirstyanne00,
open the film door and check the shutter blades. did you accidentally push the blades in when loading the film? if so take the camera to a camera repair shop, the technician may be able to reset the blades while you wait.
or send it to pentax repair center for an estimate cost to repair.
Oct 25, 2008 | Pentax MZ-50 35mm SLR Camera
Black viewfinder
Slr mirror is stuck. remove the lens and try to slightly move the mirror up and down ( but not forcing it to move!)and pushing the shutter switch. Try also applying lighter fluid in the mechanism while operating or shooting, fluid will help loosen the stucked mechanism.
Aug 31, 2007 | Pentax ZX-7 35mm SLR Camera
Shutter wont fire, or auto focus
This sounds like mirror box motor problem ( see enclosed shot from our workshop ) : this cocks the shutter and controls mirror mechanism and when the drive dosnt work properly ( small nylon gear on the motor goes ) camera will develop the the sort of problems you describe.
Can be repaired but will cost $ 150-200 so it is relatively expensive repair.
Jun 01, 2007 | Pentax MZ-50 35mm SLR Camera
Pentax MZ 50 film winding problem
Well, I'm not a camera repairman, but it sounds to me (and probably to you too) that the electronics are damaged or perhaps there's dust in the contacts inside. I also have an MZ-50. There's so many electronics involved and they don't age so gracefully. I would consider buying another one off eBay or you can get a ZX-30 (same as MZ-30) for $75 from Blue Moon Camera & Machine with a 1 year warranty (parts and labor). The best way would be, in my opinion, to get a manual, mechanical camera from the 1970s and put a good lens on it. Those seem to last forever. No electronics to worry about. Advance and rewind the film manually. You can use a digital camera as a light meter to set the aperture and shutter speed. I'm thinking of going this route when my MZ-50 finally conks out.
Apr 25, 2007 | Pentax MZ-50 35mm SLR Camera
Cameras Logo
54 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
