Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Intermittantly low cooling - Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
  • 132 Answers
Sounds like the thermostat is getting a little worn out.
A new thermostat would probably fix the problem
Posted on Mar 25, 2011
1992 chevy C1500: Heat works on low speed, no medium, and high only works intermittantly.
On any other vehicle it sounds like the blower fan switch.
The fan switch provides power or ground to the resistor and there would be a high speed blower relay to bypass the resistor.
But in your case the fan switch is part of the controller.
I don't have a diagram for a 92 but the 94 model shows relays for low medium and high speeds. Each relay gets power from a fuseable link. The high relay gets power thru the low relay if the low relay is not engaged.
If you have the model with 3 relays you may need to check them.
Feb 01, 2013 | 1992 Chevrolet C1500
Front end of divider between refrigerator and freezer is getting very hot to the touch. both sides still working okay... just concerned that the frig may burn out or cause an electrical fire.
The area you are describing is the breaker panel, inside is a heater called a mullion. The purpose of this heater is to control any moisture that may form due to the temp difference (Dew Point) inside and out. This excessive heat you are noticing is a for-warning of bad things to come (compressor damage, spoiled food). The most common reason is not keeping the condenser (different types, designs and locations depending on make and model) clean. Recommend inspect and service every 4 - 6 months. A condenser brush (looks like a over sized bottle brush) and a vacuum with a wand is used. If never done before, service front and back, mybe power clean with reverse blowing vacuum after getting the heavy stuff out. After cleaning, give 24 hours, if no major damage to compressor or condenser fan motor, the system should return to normal, breaker panel will cool to average 10 - 15 dgs above ambiant. Other issues that it could be; weak compressor, bad - intermittantly operating condenser fan, doors intermittantly left ajar, bad - low RPM evap fan motor, cavity lights on when doors closed.
Ric
Mar 10, 2010 | KitchenAid Superba Architect KSCS25INSS...
Intermittantly not going into reverse.
check fluid. linckidg.go to your micanic.
Jan 25, 2010 | 2001 Chevrolet Blazer
Cooling fan intermittantly speeds up.
This is normal
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
Aug 25, 2009 | HP Computers & Internet
Power steering and dashboard power goes out intermittantly
check for a loose ground or harness conection
Jul 07, 2009 | 2007 Toyota Yaris
HOT OR NOT
You really need to look at Edmonds.com for the Recalls, Service Bulletins and Complaints on this Blazer! Luckily I found a Buyer for Mine Before it Got Worse! Not that it was Good!
Feb 03, 2009 | 2000 Chevrolet Blazer
Cooling system bleeding
Faulty thermostat or water pump.
Jan 03, 2009 | 1999 Pontiac Grand Am GT
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
