I can't get a dvd to load in my mac. It used to work.There isn't anything stuck in it, but the disc doesn't load. I push it in and it sits there part way out. is there some kind of motor failure?
    Sergeant:
  • 296 Answers
Yes. It's part of Apple's business strategy.
Posted on Mar 25, 2011
Can't get a disc out of my mac
There is a small hole on the front of the drive or on the actual loading door itself. Staighten out a Paperclip and stick it in the hole. Push and the loading tray will open. If you have the disc loaded wrong it may take a little "extra" push to open it up This works on all CD or DVD loading trays in your life
Nov 13, 2012 | Computers & Internet
My Sony dvp NS710H isn't playing most standard, well conditioned DVDs.
Hello
Just clean its laser pickup lens, by inserting a lens cleaning disc in to, and play it at least two times. If it doesn't help you, the laser pickup unit should be replaced. The lens cleaning disc can be bought from most of the electronic sparepart selling shops at your town, and won't cost more.
Feb 27, 2012 | Sony DVP-NS710H/B DVD Player
Hey my mac won't eject a disc. i have tried a lot of stuff and nothing happened. when i restart it the disk spins and doesn't sound stuck and when i used disk utility it said there was an error...
Resolution Tip: Make sure the CD or DVD disc is not in use. Quit all applications that are using files on the disc.
  1. Press the Media Eject key at the top-right corner of the keyboard.
  2. If that doesn't work, drag the disc's icon to the Trash.
  3. If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected.
    To restart, choose Restart from the Apple menu.
Aug 16, 2011 | Computers & Internet
Dvd is stuck
Before you remove the DVD player cover, try turning the device off and then back on to see if the disc will come out after the machine has rebooted.
  • Use the opportunity while you have the outer casing off to clean the lens of your DVD player.
  • Never work on an electrical device that's still plugged in.
  • Opening a DVD player may negate the warranty. Read yours carefully before you proceed.
  • Follow these steps to remove it
    Step 1 Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
  • Step 2 Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place.
  • Step 3 Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
  • Step 4 Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn’t quite finished yet.
  • Step 5 Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
  • Step 6 Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you’re careful. You should be able to access and remove the disc.
  • Oct 10, 2009 | iLO DVDR05 DVD Recorder
    Stuck dvd in superdrive
    When you turn the computer on, press and hold the mouse button and keep holding it until the disk pops out.
    Nov 30, 2008 | Apple iMac G4 Desktop
    Philips DVD recorder, (250gb) DVDR3460H. can not remove disk .........
    your gonna have to open the machine up the there is a whits tab that lifts the disc up to spin you will have to use your fingers to slde it of that make sure its unplugged and then the white thing will realese
    Sep 19, 2008 | Televison & Video
    Stuck DVD
    im not resposible for anything here but try this. stick another disc in only about half way or as far as it will go up to that point. when the loading mechanism in the player sees another disc trying to come in, it pops up to accept the disc. it should spit your stuck disc back at you while holding the new disc in your hand.
    Jul 11, 2008 | Jensen VM9510 Car DVD Player
    DVD Player won't open
    Try this. This works on some brands and models.
    Power up the unit. Using the remote, press and hold the 'STOP' button for about 5 seconds. Release and press the 'OK' button.
    Jun 18, 2008 | Samsung DVD-V4600 DVD Player/VCR
    Computers & Internet Logo
    David Payne
    David Payne
