I have Raypak RP2100 spa Water heater.Last 5 years working good, But now its not working.I check all switches but How can I check sensor ? I cut sensor wire and touch togeather on that time start igniter and lit for 5 second but not flow gas in the burner.So main valve not supply gas in the burner. I thought I need to change my sensor may be its out of order. Please give advise. Dilip Patel
chillmaster
  • 104 Answers
SOURCE: I have a Raypak pool
Usually not the gas valve unless line voltage was applied to it. Millivolt systems are very touchy about connections. First check the output of the millivolt generator (thermopile) the wires for this usually go straight to the gas valve they should be one red and one white usually in a high temp fiber glass sheath. The wires will lead from the gas valve to a rod by the pilot. Test between the two wires with a meter that can read mV DC. You should have somewhere in the neighborhood of 450-600mV DC. If you do not, then the thermopile is bad. If you do, then it is either a bad connection somewhere or an open safety in the circuit. Check all of the safety devices and clean all of the connections in the unit with sandpaper. Usually for safety devices there will be a high limit on the discharge of the header, a pressure switch sensing water pressure, and a rollout switch or two in the control compartment above the burner. Good luck, I have to battle with mV systems all the time at work, usually it's just a bad connection.
Thanks,
Chillmaster
Posted on Jul 03, 2008
22yooper
  • 828 Answers
SOURCE: 2001 Coleman Niagara Elite folding
You may have one of two problems; The pilot orifice is very small and allows only a limited flow and any air trapped in the gas supply takes some time to bleed out while you are holding down the pilot button. Or the pilot orifice may be plugged in which case you would have to replace it.
Posted on Jul 10, 2008
  • 124 Answers
SOURCE: I have a problem with
sounds like its not proofing flame. it has a sensor usually like a needle sticks out into the flame that tells the gas valve the flame lit and is burning so its ok to keep sending gas, if its fails to proof flame then burner shuts down, then it tries to relight 3 times then locks out on fail safe. the blower will sometimes run continually once that occurs to highlight a failed condition. every time you reset it will try again 3 times then shut down. lp gas is very dangerous, even i do not work on it as the gas acts like gasoline and lays around. not like natural gas that disperses well. if you see the flame sensor try gently cleaning it with a little emory cloth. also a loose ground can cause this. check tio be sure any green wires are snug , they actually flow volts to ground through the flame on some to proof, thats why no ground no flame. if that fails then the board is most likely problem. change wire for wire , or get generic replacemant and follow directions exactly. good luck.some ignitors act as a flamre proofer as soon as they are done igniting! rarely do they fail to perform both funtions.
Posted on Nov 21, 2008
SOURCE: Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Posted on Jan 06, 2009
rayname
  • 70 Answers
SOURCE: cant find wireing diagram for carrier 585ejw30050ca
if you have a volt/ohm meter you can unplug all the wires to the valve set the meter to ohms and check to see across each terminal which have measurable resistance these should be the coil, usually the diagram is on the panel door i guess this is not the case so you will probably have to see which wires have voltage when your tstat is calling for heat also you need to make sure there are no other safety holding this circuit out let me know how you make out
Posted on Jan 09, 2009
Raypak RP2100 Model P0127NCO spa heater with a problem.
Cycling on/off like that can be a number of things. One of the more common problems is a "flow" problem. Try cleaning out your filter. If it is this type of problem, the flow switch is not sensing proper amount of water flow.
Jan 15, 2013 | Raypak Pool & Spa
Raypak 2100 turning off and on
check gas pressure if ok check flame sensor if ok check pressure switch make sure making contact or loose wires to pressure switch
Oct 03, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a raypak rp2100 which was working last weekend but wont switch on anymore . I checked the fuse and all ok. I do have a spare heater in the shed for spare parts. What would cause the heater not to...
The transformer would be the most likely cause. It is inside the chassis inside the junction box where the power comes into the heater. Check the secondary side for 24 VAC. It is likely not going to be there.
John
Apr 20, 2011 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How can i get a power vent for my raypak rp2100 pool heater
yes if no area on board for fan hook fan if series with firemans switch when fan on heater will work or a air switch
Oct 29, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
RP2100 GOES ON AND OFF REPEATEDLY
If you received the PRS error, then it is the water pressure switch. The water pressure switch, or heater actuator, ensures
that the heater operates only when the filter pump is in
operation. It is located on the inlet/outlet header. It is
factory set at 1.75 PSI for deck-level installations.
When the heater is located below the level of the spa
or pool, it may be necessary to adjust the pressure
switch to compensate for the no-flow static head. If it
is necessary to adjust the water pressure switch, Follow the directions in your manual.If your is the low Nox model, then you have a combustion fan. This has a fan air pressure switch but the error code for it is FAN I believe. If you don't have a manual you can get one at www.raypak.com
Jul 14, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater is making a knocking noise
low water flow check manual bypass in heat exchange if spring broke letting too much water bypass and overheating water in unit also see if pump ok and filters
Jun 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
What is causing the "shorted on water sensor"?
I have a RayPak 2100 heater and I have the following error:
Water sensor shorted. How do I resolve the problem?
May 31, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
