Question about Sony 1GB Memory Stick PRO Duo Memory Card
I try to record something and it says that the memory stick is full, than I put it into my computer and it says that is blocked how can i fix that?
    Problem Solver:
  • 16 Answers
Although the sony card is physically the same as an sd card, and will fit in a pc slot, the memory it contains is different, and is formatted differently, thus it cannot be read by a pc, it needs to be inserted into a sony machine that can read the files on it, then you can delete them, hope this helps
Posted on Mar 25, 2011
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
Sony cybershot h3 camera error 13:01, memory stick not recognized by camera or computer, How can I recover my digital photos from the memory stick
I have succeed to recover photos from memory card with Tenorshare Data Recovery.It is a professional photo recovery software that can recover data after deeply scanning your memory card to look for lost data. By the way,you can download it and scan your memory card for free to preview whether your photos can be recovered.Get it from http://www.any-data-recovery.com/
Jul 17, 2011 | Cameras
Trying to install Dynes 5 in 1 memory card reader/writer on my Mac running 10.6.4 Can I put the small disk in my laptop drive - it is a slip in slot
If you're worried, put the small CD-ROM into some other computer, and copy the entire contents to a full-size CD-recordable disk (or to a USB memory-stick).
Then, carry the CD-R (or the memory-stick) to your computer.
Dec 20, 2010 | Dynex 5-in-1 USB 2.0 Mini Memory Card...
Sony Handycam Dig 8 doesn't recognize tape when trying to record
If it has memory stick, Make sure your memory stick is in. Your memory stick is full. Delete the unwanted pictures from the memory stick or use a differnt biger memory stick.
I looked in the manual. It seems your camcorder does not have a slot for memory stick. But you may still save pictures on the tape. Here is the link to download the manual
http://www.docs.sony.com/release/DCRTRV140.pdf
Please read Page 40 "recording picture on the tape".
GOOD LUCK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 24, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
Internal Memory is full??
If you dont put a memory card in your camera it is forced to record on and read from the internal memory (which is pretty small). If you do insert a memory card (is it a memory stick?) you can read the card but not the internal memory. Try it both with and without the memory stick.
Apr 29, 2009 | Cameras
Movie recording disabled
it's either you finalized a disk or your memory stick is full. if possible delete recordings and or photos in your memory stick to enable recording, or put a blank disc..once a disc is finalized it cannot be used to record on the cam but could still be viewed on the cam by selecting the media format,
Mar 09, 2009 | Sony DCR-DVD610 DVD Camcorder
Hard drive is full
The memory stick can only be used for taking still pictures (which are of terrible quality). Your only option for creating space on your hard drive is to delete items. Before that you can upload videos to your computer and/or burn them on DVDs. Sony actuallly has a DVD burner called DVDirect where you can burn DVDs without the use of a computer. I hope this helps.
Dec 25, 2008 | Sony Handycam DCR-SR42 Camcorder
Not recording
i have a camcorder just like yours. by the way im not using memory stick because its pretty easy to use a dv tape.
try to switch from the menu your storage device like dv to memory card or stick. format it to your camera and computer. hope that helps!
CHARCOIS
Jul 28, 2008 | Samsung SC-D353 Mini DV Digital Camcorder
Computer doesn't recognise memory stick
well you could check if your media drive is compatible with memory stick duo/pro duo or update the drivers for it . or try something like going into its properties and click the tab called recording and select enable cd recording on this drive (if that renders your dvd drive inaccessible you can change the other drive(inaccessible drive) to that setting).
Oct 29, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Sony 1GB Memory Stick PRO Duo Memory Card Logo
35 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
