Question about Acer Aspire One Netbook 8.9" Notebook
Not open i push d switch open pwer light not continue to open
  • Acer Master
  • 32,281 Answers
Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced. Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's power socketcould be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Posted on Mar 25, 2011
My taillights and dash lights wont turn on. Im not getting power to that fuse
Now you need a wiring diagram to continue
your testing
Dec 03, 2014 | Cars & Trucks
Wanted to restore to original condition. Pressed power and then F8. Then accidently pressed pwer switch again. Now only have blinking amber power light
Are you able to get into safe mode by pressing F8. You can also try the last known good configuration option after pressing f8 continuously.
Sep 03, 2011 | Dell Dimension 3000 PC Desktop
Head light does not come on at all Checked fuse but nothing wrong no dim or bright Supposed to light up when bike starts, but does not. Tail light fine
SOUNDS LIKE DIMMER SWITCH. HI -LO. MAKE SURE YOU HAVE POWER IN. IF TAIL LIGHT ON CIRCUIT OK SAME POWER CHECK SWITCH ALSO START BUTTON COULD DO THIS CAUSE WHEN YOU PUSH START BUTTON TURNS PWER OFF TO HEADLIGHT IF DIRTY CORRODED ETC WILL NOT SEND POWER.
Apr 18, 2011 | 2005 kawasaki KLE 500
Rear brake light wont work when bake break is pushed only when front is pushed it works
Examine the rear brake pedal and linkage....there should be a light spring that pulls on the brake switch when you push the pedal down...possibly the spring broke and fell off.
If all is well...there should be a connector nearby for the switch...usually 2 wires....12 V power in on one, and power out to brake light on the other. With a multimeter, unhook connector and with key on...you should have 12 V on one of the two wires in the harness...if you don't...there is a harness issue.
If you have power to the switch, now test for continuity (ohms) across the unhooked switch wires ...should be open (no continuity ) with pedal up, and when you press down pedal...the switch should close and show very low ohms continuity. If you cannot get continuity...normally there is an adjustment to move3 the switch out further so the spring from the pedal pulls on the switch plunger more...if your are unable to get continuity by adjusting switch mount..replace switch..
Mar 21, 2011 | 2001 Yamaha YZF-R1
Go to start my car nothing happens look at the dash the r meaning reverse light is on not park push the stick shift back and back to park car starts ok.
improper park\neutral switch adjustment,
Check
1 The Park/Neutral/Back-up light switch
has a black colored insulator and is located
at the lower left hand side of the transaxle
near the oil pan. The switch inhibits starter
motor engagement unless the gearshift lever
is in the PARK or NEUTRAL position and
completes the back-up light circuit when the
gearshift lever is placed in REVERSE.
2 Prior to checking the switch, first make
sure the shift cable is adjusted properly (see
Section 4).
3 Raise the vehicle and support it securely
on jackstands. Extract the 2 push-in fasteners
and remove the transaxle splash shield.
4 Disconnect the electrical connector
from the Park/Neutral/Back-up light switch.
5 Using an ohmmeter, check for continuity
between the center terminal of the switch and
the switch body. Continuity should only be
present with the gearshift lever in PARK and
NEUTRAL. If continuity is detected with the
gearshift lever in any other position, replace
the switch.
6 Next, check for continuity between the
t wo outer terminals. Continuity should only
exist with the gearshift lever in the Reverse
position. Check the for continuity between
each of the outer terminals and the switch
body. No continuity should be present.
Replace the switch if it fails any of these
checks.
7 Install the transaxle splash shield and
secure it with the 2 push-in fasteners. Lower
the vehicle.
Replacement
Refer to illustration 6.10
8 Raise the vehicle and support it securely
9 Working under the vehicle, disconnect
the electrical connector from the switch.
Place a drain container under the transaxle as
some fluid loss will occur.
10 Unscrew the switch from the transaxle
using a box-end wrench (see illustration).
Discard the switch seal.
11 Look into the switch opening in the
transaxle. Have an assistant shift the
transaxle from PARK to NEUTRAL. Check
that the internal operating fingers are centered
in the switch opening.
12 Install the new switch and seal into the
transaxle and tighten the switch to the torque
li sted in this Chapter's Specification Section.
13 Recheck the switch operation (see
Steps 1 through 6).
14 Attach the switch electrical connector,
install the transaxle splash shield and lower
the vehicle.
15 Check the transaxle fluid level and add
more, if necessary (see Chapter 1).
Feb 18, 2010 | 1996 Dodge Stratus
"Door Ajar" light won't go off. Interior lights staying on.
I sprayed WD40 in the handle opening and moved it up and down a few times and sprayed some in the latch and it went away.
Feb 03, 2010 | 2004 Chevrolet Impala
Dryer wont start
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
if possible, with the door open, push the limit switch the door normally hits to let the drier know the door is shut. That switch may be bad.
Dec 27, 2008 | Whirlpool LEQ9858P Electric Dryer
Toshiba L45-S7423 won't power up
Based on my experience this sounds more like a display issue, not necessarily the LCD but most like the inverter somehow cam unseated or it's on it's way out, then again it could be a graphic card that has come unseated without opening up the LCD bezel or examining the graphics card it's hard to say, sorry
Hope this helps.
Dec 06, 2008 | Toshiba Satellite L45-S7423 Notebook
Sharp R-1505 microwave
The power fuse open , if open replace it don't make jumper it b
cause fire .
the power transformer builtin fuse open/
The door micro switch open /need to replace.
Jan 03, 2008 | Sharp R-1505 Microwave Oven
Acer Aspire One Netbook 8.9" Notebook Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
