Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printer when it prints a picture it comes out all green. what is the problem i just put in a new ink cart thankyou joanne
    Scholar:
  • 96 Answers
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Posted on Aug 05, 2008
Printing works but, paper comes out with faded picture. Ink cart. is new. I have a HP Deskjet D4100series disk???
Sometimes it takes more than a couple tries to get the right settings the first time you put in a new ink cart. Try using the calibration setting for the printer under it's properties?
Mar 15, 2010 | HP Deskjet D4160 InkJet Photo Printer
Colors are not printing correctly. put in a new cartridge, test page came back with only black, yellow, and blue. fiddled around with it a bit to no avail. put in anther new cartridge, test page came...
I use a small diameter silicone tube to carefully "prime" stubborn new carts by sucking a drop of ink out of the tiny print holes in the printhead part of the cart. Ink can dry at the head and since these carts work by electrical excitation, there needs to be liquid of each color at the holes. Slap a drop of water with your finger on the holes to start easy hesitant ones. Do not get the contacts wet.
Jun 04, 2009 | HP DeskJet 932c InkJet Printer
Print colors
You might want to run a cleaning page through it. This uses up more ink that a typical print job, but it will allow you to clean the heads and force ink through them.
Feb 14, 2009 | HP PSC 2110 All-In-One InkJet Printer
Print head
Check that all, printhead and ink are seated and contacts are correct.
Power down the printer and allow for a complete power on and self test.
Dec 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Black and white printing not working
sounds like its a expired ink issue. on alot of the hp photosmart printers the ink has a expirey date on the carts the best solution would be to contact hp and chances are they will send you free carts if your ink has been expired. when a black ink is almost out most of the time it trys to draw ink from the color carts mixing to make the appropriate color.
but you can also try the following.
See the instructions for
calibrating a print cartridge in
the Care and Maintenance
section of the HP Photosmart
Printer Help.
Aug 11, 2008 | HP PhotoSmart 7960 InkJet Printer
Colors
Did you run a quality test print by pressing ink etc...?
It might be that you have no magenta anymore.
If you can see all the 4 colored blocks on the test sheet, firstly try to copy(!) a picture with pink colors and secondly run a pc print. If there is still no pink and you have it blue or green on the COPY one the scanner needs readjustment (from service personell). If you have trouble with the pc printing, too there might be
a defective ink cart holder which leaks and mingles the ink (you need a new ink cart holder then)
Jan 08, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printer will not start after changing ink cart.
u better remove both catridges ,switch on the printer ,after that the print catridges lights will blink ,open the cover the catridge holder will come at the centre,put the catidges n perform the catridge alignement,n complete it
Dec 19, 2007 | HP Photosmart C3180 All-In-One InkJet...
Vertical lines
1. Took out the ink carts and cleaned the copper contacts of both the ink carts.
2. Clean the copper contacts on the ink carts slot in the printer and then insert the ink carts in the printer and then print out the page.
Dec 11, 2007 | Epson Stylus C60 InkJet Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
23 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
