Question about ASUS Computers & Internet
My motherboard ASUS P4P800 with pentium IV 3.2 HT processor. 1. Happen to be most of the time to switch on the computer it will show different loading sometimes with HT sometimes without HT. 2. The BIOS setting will changed. 3. Even worse, after switch ON the computer. Windows XP loading... Then nothing come out. Is that it's time to get a NEW Motherboard or Power Supply Problem or the Processor itself?
    Master:
  • 525 Answers
Pull out your ram for 10 seconds. Put it back in. Restart. See if this helps. Make sure there is no power when doing this.
Posted on Mar 25, 2011
Aopen ux915g
Yes. Any Intel Pentium 4 processor will fit fine. That said A P4 processor is fast, but the Pentium D is much faster. The D stands for Dual Core. This means that they have two on die processor cores instead of just one, as the Pentium 4 does. Two processors also makes it better for "demanding" applications.
The Pentium D is better if you have a motherboard that will utilize the technology. As stated the Pentium D is Duel core. This is Intel's way of creating the closest environment of a true duel processor. The HT is for Hyper-Threading which acts like a zipper and allows several applications to process at the same time. The Pentium D will really make a difference when used with the new 64 bit operating system.
However, HT (Hyper-threading) P4, does have emulated Dual Core processing. In short, the processor makes the computer think its runing a dual core. The Pentium 4 also has a couple different levels, so if you are trying to make a comparison, make sure that you look carefully.
Although neither can match the power of an Athalon or an AMD x2 processor. If you are buying, get something with 64 bit processing. WAY faster and better for games and high graphic systems.
May 13, 2014 | Computers & Internet
Hi.. I have a server system having Intel Pentium 4 processor. The following details are written on the Processor. Intel (m) (c) '03 PENTIUM (R) 4 2.8 GHz, IM1800, jl79k MALAY, Q417A92 t417b040 ...
hi,
you can on this motherboard models for your intel Pentium 4 processor,
1. ASUS P4P800 Deluxe
2.MSI Neo2-FIS2R
3.ASUS P4C800 Deluxe
4.Intel D865PERL
5. ABIT IS7
Feb 16, 2011 | ASUS Support Intel Pentium M Processor and...
Audio problem
Go to the follwong site and follow these steps: -
http://support.asus.com/download/download.aspx?SLanguage=en-us
1. Select Product - Motherboard
2. Select Series - Socket478
3. Select Model -
P4P800-X and click search, it would ask you for operating system
4. Select operating system and download drivers
Hope it helps!
CreativeTECH
Nov 25, 2010 | ASUS P4P800-X Pentium Motherboard
When I start, the powerled flicks (blinks) and the puter won't start. Running XP with 2 x- 512 mb of ram
Bad Power Supply. Weak voltage power rail. (Or power rails in this case)
Ordinarily a Power Supply that is bad will at least light LED lights, and maybe spin fans, but will not have enough power to turn the Processor on.
1) ALL of the LED lights on at one time, use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor can use 51 to 125 Watts. Depends on what Processor it is.
[ Asus P4P800-MX? Can support up to an Intel Pentium 4 Extreme Edition at 3.40GHz.
109.6 Watts,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Prescott_2M_.2890_nm.29
Replace the Power Supply.
Is this in a pre-built computer, or one you built?
Nov 21, 2010 | ASUS P4P800-MX Motherboard
ASUS P4P800-SE (I have 2 identical boards) 3.0 GHz HT processor -- tested & good (actually have 2 spares) 2.5 GB RAM -- all tested & good 2 different power supplies tested (350W - seems to work...
I don't understand... are you able to POST or not?
Are you sure that both DVD drives that are on the secondary IDE channel are configured as MASTER and SLAVE by using the pins on the back of the drives?
Mar 31, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Computer Will Not Boot
It sounds like it could be your processor, how did you test your processor to make sure it worked correctly? Also how manny stick off RAM do you have and the total amount in MB or Gigs.
Jan 22, 2009 | Intel Foxconn Motherboard
Problem, as it Restart automatically by itself within 1- 10min
i had the same problem. its within your harddrive. you must reformat it
May 14, 2008 | ASUS P4P800-X Pentium Motherboard
Processor compatibility
looks like you limited to the p4 Prescott, this is a p4 list of the cpu support from asus. I also looked at their bios update page and found no bios improvement. if you can move to the 775 platform ,you can move from p4. otherwise, the p4's are still  good . I had the cpu that is the 2nd one down. 3.2ghz oc'd to 3.8ghz full time with a max of 4.0ghz on air[775 platform] quad-pumped gave me a 1001.3mhz FSB
Supports Intel Prescott CPU
P4-3.20E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   ALL 1006 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:1MB, rev.G1)   ALL 1011 gogo.gif
P4-3.40 GHz (800 FSB, L2 cache:512KB, HT, D1)   ALL ALL gogo.gif
P4-3.40E GHz (800 FSB, L2 cache:1MB, HT, 90nm)   2.00 1006 gogo.gif
P4-3E GHz (800 FSB, L2 cache:1MB, HT, 90nm)
SEE 4 YOURSELF
http://valid.x86-secret.com/show_oc.php?id=156822
Oct 30, 2007 | ASUS P4P800 SE (890552603657) Motherboard
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
