Question about Jay NEW JAY TURSER BLACK SINGLE CUT SET NECK LP JT-220-BK
Cai i replace my j turser broken guitar neck?
  • Jay Master
  • 5,603 Answers
Only a guitar repair facility can answer this. I have repaired a couple myself but it depends on the break. On mine the head was broken off near the nut. It takes some skill in doing the repair.
Posted on Mar 25, 2011
What is the best guitar strings for gospel music?
When I started to play country and gospel on my guitar I found that these are the way to go. I hope my advice was a help.
JONATTHAN E.
CHAPMAN
Mar 06, 2015 | Washburn Jay Turser concert style acoustic...
The neck of my guitar is not straight but i alreadyadjusted the trusrod
Edgar,
How are you determining that the neck is not straight? If you are thinking the neck is not straight because the strings are at different heights along the neck, the problem may be neck tilt or saddle and/or bridge height. You can raise or lower the bridge system or string saddles to add or subtract string height along the neck. In addition, neck tilt (particularly easy to adjust on bolt-on necks) refers to the angle that the guitar neck exits the neck pocket on the guitar body. This also effects string height.
Conversly, if you see a distict bow or bend in the neck when you look down the top edge of the neck, the truss rod may indeed be involved. Generally, most players like a little bit of "relief" in the neck. That is to say, a little bit of a concave bow. I prefer a relatively straight neck with very little relief. Just preference.
However, you mentioned you already adjusted the truss rod. Make sure the truss rod is functional. If you loosen the bolt or hex on the truss rod and the concave bow on the neck gets more pronounced, it is likely that you truss rod is ok. If you make adjustments on the bolt and there is little or no change on the neck relief, it is possible that your truss rod is not functioning or is broken. It is very possible to break a truss rod by over tightening but it would take some real effort to do. Still, it is possible.
Check out those points and see if it helps.
Confirm truss rod is working.
Check bridge height and saddle height.
See if adjusting neck tilt is possible on your model guitar.
Good luck.
Oct 17, 2013 | Fender Music
Truss rod slippage
If the truss rod has broken loose, it is not user serviceable. This needs to go to a repir shop. The fretboard has to come off to fix this. The repair may be more than the value of the guitar.
May 09, 2012 | Epiphone Dot Electric Guitar
My neck of the guitar is broken. Please suggest a poosible way to repair this. Guitar is Samick Avion AV 3.
This is very serious as a broken neck means a lot to the guitar. It depends on the section broken and if the fret is also damaged.
Since the neck needs to be quite strong as the strings are tightened and must not in any way bend or be soft-- as the TUNING WILL KEEP ON CHANGING- the neck must be wedged back and then maybe the use of a counter steel reinforcement might be needed.
It is best to get this done professionally , if you intend to get this guitar to retain the quality.
Sep 13, 2011 | Samick Greg Bennett Avion AV-3 (Black)...
Replacement neck required
There are many different company's that offer replacement necks for your guitar. You can try, Warmoth, StewMac, Allparts, One of the best bolt on necks made sold by Carvin.
Aug 24, 2011 | ESP LTD V50 Electric Guitar
I need documentation to set neck adjustment and intonation for a Gibson ES-359 custom. It doesn't seem that Gibson has anything readily available.
Intonation is easy if you have an electronic tuner, and instructions for a Les Paul style guitar will be close enough. Same with neck adjustment, if it is a set neck, use the Les Paul info. If a bolt on neck, everything but the neck angle is still relevant.
Jul 01, 2011 | Gibson Guitar Gibson Custom ES 359 Semi...
Hey my ax260 strings rattle alot mainly the bass strings? and every time i touch the coil tap knob a ugly sound comes from the amp its not even a year old yet and never been knocked over or droped could...
Strings "rattling" is usually guitar setup. This has to do with string height and POSSIBLY the neck truss rod. For the latter, have a guitar shop set it up for you. Hum from touching a knob is likely a broken ground wire in the cavity of the guitar. Also view videos on YouTube search "Guitar setup"
Apr 27, 2011 | ESP Ltd EX-50 Electric Guitar
Epiphone sheraton 2 has broken neck tuner section
That is near fatal... you might find a Luthier that could repair it. I have repaired three broken neck instruments myself, an acoustic bass, acoustic hollow body, and a banjo... it is NOT fun and requires great care. The strains on the neck from string tension cause a lot of force that tries to re-break the neck.
Mar 15, 2011 | Epiphone Elitist Sheraton Electric Guitar
Ibanez artist guitar circa 1983. buzz in string. bowed neck. not sure how to adjust rod. bow is like a hump rather than valley.
The rod is probably broken - this causes the buzz and the bend in the neck. Replace the neck.
Mar 06, 2011 | Ibanez Music
Strings are very far away from the last frets on the neck...
Sometimes the truss rod (nut you are referring to) will do the trick. The truss rod runs under the fingerboard and allows you to give the neck relief or tension. Some truss rods are dual action but I'm guessing yours is designed simply to give basic relief of the neck. I would make sure the truss rod is adjusted properly before sanding down the saddle. If you sight down the neck you should be able to see the relief in the neck - just use the string as your straight-edge. Most guitars need a slight amount of relief but higher-end guitars can be almost straight (better fretwork.) Once the neck has been adjusted correctly you can move forward with the setup.
Make sure the nut is also the proper height. If the nut is too low (1mm height between bottom of string and first fret) you should get it replaced by someone capable of doing such a thing. If the nut height is okay I would suggest moving forward cautiously by sanding the bottom of the saddle. Make sure this is done patiently and carefully as it can drastically change the sound and playability of the guitar. Hardly any material needs to be taken off to lower the action just a little. Error on the side of not-enough than too much. Make sure the bottom of the saddle remains flat! If the bottom isn't flat the guitar can sound horrible and if there is an undersaddle pickup it might not pick up evenly. The easiest way to do so is to tape some sandpaper rough side up on a flat surface (just don't pick something like mom's heirloom or something important in case it gets scratched.
If you'd like more detail check out http://www.fretnotguitarrepair.com/Repairs2.htm
Good Luck!
Nov 15, 2008 | Epiphone Aj-100 Acoustic Guitar
Jay NEW JAY TURSER BLACK SINGLE CUT SET NECK LP JT-220-BK Logo
53 people viewed this question
Top Jay Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Jay Music Expert? Answer questions, earn points and help others
