Question about Mtd Garden
I have an older 4 cycle Briggs and Stratton engine that needs points replaced. How do I remove the flywheel in order to get at the points? Thanks
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
You must remove recoil housing and flywheel retaining nut or nut assembly. a flywheel puller is recommended however a two person team will do; using two prybar system pry flywheel up or out away from engine block prying from opposite sides of flywheel just enough to remove flywheel end play but not ever enough to pop off flywheel. It is very important to not pry so hard as to ever break any component under or around bottom of flywheel. Now with the use of a brass punch or aluminum shaft equal to or larger that diameter of shaft where retaining nut was removed; person # 2 should us a small ball pin hammer or equivalent to strike brass punch or aluminum shaft to break tapered shaft from flywheel. Never us a large hammer as engine damage is likely. Usually one or two good solid strikes is all it takes so good luck.
Posted on Mar 27, 2011
How do i get the flywheel off to get to the points i have no spark
use a three prong pulley puller and pull it off before this are you sure you have points chek blad brake is disengaging befor pull fly wheel
May 13, 2012 | Briggs & Stratton Briggs Stratton...
Have an older tiller w/a 5hp briggs motor, no spark,had to repair inside wire going to coil, still no fire, are there points inside flywheel i should check & does flywheel pull off
First check continuity of coil to ensure there are no breaks .If there is a wire heading in under the flywheel, it is probably going to the points. Check coil is grounded properly.
The points are normally behind the flywheel which you will have to remove using a pullers. The nut holding the flywheel on to the shaft normally loosens in the same direction as the flywheel rotates but if there is any shaft thread exposed above the nut, check the threads to confirm this.
The capacitor near the points may be shorted, disconnect it to check this with a continuity tester.
Mar 10, 2011 | Briggs & Stratton Hammering
Trying to change the points on an old briggs and stratton 8 hp engine
Need to know what model Older engines have points "under" the flywheel. Use a wheel puller to remove after removing the nut in the center of the flywheel. Newer motors have an electronic ignition module. Follow the small wire from the magnetio. If it goes under the flywheel then you have points. If it goes to a small device on side of motor, you have electronic. You can go to http://www.briggsandstratton.com/ and look up your odel number.
Jun 23, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
FLYWHEEL REMOVAL
You need a flywheel puller tool. You can rent them at most auto parts stores for a few dollars a day. Be advised that flywheels can be very hard to remove, and can come off suddenly and violently when using a puller, keep your face away.
May 04, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Removal of flywheel from briggs and stratton 4 cycle engine 3 hp
Without the $100 flywheel remover that briggs will happily sell you you can do the following.
First you will need another body to help, two if available
2 pry bars or large screwdrivers
A air hammer if you have it or a large hammer if not
Loosen the flywheel nut until it backed off til the nut is just barely one thread or even with the shaft. Now put your pry bars behind the flywheel on opposite sides. Have someone provide constant pressure (don't be too forceful the block is made of aluminum and can be damaged). Now hit the end of the shaft with a hammer or air hammer (the nut is protecting the shaft threads) with medium power. With a few careful hits the flywheel should pop right off.
If you run into trouble or are unsure of something in this proceedure please ask.
Mar 30, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Cant get a spark on my briggs and stratton 4hp engine, trying to
gap from coil to flywheel is .010. if you've replaced coil, points and condenser with no spark i would try replacing the coil and points with an magnetron kit or a coil that allows for the elimination of points.
Mar 21, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Garden Logo
145 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
