Question about Toshiba 65HX81 65" Rear Projection Television
Red line will not focus
Toshiba 65hx81
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Needs convergence rebuild
call qual tech
Posted on Aug 03, 2008
Blurry Picture on Toshiba 65HX81
yes the tv has convergence problem u will need a tech to reposition it
Jul 11, 2013 | Toshiba 65HX81 65" Rear Projection...
Red gun convergence problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 16, 2009 | Toshiba 65HX81 65" Rear Projection...
Toshiba 65HX81 No Power Issue
ur ignition card/panel is burned change it!!
Aug 16, 2008 | Toshiba 65HX81 65" Rear Projection...
Toshiba 65hx81
have tech to rep. audio amp.
Jul 26, 2008 | Toshiba 65HX81 65" Rear Projection...
Red power light flashs red
Those are nice looking tv's. Unfortunately it might be the convergence board IC's that failed. (color alignment controller) This isn't a DIY project, usually cost around $300 a failed IC. You might at least have a technician diagnose it for sure. Then you'll know whether to invest or save up for something new.
Apr 23, 2008 | Toshiba 65HX81 65" Rear Projection...
Toshiba 65Hx81 model rear projection
The picture tubes dim over time. It's possible they need to be replaced and/or cleaned. There are 3 of them (one blue, one red, and one green).
Jan 28, 2008 | Toshiba 65HX81 65" Rear Projection...
Toshiba 65HX81 65" Rear Projection Television Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
