Question about LG WM-2277HW Front Load Washer
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
    Sergeant:
  • 194 Answers
Common causes
door gasket damaged(torn)
Dispenser fault
Lint filter door not fully closed
It sounds like you might have a damaged outer bowl, broken by a foreign object(coin, wire,screw)
Posted on Mar 25, 2011
LG front loader WD14071SD6 won't fill and run on cold wash. Works fine on hot. Thanks
The main causes your washing machine is not filling with water MAY BE:
1. One of the water valves (hot or cold) supplying the washer with water has been turned off or closed.
2. Your washer has a shutoff valve on the back that may be in the closed position
3. There may be a water filter on your washer that is clogged and tells the washer computer (control board) to not allow water to enter.
4. A hose or water connector on the back or inside the washer is defective or clogged.
Dec 29, 2016 | LG Washing Machines
Even when the machine is set to cold it pulls in hot
not sure on that one most machines are cold fill now,,think it is to do with the valves been closed , even though the machine is in a cold wash it registers a fault when any of the valves are closed
Nov 10, 2013 | Whirlpool Duet GHW9150P Front Load Washer
LG washer not filling with water
I take it you mean you cleaned out mesh inserts in the entry side of the hot and cold water valves?
Inside the valves are rubber diaphragms which when they age, perish......a bit like you and me!
Provided voltage is being applied to the valves you will hear them "Buzz" when the time is for water to enter the machine. If they buzz but do not allow water entry, they need to be replaced.
Poppa
http://www.cdbaby.com/cd/poppamadison
Jan 29, 2013 | LG WM2277H Front Load Washer
My washer wm2277h does not have cold water just hot water..Can someone please help me
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 23, 2011 | LG WM2277H Front Load Washer
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it.
If leaking behind unit : check water hose , is it placed properly ?
If leaking under unit : call technician to repair it.
good luck.
Mar 25, 2011 | LG WM-2277HW Front Load Washer
I want to clean the soap and softner holders I need a manual
http://www.retrevo.com/support/LG-WM2277H-Washers-manual/id/438ag213/t/2/
I clean mine with plain hot water and a rough towel. Then I fill the dispenser with hot water and run a light wash cycle.
Dec 31, 2010 | LG WM2277H Front Load Washer
What type of washer does the LG WM2277H take for the cold inlet hookup?
The water supply lines for the LG WM2277H are the same as almost all clothes washers sold in the US, which are standard garden hose threads, and use a standard garden hose washer.
Jun 17, 2009 | LG WM2277H Stainless Steel Front Load...
MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
May 06, 2009 | LG WM2277H Front Load Washer
Water leaking from hot water connection
Try sliding the panel backwards it should slide off.. Hopefully this should do the trick
Apr 26, 2009 | LG WM-2277HW Front Load Washer
No water geting into washing machine.
check hot and cold inlet vavle with meter...do you fell them humming,,or vibrating...
Jan 02, 2009 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
